Re: 3690933 mopar valve springs
[Re: A727Tflite]
#3209565
01/31/24 04:38 PM
01/31/24 04:38 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Why not just use a good PAC equivalent spring? Or any other equivalent ... that would be too easy
[Re: MO_PA]
#3209571
01/31/24 04:49 PM
01/31/24 04:49 PM
Posts: 3,076 Michigan
A727Tflite
I may have to use something else, I've have used the Mopar springs on several 440's and I like the way they work on the cam that I use. It would be interesting (and surprising) to see if they are made by the same company from back in the day. I used them on quite a few stock Eliminator cars (street hemis, max wedge, six pack) in the 70’s and they were great springs. I think back then Associated Spring made stuff for Chrysler/DC.
[Re: lewtot184]
#3211115
02/06/24 01:55 PM
02/06/24 01:55 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
the real problem with the '933 spring is they get into coil bind rather quickly and are a high rate spring. As you said, not a bad choice for a fairly limited selection of cams, and not really a good match for anything “modern”. Back in the day, the MP engine manual was pretty keen on making sure there was “plenty” of open spring load. Of course, that was when cams going flat wasn’t as common as it seems to be currently.
