Re: Trailer tires
[Re: SomeCarGuy]
#3208102
01/25/24 01:52 PM
01/25/24 01:52 PM
Posts: 2,113 Byron, NY
W.I.N. Racing
Byron, NY
Here's my As other have said don't cheep out. I have an Enclosed (15,600lbs gross) that came with 225/85R15 E Good Year Marathons from the factory. Every 2 years a couple of them needed replacing due to belt failure. I switched to a 235/85R16 E Good Year Marathon and have not had a Belt failure since. Side wall deflection is typically the root cause for trailer tire failure. The E rated 16" has more belts and consequently a higher load rating and If I recall correctly they are (were) less expensive than the 15". My Big trailer (21600 Gross) has 235/85R16 Maxon 10ply (from the factory) and so far so good on wear and reliability. Point being more tire (load capacity) is cheaper in the long run.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Trailer tires
[Re: gtx6970]
#3208183
01/25/24 09:31 PM
01/25/24 09:31 PM
Posts: 3,190 Md.
carnut68
Md.
I have read that Air Stream Travel trailers are putting Michelin LT truck tires on new trailers. The Defender AT/2. Wonder how they would hold up on a car hauler?
America First!
Re: Trailer tires
[Re: carnut68]
#3208190
01/25/24 10:28 PM
01/25/24 10:28 PM
Posts: 43,555 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I have read that Air Stream Travel trailers are putting Michelin LT truck tires on new trailers. The Defender AT/2. Wonder how they would hold up on a car hauler? LT tires are illegal on trailers in some states, but of course unless you are going through scales I doubt anyone would care. Now if you had an accident, that may be enough to not get paid from your insurance company...
JB Rhinehart, Realist
A-Body's RULE!
Re: Trailer tires
[Re: Cab_Burge]
#3208281
01/26/24 01:07 PM
01/26/24 01:07 PM
Posts: 21,439 It's a dry heat
gtx6970
It's a dry heat
What size axles and how many lug bolts wheels does our trailer have on it. Is it enclosed or an open trailer? 5 lug , 15inch wheels , dual 3500 pd axles , 20 ft enclosed trailer
Re: Trailer tires
[Re: topside]
#3208296
01/26/24 01:58 PM
01/26/24 01:58 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
Goodyear Endurance on all three of my trailers. One set is 8 years old and still hanging in there. And out here in the desert that's saying something.
Re: Trailer tires
[Re: Al_Alguire]
#3209022
01/29/24 03:54 PM
01/29/24 03:54 PM
Posts: 13,595 md
mopars4ever
md
Goodyear Endurance on all three of my trailers. One set is 8 years old and still hanging in there. And out here in the desert that's saying something. Good to hear the feedback. Probably will be my next set.
Re: Trailer tires
[Re: Cab_Burge]
#3209227
01/30/24 02:58 PM
01/30/24 02:58 PM
Posts: 2,297 NE Ohio
DoubleD
NE Ohio
I went with the newly designed HanKook Vantra E-rated tires(10Ply) ST225/75R15 for my 24' Bravo enclosed trailer - so far it tows much better with these tires than the cheap D-rated tires it came with from the factory - Next trailer will be 16" rims
Re: Trailer tires
[Re: mopars4ever]
#3209337
01/30/24 09:38 PM
01/30/24 09:38 PM
Posts: 643 southern conn
1969gtx
southern conn
Goodyear Endurance trailer tire are the best I have been using them for a few years now I'm wearing them out with no blow outs before Endurance's 2 or 3 blow outs a year.
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
