Re: Sick Week Florida
[Re: fast68plymouth]
#3208843
01/28/24 05:53 PM
01/28/24 05:53 PM
Posts: 10,039 MN
JERICOGTX
MN
Joel, What’s the goal for the 5 day average? I think his goal is to just survive the week with the Heartburn HEMI, then get home and rip it out to start on a new build.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3208858
01/28/24 06:45 PM
01/28/24 06:45 PM
Posts: 7,496 Minnesota
Hemi_Joel
Minnesota
I just want to finish, but if I can run low 10's I'll be happy. If I can break into the 9's, I'll be jubilant. My first test pass was fraught with driver error. Went 10.92 @125. I forgot to bring it up on the 2 step, and I let off before the end. I'm in line for the all run session.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3208970
01/29/24 11:41 AM
01/29/24 11:41 AM
Hemi_Joel
Minnesota
Second pass yesterday, spun the tires a bit, ran a 14360 ft, then I missed third gear and aborted the pass. I figured out that the new shifter I put in that I never should have put in sits a few inches further forward than my old shifter and when I'm strapped in the bucket seat and my arm is straight I don't have enough reach to get it all the way into third gear. So I'm trying to find somebody with an acetylene torch here in the pits so I could heat it and bend it. Otherwise I'm going to put a couple half rolls of paper towels behind my right shoulder before I strap in and see if that works.
[Re: JohnRR]
#3209106
01/29/24 10:59 PM
01/29/24 10:59 PM
Posts: 8,172 Plymouth, MI
Blusmbl
Plymouth, MI
I wasn’t able to catch much of the live feed, but Joel turned in a 10.71 at 136 on day 1. Killer mph!
There were an incredible number of oil downs today, I don’t think D class made any passes until 3:30. Two of the radial cars went sub 6.50, and Jeff Lutz’s pro mod is there and went 6 teens.
[Re: Blusmbl]
#3209131
01/30/24 02:10 AM
01/30/24 02:10 AM
Hemi_Joel
Minnesota
We just got to the hotel in Bradenton at about 12:45 a.m. It has been a long day but a good one. My trunk monkey in training, Cam really stepped up to the plate and kept us organized this morning for getting everything that we need out of the trailer and organized in the trunk of the car and having us already before the driver's meeting. At the driver's meeting I couldn't hear a thing they said. The PA system had a lot of reverb. But Cam heard it so he filled me in. After the driver's meeting we had a half an hour to be out of the area where the trucks and trailers are being stored, and we made it with plenty of seconds to spare. On both test passes Sunday, I missed the third gear shift. I have just installed a new shifter that I never should have put in there, and I was blaming the shifter. But this morning I figured out that The handle on the shifter is further forward than my old one was by at least a few inches. When I'm all strapped into the seat and my arm is extended straight forward as far as possible, it's not far enough to put it solidly into third gear. We tried to find an acetylene torch to heat and bend the shift lever but no luck. Someone lent us a mapp gas torch but it just didn't have enough heat to do the job. So the solution was when I strapped into the car, I had two rolls of paper towels behind my shoulders holding me further forward. It was pretty uncomfortable but proved effective. We got called to the lanes at 11:15 a.m. and we were ready. 3 hours and 58 minutes later, after a ridiculous number of oil downs and what seemed like slow clean ups, I finally pulled into the burnout box. The guy in the other lane pre staged first so I put a little pressure on the brake pedal and held my line lock button and bumped in to stage, then just as he was moving forward my stage light went off which threw me off a little bit. As I started to bump ahead just a little bit, I didn't have the engine up against the two step revlimiter yet. Oops.The yellow came on almost instantly after I staged again and we are on a pro tree so the light was green before I even got the engine up on the limiter. I wasn't really thinking about reaction time, because I'm used to drag weak where it doesn't matter. When I was ready, I launched the car and the rear tires spun and hopped a little bit but then they really dug in in the car took off! It felt like a really good pass and I was thrilled that I hit the third gear shift with no problem. The car pulled really hard all the way to the finish line and felt good and stable in the shutdown.
I ended up running at 10.31at 136, but got a penalty added to my official ET because of the slow reaction time. That's a Sick Week rule I'll definitely remember! We got the car changed over to Street pretty good, but we have a few issues that we had to address and will have to address. It's too late now to tell any more of the story. Hopefully tomorrow goes as well.
[Re: BDW]
#3209141
01/30/24 08:13 AM
01/30/24 08:13 AM
Hemi_Joel
Minnesota
Anything over 1 second gets added to the et.
I'm looking for an oxyacetylene torch near Bradenton Motorsports Park to bend my shift lever. If anyone is around here and has one I could use for a few minutes, please give me a call at 612-221-0910.
[Re: Hemi_Joel]
#3209145
01/30/24 09:12 AM
01/30/24 09:12 AM
Blusmbl
Plymouth, MI
It can't hurt to try asking one of Cleetus's guys, either Tye or Zach. They have torches at both their shop and the Freedom Factory, and you're right next to them. Good luck, and it sounds like the car is running awesome!!
[Re: Hemi_Joel]
#3209154
01/30/24 09:43 AM
01/30/24 09:43 AM
Posts: 10,039 MN
JERICOGTX
MN
I'm looking for an oxyacetylene torch near Bradenton Motorsports Park to bend my shift lever. If anyone is around here and has one I could use for a few minutes, please give me a call at 612-221-0910. You can't just bend it with your brute strength you always talk about???
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3209157
01/30/24 10:00 AM
01/30/24 10:00 AM
Hemi_Joel
Minnesota
I found a guy, we are there now
[Re: Hemi_Joel]
#3209215
01/30/24 01:50 PM
01/30/24 01:50 PM
Hemi_Joel
Minnesota
One and done at Bradenton!
