BB engine brackets #3208147
01/25/24 06:59 PM
01/25/24 06:59 PM
AndyF Offline OP
AndyF  Offline OP
I found this set of brackets in a box that I was going thru. I know they fit a big block but I'm unsure of the years. Are these just regular brackets from late 60's to early 70's? B and E body?
Re: BB engine brackets [Re: AndyF] #3208150
01/25/24 07:19 PM
01/25/24 07:19 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Not sure of all the years, but for sure ‘68-70 B Body big block. Identical to my BB ‘68 Roadrunner.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: BB engine brackets [Re: 68LAR] #3208173
01/25/24 08:33 PM
01/25/24 08:33 PM
AndyF Offline OP
AndyF  Offline OP
Thanks. I'm thinking they stayed the same until they switched to the spool mounts.
Re: BB engine brackets [Re: AndyF] #3208207
01/26/24 01:19 AM
01/26/24 01:19 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I'm thinking 66 up to 70 for sure...possibly all the way to 72 for a B body...
Maybe 70-74 for an E body... twocents
...FAFO...
Re: BB engine brackets [Re: skicker] #3208209
01/26/24 01:48 AM
01/26/24 01:48 AM
IMGTX Offline
IMGTX  Offline
I agree.
Re: BB engine brackets [Re: AndyF] #3208293
01/26/24 01:48 PM
01/26/24 01:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
They did .
That said ... there is a different left side bracket for the earlier C body that was also used on 383 powered A bodies , it connects to the top front ear and wraps around the front of the block , not all blocks have the cast in nubs and not all nubs were machined for use. The 440 A bodies came with a modified version of the 383 mount.
Re: BB engine brackets [Re: JohnRR] #3208335
01/26/24 05:20 PM
01/26/24 05:20 PM
AndyF Offline OP
AndyF  Offline OP
Yep, I used one of the C body/A body type of mount in my '65 Coronet. I had to build custom mounts for it since the engine is not in the stock location.
