Re: Old school 509 purple shaft cam specs. [Re: cudaman1969] #3207030
01/21/24 10:49 PM
01/21/24 10:49 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
Originally Posted by cudaman1969
Originally Posted by RoadRunnerLuva
Back in the late '80's...I had the "677" MP cam in my 440 powered '69 300 'vert.
Stock block/heads, just a three angle valve job, and fresh valve train. 10.1 comp. and headers.
We used a reconditioned CH4B intake, with a Holley 650. Engine ran out of steam at 4,500ish RPM.
A few months later, we swapped out to the .509 cam, installed at .104 degrees, and a new 3310 750 Holley.
What a huge night and day difference the way that car ran. With that combo (and a 3.91 sure grip)...
It ran 14 teens -low 20's @99mph in the quarter mile..on street tires and full 2-1/2" exhaust.
Won a few street races as well, including against a new (at the time) turbo T type Buick Regal.
Mr. Regal was shocked and saddened that a "big boat" had kicked his ass! laugh2
You changed at least two things, the cam and the carb. Any idea what made the biggest difference?
I would say they both made a big difference, but that .509 cam was perfect, for that combo.
If that same combo was in an A body, it would have been a high 11 second car...IMO.
My Duster 383 with that cam carb combo went 11.65 118, st Hemi vert
Forgot to mention, converter in my 300 was a Turbo Action unit... I don't remember the part number, but it was a 3000-3500 stall iirc.
Trans was all stock except for the converter, and a T/A mild shift kit.
Plymouth Makes It!
Re: Old school 509 purple shaft cam specs. [Re: cudaman1969] #3207032
01/21/24 10:56 PM
01/21/24 10:56 PM
Land 'O Lakes
Land 'O Lakes
That's awesome! You're Duster went mid 11's with that combo! Was it a street car also?
Plymouth Makes It!
Re: Old school 509 purple shaft cam specs. [Re: RoadRunnerLuva] #3207033
01/21/24 10:57 PM
01/21/24 10:57 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Never ran the 509 cam, though I did run the old Street Hemi grind in my 64 300, 750 carb, 4.10 gears and a stick car too. I miss that car, many a 454SS and Iroc Z got spanked with it.
Re: Old school 509 purple shaft cam specs. [Re: Sniper] #3207034
01/21/24 11:02 PM
01/21/24 11:02 PM
Land 'O Lakes
Land 'O Lakes
How much did your '64 300 weigh? I always got a kick out of people's reactions
when they got spanked by a big C body! up
Plymouth Makes It!
Re: Old school 509 purple shaft cam specs. [Re: RoadRunnerLuva] #3207037
01/21/24 11:20 PM
01/21/24 11:20 PM
nowhere
nowhere
No idea, I forget those details, it was the late 80's.
I like the idea of a hotrod 300, looking at an SRT8 300. If I could easily swap in a stick I might get it.
Re: Old school 509 purple shaft cam specs. [Re: Sniper] #3207120
01/22/24 10:50 AM
01/22/24 10:50 AM
an8sec70cuda Offline
I've always installed the 509/292 108 LSA cam 4 degrees advanced. 104° ICL. That cam works great in my opinion, even though it's an old cam that everyone likes to crap on. Some of the old stuff still has it's place. twocents
I had a 10:1 440 w/ stock 906 heads, just a 3 angle valve job, 509/292 cam, Performer rpm intake, 830 holley, headers, 3500 stall, 3.91 gear, in a 3700 lb cuda. Ran 11.80s at 112 mph on pump gas. Drove it everywhere.
Switched to some home ported 915s and it ran 11.40s at 117 mph.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Old school 509 purple shaft cam specs. [Re: RoadRunnerLuva] #3207276
01/22/24 05:51 PM
01/22/24 05:51 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
[quote=Sniper][quote=RoadRunnerLuva]Back in the late '80's...I had the "677" MP cam in my 440 powered '69 300 'vert.
No street car but should have. .030 over TRW slugs, stock 915 heads, .550 triple springs adj rockers, Torker intake 3310 Holly with 2” spacer, Hooker fender wells with 12” extension, stock 68 street Hemi vert, 4.88 8-3/4, 10.5/ 29 M&H slick S/S springs moved into frame, Carter pump. All steel car one van seat, heater removed, hoop with side bars. Best driving race car I ever had, stopped on a dime, KH brakes up front. 1981.
I put the engine in a race 68 Dart (big tires and 4000 vert) went 7.01 in eight, about a tenth and a half slower that his built 440. We ran mostly 1/8 mile
Re: Old school 509 purple shaft cam specs. [Re: cudaman1969] #3208512
01/27/24 02:25 PM
01/27/24 02:25 PM
Findlay
Ramman Offline OP
Ramman  Offline OP
Findlay
Since i don't see it listed and it wasn't widely discussed, at least in my cicle in the late 70's , what lobe seperation angle is this cam? All i find is a installed centerline of 108°. When I plug it into a camspec calculator, I have to enter a load separation angle of a 106° to get 38° overlap. Even though the box is 76°.[align:left][/align]
Re: Old school 509 purple shaft cam specs. [Re: Ramman] #3208549
01/27/24 04:10 PM
01/27/24 04:10 PM
CA
crackedback Offline
crackedback  Offline
CA
Centerline and LSA are the same on those 508-509 cams, IIRC. If it says 108, then use 108 for both. Then choose where to move the centerline when installing.
overlap comes up spot on in the wallace calculator 292 108 lsa
Re: Old school 509 purple shaft cam specs. [Re: RoadRunnerLuva] #3208928
01/29/24 12:37 AM
01/29/24 12:37 AM
I bought one of those cams from Bob Mazzolini back in the day, when I started installing and degreeing it wasn't that cam, it was the 533 solid lifter cam in the 509 cam box rant down puke
Mopar never mark those D.C. cams in any way for us, the consumers and racers, to I.D. them on the bench before installing them down puke
Same thing later on buying a 590 solid lifer cam with lifters from him, it was a 557 cam in the 590 box, I called D.C. on that cam and was told that Mopar had switch vendors and they knew those new cams didn't have the proper lobe lift but they insisted they were still great cams ARHHHH down rant puke I took that one back and ended up having to argue with Bob to take it back and refund my money back to me, that was the last Mopar D.C. cam I bought. shruggy
Re: Old school 509 purple shaft cam specs. [Re: Cab_Burge] #3209148
01/30/24 09:28 AM
01/30/24 09:28 AM
Findlay
Ramman Offline OP
Ramman  Offline OP
Findlay
Thanks group.
This forum is the best!!
Re: Old school 509 purple shaft cam specs. [Re: Ramman] #3210157
02/02/24 10:51 PM
02/02/24 10:51 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
If you install that cam, and measure it, it likely will not have/match the advertised 0.050” duration. Probably closer to 242.
Re: Old school 509 purple shaft cam specs. [Re: BSB67] #3211103
02/06/24 01:31 PM
02/06/24 01:31 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
A 292 cam from the 70’s should have been a Racer Brown SSH-44.
I ran one of those for a while…….. it was a good cam.
My actual measurements had it as about 304@.006 and 244@.050.
Re: Old school 509 purple shaft cam specs. [Re: fast68plymouth] #3211140
02/06/24 03:06 PM
02/06/24 03:06 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
That .533 cam has slightly more duration than a .590 solid.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Old school 509 purple shaft cam specs. [Re: deaks] #3211185
02/06/24 04:47 PM
02/06/24 04:47 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
As Fast said, back in the early Direct Connection days thr Racer Brown SSH-44 was the 509 purple shaft and I believe (don't quote me) the SSH-25 was the 484 cam with about 241 @.050.
In the early DC Engine manual they referred to the 509 as the 4 speed bracket cam and the 484 as the Automatic Cam
the 484 was a great 440 cam and the 509 got used in a lot of tight converter cars but still worked pretty decently.
The typical hot 440 set up for the Day was the '67 closed chamber 915 heads shaved at least .040" with a 509 and a TM-7 /4779 (750 DP) and a 340 or 383 (10 3/4") 'Road Runner' Converter. We used to put the cam in +4 rather than straight up. With 3.91's or 4.10's you could bust almost anything pretty consistently...Until the W2's started becoming available.
WIZE
In Car:
Re: Old school 509 purple shaft cam specs. [Re: Streetwize] #3211230
02/06/24 07:13 PM
02/06/24 07:13 PM
A727Tflite Offline
A727Tflite  Offline
Before there was a Direct Connection, Chrysler carried the SSH 25 and 44. Later they released the Purple Shaft series cams, two offerings with specs close to the Racer Brown cams.
The early Purple Shaft cams were made by Camcraft and were excellent cams, circa mid 70’s.
Not sure who made them later.
Re: Old school 509 purple shaft cam specs. [Re: A727Tflite] #3211234
02/06/24 07:28 PM
02/06/24 07:28 PM
So. Burlington, Vt.
So. Burlington, Vt.
The engine manual shows the Mopar part number for the SSH-44 as P3690812.
I don’t know how far back that number dates it.
Re: Old school 509 purple shaft cam specs. [Re: fast68plymouth] #3211287
02/06/24 08:52 PM
02/06/24 08:52 PM
A727Tflite Offline
A727Tflite  Offline
The first use of the SSH series cams was the -25 and was for the Hemi, around 1967/68, part number was 2836158. I’m thinking the “P” prefix started early 1970’s.
In fact many of the earlier non - P numbers were simply carried over by adding the P.
Re: Old school 509 purple shaft cam specs. [Re: A727Tflite] #3211413
02/07/24 10:25 AM
02/07/24 10:25 AM
moparx Offline
moparx  Offline
i have used the SSH-25 cam in 383's, and at 4* advance installed, that works great !
beer
Re: Old school 509 purple shaft cam specs. [Re: fast68plymouth] #3211471
02/07/24 12:58 PM
02/07/24 12:58 PM
So. Burlington, Vt.
So. Burlington, Vt.
The engine manual mentions that the new replacement for the street hemi cam came out in 1983.
That’s cam number- P4286631.
The 248, 260, 272 cams are all slightly higher part numbers, so my take on that is they were released around the same time.
The MP 484 and 509 cams are P412 numbers, so they should be from a bit earlier.
