904 hardened shafts available #3204296
01/13/24 11:49 AM
01/13/24 11:49 AM
Minnesota, USA
humpty Offline OP
humpty  Offline OP
Minnesota, USA
Darren at Pro Trans reached out this week and has early and late model 904 billet input and output shafts in stock. Get them while they’re hot!
https://www.facebook.com/profile.php/?id=100063654516407
Re: 904 hardened shafts available [Re: humpty] #3204305
01/13/24 12:38 PM
01/13/24 12:38 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I don't see anything on their Facebook page that you posted or on their website.
Any other links?
Thanks!
Re: 904 hardened shafts available [Re: 340Cuda] #3204313
01/13/24 01:05 PM
01/13/24 01:05 PM
Minnesota, USA
humpty Offline OP
humpty  Offline OP
Minnesota, USA
Give Darren a call at 254-749-5689 or message him on FB by hitting the Message Us button on the top of the page.
Re: 904 hardened shafts available [Re: humpty] #3204924
01/15/24 11:52 AM
01/15/24 11:52 AM
Northport, al.
tvt59 Offline
tvt59  Offline
Northport, al.
I got mine through Keith Long at 272 specialist
Nothing worth anything comes easy. It is always harder to do the right thing. My Grandfather
Re: 904 hardened shafts available [Re: tvt59] #3205503
01/17/24 09:43 AM
01/17/24 09:43 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
There was a bit of a dry spell with the output shafts. I was fortunate to find a fellow mopar racer last summer with an A&A shaft to mate to the input that was available. Went over 100 passes on the stock shafts in the other trans.
Re: 904 hardened shafts available [Re: J_BODY] #3205508
01/17/24 10:10 AM
01/17/24 10:10 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What’s more critical input or output?
Re: 904 hardened shafts available [Re: cudaman1969] #3205807
01/18/24 01:21 AM
01/18/24 01:21 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
In my case with the A&A route your answer is both….. the shafts mate to each other.
Re: 904 hardened shafts available [Re: J_BODY] #3207260
01/22/24 05:25 PM
01/22/24 05:25 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
The input for sure if you look how small it is you will see why they break ive broken 2 inputs with the stock shaft now have the A&A input and a cryo rear shaft
