Truck engine brackets
#3208145
01/25/24 06:56 PM
01/25/24 06:56 PM
Posts: 31,036 Oregon
AndyF
I'm cleaning up the shop and came across a box of what I think is truck motor mounts, or engine brackets. I think I have both early and later truck mounts, mostly big block but the black set is marked 360. Just thought I'd double check here before I put them up for sale. Are the straight ones the later 2wd truck mounts? I think the ones with the extra kickout bend came from an earlier truck, maybe a 1970?
Re: Truck engine brackets
[Re: AndyF]
#3208515
01/27/24 02:35 PM
01/27/24 02:35 PM
Posts: 4,919 Wills Point, Texas
Hugh Jorgan
Wills Point, Texas
First pic is 4x4 BB Second pic is 2wd BB (I used to make them.) Third pic is 2wd & 4wd 360 (i have a set in the shop currently) All are 72-92 mounts Motorhome brackets are different 71 and older brackets are different.
