1969 Roadrunner 4X4 #3208023
01/25/24 07:58 AM
01/25/24 07:58 AM
Detroit, MI
FC7AARcuda Offline OP
Detroit, MI
Found this on Facebook. Too bad they ruined a 4-speed air-grabber Roadrunner
Facebook link
Re: 1969 Roadrunner 4X4 [Re: FC7AARcuda] #3208024
01/25/24 08:00 AM
01/25/24 08:00 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
The next time someone does a good job building a car into a 4x4 will be the first time someone does a good job building a car into a 4x4.
Earning every penny of that moderator paycheck.
DBAP
Re: 1969 Roadrunner 4X4 [Re: not_a_charger] #3208054
01/25/24 11:17 AM
01/25/24 11:17 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Not exactly well-executed, to put it politely.
I have seen a couple cars done up into 4x4s that were pretty nice, but that's over a span of...I guess 50 years...
Most memorable was one I saw in Central CA in the '90s: an early-'80s BMW 6-series, of all things !
It appeared well-done enough that only its ride height - maybe 4" above normal - tipped us off.
Re: 1969 Roadrunner 4X4 [Re: not_a_charger] #3208120
01/25/24 03:30 PM
01/25/24 03:30 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
This RR popped up on my feed yesterday, kinda like a car wreck, you can't help but look...
There was a late-70's Corvette dropped onto a Bronco (YES, Bronco, with a 302) frame for sale for a couple grand probably 5 years ago. Pretty sure it was built by a guy learning how to weld when he was drunk, pure hack job. I joked with my wife that we should buy it just to go to all of the "Corvette ONLY" shows and events just to see the TACOs (Typical A$^@(!e Corvette Owners) heads explode. This might be the Corvette guy's way to get into a MOPAR show...
Re: 1969 Roadrunner 4X4 [Re: FC7AARcuda] #3208175
01/25/24 08:41 PM
01/25/24 08:41 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
At least they didn't cut up the wheel-wells.
It seems like every converted "non-factory option" 4X4 has the ugly tires sting out three feet from the body. puke
My Monster are real!
Living within your means makes life pretty easy.
Re: 1969 Roadrunner 4X4 [Re: not_a_charger] #3208189
01/25/24 10:21 PM
01/25/24 10:21 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
laugh2 nicely done!
Plymouth Makes It!
Re: 1969 Roadrunner 4X4 [Re: RoadRunnerLuva] #3208198
01/25/24 11:11 PM
01/25/24 11:11 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: 1969 Roadrunner 4X4 [Re: TJP] #3208279
01/26/24 12:45 PM
01/26/24 12:45 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
equally as good as a photographer as well
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 1969 Roadrunner 4X4 [Re: FC7AARcuda] #3208443
01/27/24 09:54 AM
01/27/24 09:54 AM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
I might have throw up a little in the back of my throat.
