Old school 509 purple shaft cam specs. #3121651
02/15/23 01:17 AM
02/15/23 01:17 AM
Findlay
Ramman Offline OP
Ramman  Offline OP
Findlay
I have an old (1980) single bolt, RB, purple shaft .509 lift 292 duration, direct connection, hyd. flat tappet cam. I've since lost the cam card for valve timing events and lobe separation. I'd heard they redesigned this grind some years later. Does anyone have an old direct connection catalog or complete specs. for this cam?
Thanks group!
Re: Old school 509 purple shaft cam specs. [Re: Ramman] #3121660
02/15/23 06:07 AM
02/15/23 06:07 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Does this help?
Re: Old school 509 purple shaft cam specs. [Re: Ramman] #3121724
02/15/23 01:03 PM
02/15/23 01:03 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Cam card? Not from Mopar.
In the words of Muddy Waters:
“You can’t spend what you ain’t got, and you can’t lose what you ain’t never had”
Victory library will be your best resource and even that is debatable on certain grinds.
Rich H.
Esse Quam Videri
Re: Old school 509 purple shaft cam specs. [Re: ZIPPY] #3121738
02/15/23 02:03 PM
02/15/23 02:03 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Ain't that right, wink When I read this post I went and looked at a new still in the box P4120235 484" lift camshaft and lifters and NO cam card. All you get is a label on the box with the specs, lucky I still have the original box. The box "was" pretty though, I guess that's where they spent the money instead of on the "cam card"? wink grin
Re: Old school 509 purple shaft cam specs. [Re: Ramman] #3121793
02/15/23 05:01 PM
02/15/23 05:01 PM
Central NC
gch Online content
gch  Online Content
Central NC
Should have been ground on a 108 so I would imagine installed at 104 or even 102 depending on compression,etc.
Re: Old school 509 purple shaft cam specs. [Re: gch] #3121877
02/15/23 09:42 PM
02/15/23 09:42 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
DC 509 is part number P4120237
Its listed on A12's chart, towards the bottom.
Re: Old school 509 purple shaft cam specs. [Re: A12] #3206301
01/19/24 06:30 PM
01/19/24 06:30 PM
Findlay
Ramman Offline OP
Ramman  Offline OP
Findlay
They list a centerline of 108°. Is that suggested installed centerline or lobe separation angle. If installed centerline, what lobe separation angle was ground into this cam? Thanks forum.
Re: Old school 509 purple shaft cam specs. [Re: Ramman] #3206417
01/20/24 03:11 AM
01/20/24 03:11 AM
All of those early cams were made by the cheapest, low bid sub contractors that Mopar could hire down puke
I can't tell you how many D.C. cams i bought and returned to get a good one, I stop using them due to the lack of quality.
If you decide to try and use one make sure and degree it on at least two cylinders, I like to check both #1 and #6 so I don't have the change the degree wheel for T.D.C. while checking those lobes wrench scope up
Re: Old school 509 purple shaft cam specs. [Re: Ramman] #3206451
01/20/24 11:06 AM
01/20/24 11:06 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
108 is the lobe separation angle. If you install it at 108 intake centerline it will have split overlap. Usually these should instead be installed advanced a few degrees. 103 or 104 intake centerline is what I would go for.
Re: Old school 509 purple shaft cam specs. [Re: GomangoCuda] #3206533
01/20/24 03:17 PM
01/20/24 03:17 PM
CA
crackedback Offline
crackedback  Offline
CA
If that is the 114 LSA, use it as a doorstop. JMO.
I've installed those 108 cams as far ahead as 100 depending on engine static compression. The tend to like being installed ahead.
Good luck with it.
Re: Old school 509 purple shaft cam specs. [Re: crackedback] #3206557
01/20/24 04:08 PM
01/20/24 04:08 PM
A727Tflite Offline
A727Tflite  Offline
Seems some people are confused between the meaning of LSA and Centerline.
You can change the installed centerline - you can’t change the LSA.
I doubt any manufacturer advises the user to install the cam using LSA.
Re: Old school 509 purple shaft cam specs. [Re: A727Tflite] #3206631
01/20/24 07:15 PM
01/20/24 07:15 PM
GomangoCuda Offline
GomangoCuda  Offline
The only confusion I see in this thread is Larry Sheppards 50 year old chart. Centerline is not ground into the cam, it is determined at assembly. The column labeled Centerline should be labeled Lobe Separation Angle and then he probably could have added another column labeled Recommended Installed Intake Centerline.
Quote
True but if the cam has symmetrical lobes as I am sure all of these cams do then if installed Straight Up the ICL will be the same as the LSA. In practice most people will install these cams advanced at least 4deg. resulting in an ICL less than the LSA.
At the risk of complicating this more, the Intake closing event is what affects cylinder pressure. When Harrold Brookshire was grinding NASCAR cams he didn't even tell the teams ICL and LSA. Probably because they are not really relevant with nonsymmetrical lobes.
Re: Old school 509 purple shaft cam specs. [Re: GomangoCuda] #3206636
01/20/24 07:31 PM
01/20/24 07:31 PM
A727Tflite Offline
A727Tflite  Offline
Quote
Agreed, should have had two columns, Design Centerline and LSA. Both probably ignored by the vast majority of guys, they stabbed the cam and lined up the dots and hoped for the best. The more educamated guys know what to do.
As for the NASCAR guys, I bet they ran a ton of dyno sessions and knew exactly what the engines wanted for LSA and ICL.
Re: Old school 509 purple shaft cam specs. [Re: A727Tflite] #3206678
01/20/24 11:00 PM
01/20/24 11:00 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
That # 237 worked pretty well in our dirt track car on the long straight 1/2 mile track back in the 80s.
Re: Old school 509 purple shaft cam specs. [Re: A12] #3206959
01/21/24 06:59 PM
01/21/24 06:59 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
The first 2 cams on A12's list appear to be the same cams. Why 2 different part numbers?
Re: Old school 509 purple shaft cam specs. [Re: elmor353] #3206969
01/21/24 07:33 PM
01/21/24 07:33 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I think the taper was different on the 6-pack cam.
Re: Old school 509 purple shaft cam specs. [Re: bobby66] #3207019
01/21/24 09:54 PM
01/21/24 09:54 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
Back in the late '80's...I had the "677" MP cam in my 440 powered '69 300 'vert.
Stock block/heads, just a three angle valve job, and fresh valve train. 10.1 comp. and headers.
We used a reconditioned CH4B intake, with a Holley 650. Engine ran out of steam at 4,500ish RPM.
A few months later, we swapped out to the .509 cam, installed it at 104 degrees. Changed to a new 3310 750 Holley.
What a HUGE night and day difference the way that car ran. With that combo (and a 8.75" 3.91 sure grip)...
It ran 14 teens -low 20's @99mph in the quarter mile..on L60-15 street tires and full 2-1/2" exhaust.
Won a few street races as well, including against a new (at the time) turbo T type Buick Regal.
Mr. Regal was shocked and saddened that a 4,500 lb. "big boat" had kicked his ass! laugh2
Plymouth Makes It!
Re: Old school 509 purple shaft cam specs. [Re: RoadRunnerLuva] #3207022
01/21/24 10:01 PM
01/21/24 10:01 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
A few months later, we swapped out to the .509 cam, installed at .104 degrees, and a new 3310 750 Holley.
What a huge night and day difference the way that car ran. With that combo (and a 3.91 sure grip)...
It ran 14 teens -low 20's @99mph in the quarter mile..on street tires and full 2-1/2" exhaust.
Mr. Regal was shocked and saddened that a "big boat" had kicked his ass! laugh2
You changed at least two things, the cam and the carb. Any idea what made the biggest difference?
Re: Old school 509 purple shaft cam specs. [Re: Sniper] #3207025
01/21/24 10:15 PM
01/21/24 10:15 PM
Land 'O Lakes
Land 'O Lakes
I would say they both made a big difference, but that .509 cam was perfect, for that combo.
If that same combo was in an A body, it would have been a high 11 second car...IMO.
Plymouth Makes It!
Re: Old school 509 purple shaft cam specs. [Re: RoadRunnerLuva] #3207027
01/21/24 10:42 PM
01/21/24 10:42 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My Duster 383 with that cam carb combo went 11.65 118, st Hemi vert
