Drive shaft Question - '70 roadrunner
#3203717
01/10/24 10:10 PM
01/10/24 10:10 PM
Posts: 1,228 Maple Valley, WA
70mopes
Maple Valley, WA
My 70 roadrunner (383 auto) is missing its driveshaft. It is supposed to be 51.5 inches in length.
I have a spare 3.25 dia driveshaft which is a bit longer. It has small ujoints on front and rear (7260 diff yoke). My application uses a 7290 diff yoke.
I was going to shorten the driveshaft but have a couple questions about doing it
Did the 70 roadrunner use the big ujoint on the front of the shaft as well as the rear?
Would a good driveline shop be able to replace the ends with flanges that utilize the larger (7290) ujoints?
Re: Drive shaft Question - '70 roadrunner
[Re: 70mopes]
#3203765
01/11/24 06:49 AM
01/11/24 06:49 AM
Posts: 5,812 ohio
ruderunner
ohio
Yes, 7290 on both ends
Yes shops can change ends. But at that point a whole new shaft might be the same price.
Alternatively, get a conversion joint for the axle end.
Angry white pureblood male
[Re: 70mopes]
#3203816
01/11/24 01:37 PM
01/11/24 01:37 PM
Posts: 5,812 ohio
ruderunner
ohio
I've been running the small joints for almost 30 years on my car. No failures.
I don't have huge power or slicks
[Re: 70mopes]
#3203823
01/11/24 02:18 PM
01/11/24 02:18 PM
Posts: 43,162 Bend,OR USA
Cab_Burge
[quote=70mopes Mechanically, does it need 7290 ends or is running a 7260 up front and a 7260/7290 on axle a sound change? Any dis-advantage to doing so? [/quote] I've ran many mix u joint drive shafts in some of my old drag race cars that had 8 3/4 in them with the small 7260 U joint pinion yoke on them, same thing the other way with using a conversion U joint on a car that had the 7290 U joints on both ends driveshaft that we swap a third member into it that had the smaller 7260 pinion yoke on it, swapping the U joint was usually easier, faster and cheaper than replacing the pinion yoke to the 7290 type, especially on the "489 carriers" buy the offroad H.D. solid U joints, not the stock OEM replacement type
[Re: moparx]
#3204206
01/12/24 10:26 PM
01/12/24 10:26 PM
Posts: 5,812 ohio
ruderunner
ohio
Depends on use. I've been running Precision joints since 97, grease em up and no problems
Damn near 30 years and they haven't been apart.
If he's building a drag car then sure go solid.
