Re: Painting plastic parts?
[Re: tboomer]
#3208228
01/26/24 09:12 AM
01/26/24 09:12 AM
Posts: 4,768 Holland MI Ottawa
2boltmain
Holland MI Ottawa
ABS is a common interior plastic material and paint adheres to it very well- much better than other plastics. Spray can paint especially on plastics is not durable where it is frequently handled/manhandled. That said I believe HVAC vents are ABS and being they are just touched with finger tips the paint covering should hold up and be fine.
Keep old mopars alive.
[Re: burks340]
#3208259
01/26/24 11:11 AM
01/26/24 11:11 AM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
I use SEM products on all of my dash restorations.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: tboomer]
#3208265
01/26/24 11:27 AM
01/26/24 11:27 AM
Posts: 3,042 N.W. Florida
Fat_Mike
N.W. Florida
Here's a recent thread that might be useful:
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/3203198/Searchpage/1/Main/261118/Words/%2Bplastic/Search/true/re-body-guys-painting-plastic.html#Post3203198
[Re: moparx]
#3208315
01/26/24 03:20 PM
01/26/24 03:20 PM
70gtx440dana
Lansing, MI
what product number[s] was [were] used on the brown dash restoration ? TIA Had to have the colors custom mixed for the tan/brown dash.....the standard offerings were not a good match. I do not have any material left to reference product ID or color code.
[Re: gtx6970]
#3208372
01/26/24 07:57 PM
01/26/24 07:57 PM
Posts: 4,916 new berlin wisconsin
Mr T2U
i am a PPG certified painter. when painting plastic the most important part is to identify the type of plastic you are painting. ABS type plastic doe NOT require adhesion promoter. TPO type plastics DOES require promoter. fastest way to identify the type is cut a small sliver off the part. then place it in a cup of water. force the plastic to the bottom of the water several times to make sure you break surface tension floating the plastic. IF the plastic floats you need adhesion promoter. if it sinks no promoter is required.
if promoter is required LIGHTLY scuff the plastic with a fine grit scotch brite. i use a gray.. DON'T heavily scuff it, use a RED scotch brite pad. the promoter will swell up the scuff scratches making a mess.
plastic needs to be CLEAN before painting. i found using white wall cleaner and a gray scotch brite cleans it really good. make sure you completely rinse off the soap before painting. you might try wiping it down with rubbing alcohol works great if on a budget. PPG makes a 3 step clean, wipe, and prep system. it's somewhat $$$ but works great on TPO plastic. PPG also makes a alcohol based plastic cleaner. DX103. i think it's only sold by the gallon so it's somewhat $$ also.
perception is 90% of reality
[Re: Mr T2U]
#3208464
01/27/24 12:00 PM
01/27/24 12:00 PM
Mr T2U
plastic needs to be CLEAN before painting. i found using white wall cleaner and a gray scotch brite cleans it really good. make sure you completely rinse off the soap before painting. you might try wiping it down with rubbing alcohol works great if on a budget. PPG makes a 3 step clean, wipe, and prep system. it's somewhat $$$ but works great on TPO plastic. PPG also makes a alcohol based plastic cleaner. DX103. i think it's only sold by the gallon so it's somewhat $$ also. i re read and will clarify a bit. WASH / scrub down part with WW cleaner then rinse. for FINAL prep before painting use alcohol inetead of wax and grease remover.
