Re: Block Raffle - BME 4.500" bore block
[Re: Cab_Burge]
#3204249
01/13/24 06:11 AM
01/13/24 06:11 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
[quote=). Putting this out here to see if there is any interest. , but I'm thinking 200 spots, $100.00 per spot. Some of the proceeds are going toward a missing person search that I'm involved with. Whatever is left I’ll put toward another block. edit:. Mike 200 x $100.00=$20,000.00 I paid $3300.00 for my Bulldog Iron block with all the machine work done several years back, with the shipping to central Oregon. $6300.00 ( I think) for my K.B. aluminum wedge 4.500 bore block finished machined with shipping also seven years ago before KB moved out of Canada, not sure about the exchange rate on the U.S. Dollar to Canadien dollars were back then I paid in U.S. currency [/quote] Did you not read what the extra money is going to
[Re: pittsburghracer]
#3204405
01/13/24 05:24 PM
01/13/24 05:24 PM
Posts: 43,326 Bend,OR USA
Cab_Burge
I saw that, I use to live 45 miles to the east of that area and know the hills and mountains around there well. I think that young man is running away from something, not lost in the hills or mountains BTW, there are many very good volunteer search and rescue groups threw out SO CA, many, many as well as several, more than i can remember now, government funded and ran search and rescue agencies : work: I hope he didn't commit suicide
[Re: Cab_Burge]
#3204423
01/13/24 06:59 PM
01/13/24 06:59 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I saw that, I use to live 45 miles to the east of that area and know the hills and mountains around there well. I think that young man is running away from something, not lost in the hills or mountains BTW, there are many very good volunteer search and rescue groups threw out SO CA, many, many as well as several, more than i can remember now, government funded and ran search and rescue agencies : work: I hope he didn't commit suicide Wholly crap Cab give it a break. Cheese n rice
#3205137
01/16/24 05:45 AM
01/16/24 05:45 AM
Posts: 1,647 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I would be in for a chance.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Block Raffle / Fundraiser
[Re: 6PKRTSE]
#3205674
01/17/24 04:24 PM
01/17/24 04:24 PM
Posts: 96 Carson City
Mike@440Source
Carson City
Outstanding Getting ready to post rules now, with a change in description. Mike
Re: Block Raffle/Fundraiser- BME 4.500" bore block
[Re: Mike@440Source]
#3205704
01/17/24 05:50 PM
01/17/24 05:50 PM
Mike@440Source
Carson City
Ok, here we go. Verbiage corrected to fundraiser, since that’s what this is. Rules:
1. Item being offered is a Bill Mitchell Products 4.500” bore aluminum RB Chrysler engine block, part number 088555. Item offered as-is from the manufacturer and requires final machining to set clearances, including lifter bores, cylinder bores, and piston-to-deck height. Block includes a hardware kit from BMP, which supplies screw-in core plugs, dowel pins, and oil restrictors. 2. Item being offered is personal property of the seller and is not affiliated with, nor offered by 440 Source, Inc. Item is intended for competition use without warranty, expressed or implied. End user of the item being offered acknowledges that safe and lawful use is his/her responsibility and holds seller and member(s) and managing partners of the Moparts bulletin board and its online community blameless in the event of an accident. Please understand what you are attempting to win as I’ve provided the part number and accurate description. No Returns, no exceptions. 3. Fundraiser is being held with permission of Moparts. This is not a retail sale. If you don’t like the item or the terms set forth, don’t buy in. It’s that simple. 4. Limitations, Shipping, and Duties: Item will be palletized. I can assist you with shipping arrangements anywhere in the Continental US. Alternatively, you may handle these arrangements on your own. Hawaii and Alaska residents, please arrange a shipping method. Australia, Canada, and residents of other territories outside the Continental US, please pick a US freight broker and provide contact information at the email address below. Customs / duties are the responsibility of the recipient. No, I will not falsify customs documents for you. No exceptions. 5. Available spots: 200 spots offered, $100.00 US per spot. You can buy 1, or you can buy as many as you want to. Draw will happen once all 200 spots have been spoken for. Cancellation and refund will happen if sufficient interest is lacking to cover the replacement cost of the item. Void where prohibited.
1st draw: Engine block 2nd draw: $750.00 3rd draw $250.00
6. IMPORTANT: Reply directly to this thread with the spot number you want, then email me at MikesBlueCollar@gmail.com with the spot number(s)you picked. Once I respond with confirmation, payment may be made using the following methods:
Venmo: MBarbarigos775 PayPal: @mbarbarigos CashApp $MichaelBarbarigos775
A portion of fundraiser proceeds will be used to fund the upcoming search effort for Aiden Clune in April 2024. Thank you all for your support, and good luck. I 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. 92. 93. 94. 95. 96. 97. 98. 99. 100. 101. 102. 103. 104. 105. 106. 107. 108. 109. 110. 111. 112. 113. 114. 115. 116. 117. 118. 119. 120. 121. 122. 123. 124. 125. 126. 127. 128. 129. 130. 131. 132. 133. 134. 135. 136. 137. 138. 139. 140. 141. 142. 143. 144. 145. 146. 147. 148. 149. 150. 151. 152. 153. 154. 155. 156. 157. 158. 159. 160. 161. 162. 163. 164. 165. 166. 167. 168. 169. 170. 171. 172. 173. 174. 175. 176. 177. 178. 179. 180. 181. 182. 183. 184. 185. 186. 187. 188. 189. 190. 191. 192. 193. 194. 195. 196. 197. 198. 199. 200.
#3205846
01/18/24 11:32 AM
01/18/24 11:32 AM
Dartsport540
Ringtown, Pa.
Can you take Zelle as a payment. My bank uses Zelle.
[Re: Dartsport540]
#3205942
01/18/24 03:47 PM
01/18/24 03:47 PM
Posts: 19,659 north of coder
moparx
rats ! i don't have any of the payment plans mentioned ! the only option open to me is a Postal M.O. dangitall !
#3206101
01/19/24 07:03 AM
01/19/24 07:03 AM
Posts: 4 Finland
MRE
Finland
Hi no.99 if available or any that is available thanks Mike
3250lbs,477cid N/A,FullExhaust,DOT tires 8,75 at 143mph
[Re: MRE]
#3206115
01/19/24 09:07 AM
01/19/24 09:07 AM
Posts: 668 IL
Dart451
IL
[Re: Dart451]
#3206176
01/19/24 01:00 PM
01/19/24 01:00 PM
Posts: 3,024 NY
B1duster
NY
