Re: Cage
[Re: Cab_Burge]
#3208218
01/26/24 06:25 AM
01/26/24 06:25 AM
Posts: 2,916 A shed in England
Tig
A shed in England
I'm not sure about the 1/8 mile requirements but I did have to have the funny car cage added to get my old S/P Cuda cerrted to 8:5 ET., maybe it was to 7:50 ET 25.5 cage (halo) only req'd for quicker than 8.50 (25.5 will cert to 7.50). For the 1/8 I believe it's quicker than 5.49 et and more than 125mph that requires a 25.5 (or 25.4) chassis.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: Cage
[Re: Tig]
#3208225
01/26/24 08:37 AM
01/26/24 08:37 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
My street car has a 25.5 cage certified to 7.50's. I absolutely hate that more and more of everything is going to 1/8 mile. 99% of the races are won on the better launch. Drag racing has always been and is meant be a quarter mile.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: Cage
[Re: 6PKRTSE]
#3208354
01/26/24 07:13 PM
01/26/24 07:13 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
My street car has a 25.5 cage certified to 7.50's. I absolutely hate that more and more of everything is going to 1/8 mile. 99% of the races are won on the better launch. Drag racing has always been and is meant be a quarter mile. To win any type of a dial in race you have to drive both ends of the track regardless of its length, correct
Re: Cage
[Re: Cab_Burge]
#3208381
01/26/24 08:58 PM
01/26/24 08:58 PM
Posts: 9,835 MI, usa
dvw
MI, usa
The 1/8 mile cage certs aren't set in stone. 8.50 cert will get you to around 5.30 Doug
Re: Cage
[Re: Cab_Burge]
#3208385
01/26/24 09:07 PM
01/26/24 09:07 PM
6PKRTSE
Motor City
My street car has a 25.5 cage certified to 7.50's. I absolutely hate that more and more of everything is going to 1/8 mile. 99% of the races are won on the better launch. Drag racing has always been and is meant be a quarter mile. To win any type of a dial in race you have to drive both ends of the track regardless of its length, correct Dial in bracket racing is lame and boring. I get that it has its place to make it fair for everyone regardless of vehicle or budget. I have just never been a fan. It's called Drag Racing, first one to the finish wins.
Re: Cage
[Re: Thelma133]
#3208398
01/26/24 11:03 PM
01/26/24 11:03 PM
Posts: 2,109 Byron, NY
W.I.N. Racing
Byron, NY
This is what the NHRA has to say about it. So No not until you go under 4.49 (1/8 mi) - These are for Super/pro - Pro type Bracket cars. Class cars may have different requirements ROLL BAR Roll bar mandatory in all cars (including T-tops) running 11.00 (*7.00) to 11.49 (*7.35), in convertibles running 11.00 (*7.00) to 13.49 (*8.25), and in all dune-buggy-type vehicles running 12.00 (*7.50) seconds and slower. Permitted in all cars. See General Regulations 4:10, 10:6.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Cage
[Re: W.I.N. Racing]
#3208421
01/27/24 08:05 AM
01/27/24 08:05 AM
Tig
A shed in England
Interesting, I always thought it was done using 1/8th mile to 1/4 mile equivalents. For example. a 5.00 car in the 1/8th (7.9 ish 1/4), will require 7.50 - 8.49 safety requirements and a 5.50 1/8th (8.7 ish) would require 8.50 - 9.99 stuff. Only had a cursory glance but I can't find any mention of 1/8th mile chassis requirements in the NHRA rule book I believe all the chassis certifications below require a halo or funny car style cage 25.1 SFI Full Body Chassis Spec, Pro Stock . . . . . . . . . . . . . . . 1 year Adv. E.T. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .3 years 25.2 SFI Full Body Chassis Spec, 3,200-Pound Maximum . . . . .3 years 25.3 Full-Bodied Car, Tube Chassis Roll Cage 6.50-7.49, 3,600-Pound Maximum. . . . . . . . . . . . . .. . . .3 years 25.4 Full-Bodied Car, Tube Chassis Roll Cage 7.50-8.49, 3,600-Pound Maximum. . . . . . . . . . . . . . . . . .3 years 25.5 Full-Bodied Car, with OEM Frame 7.50-8.49, 3,600-Pound Maximum. . . . . . . . . . . . . . . . . .3 years
Re: Cage
[Re: 68roadrunner]
#3208606
01/27/24 07:50 PM
01/27/24 07:50 PM
Posts: 8,250 fredericksburg,va
cudaman1969
fredericksburg,va
Any certification quicker than 8.50 has a funny car cage. As mentioned around 5.40 Well I’ll never have to worry about that. Of course I could install one in my cage but don’t want it, way too many bars to get in and out of now.
Re: Cage
[Re: 68roadrunner]
#3208645
01/27/24 10:35 PM
01/27/24 10:35 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My mild steel Daytona already had an 8.50 cert and a funny car cage. I paid to have it upgraded to a 7.50 cert and was told it needed four bars. The guy doing the work had it up on his hoist and an NHRA certification guy found 3-4 more bars that needed changed out because of rule changes which was fine with me. My blue heads up car is chrome moly and has a 6.50 NHRA certification
Re: Cage
[Re: 68roadrunner]
#3208810
01/28/24 03:47 PM
01/28/24 03:47 PM
Posts: 1,099 Massillon, Ohio
cudatom
Massillon, Ohio
Alot of people don't like them, and I understand why. And there's several more bars involved to make one cert. When my mild steel cage was removed and replaced with CM I was going to add a funny car cage. My chassis guy and I discussed this but when he heard I'd also drive it on the road from time to time he said he wouldn't add it . He said in the street it wasn't safe. Not a problem as I won't go faster than 8.5.
Ok
Re: Cage
[Re: 6PKRTSE]
#3208930
01/29/24 12:53 AM
01/29/24 12:53 AM
Cab_Burge
[quote=Cab_Burge][quote=6PKRTSE]]
Dial in bracket racing is lame and boring. I get that it has its place to make it fair for everyone regardless of vehicle or budget. I have just never been a fan. It's called Drag Racing, first one to the finish wins. Do you race? If so what class? How often do you get to race? My new car is intended to be a heads up no breakout car for all out heads up racing in the local northwest heads up no prep series that has around 5 to 6 races a year up here due to the weather and track schedules I was told earlier this year the promter may have stop proming those races due to having health problems in his family that need all of his attention, I'm praying for them I will take it put for testing and tuning and will probably enter it into some S/P races to get more seat and tuning time
