Page 3 of 3 1 2 3
Re: Rust on tti coated headers [Re: CCPcoatings.com] #3202633
01/06/24 04:07 AM
01/06/24 04:07 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Originally Posted by CCPcoatings.com
High Temp Ceramics
What about coating stainless steel headers with High Temp Ceramics? Inside and out?
Re: Rust on tti coated headers [Re: jcc] #3202635
01/06/24 04:18 AM
01/06/24 04:18 AM
Detroit, MI
CCPcoatings.com Offline
Detroit, MI
Depends which coatings you're referring to. Polished Ceramic on SS is still going to be limited to the temp restrictions, but it wont weep rust when it fails if you do. High Temp Ceramics on SS will pretty much last forever..... Most modern performance cars i.e. Challenger, Charger, Corvette, Camaro, Mustang, etc use either Kooks, ARH or Stainless Works headers which are all made from SS exclusively.
Originally Posted by jcc
Do anyone have any real world experience how these high temp coatings hold up on SS exhaust tubing?
Re: Rust on tti coated headers [Re: poorboy] #3202637
01/06/24 04:43 AM
01/06/24 04:43 AM
Detroit, MI
Detroit, MI
Coated headers hold up fine if its the right coating for the right temperature. Unfortunately, the most common being polished ceramics aren't right for most applications.
As for stainless headers cracking, that hasn't really been the case in many years. Most modern performance cars and trucks have come with some form of tubular SS manifolds for years without an issue right from the factory. Further, most aftermarket headers for those modern cars and trucks are made out of stainless exclusively. In my 25 years years of coating headers I've only seen a couple cracked pipes and they were usually the result of some outside force. Like used to support a turbo, or in the case of a dragster, the bouncing of the dragster caused the headers to crack under the primaries because they were LONG up-swept headers.
Originally Posted by poorboy
So, does the coatings hold up better then the old age header paint? Do the coated headers hold up better then bare steel headers?
The number of heating and cooling cycles, the temperature range the headers see, the fact they hang down under the chassis without protection, are all things headers have to go through. That has to make it hard for any protective finish to endure.
Stainless steel header tubes get brittle and the tubes tend to stress crack.
The header business has always had long life issues. One really only needs to look at how many cast iron exhaust manifolds have failed over the years, and one might give headers a bit of a break.
Re: Rust on tti coated headers [Re: CCPcoatings.com] #3203000
01/07/24 02:53 PM
01/07/24 02:53 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Here are my TTI's that I had them coat black. This started very quickly
Facts are stubborn things.
Re: Rust on tti coated headers [Re: larrymopar360] #3203005
01/07/24 03:12 PM
01/07/24 03:12 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Which side of the Intracoastal do you live on?
Re: Rust on tti coated headers [Re: jcc] #3203021
01/07/24 04:20 PM
01/07/24 04:20 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I live near east coast. My house is across the Banana River to the west and I'm 12 miles from beach.
Re: Rust on tti coated headers [Re: larrymopar360] #3203023
01/07/24 04:25 PM
01/07/24 04:25 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Don`t think it being near the coast caused the rusted headers. The rest of the under carriage looks pretty rust free.
Re: Rust on tti coated headers [Re: mopars4ever] #3203044
01/07/24 06:15 PM
01/07/24 06:15 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I agree, except for the TR adjusters. I was wondering if moist salt spray combined with repeated temp cycling might be an extra factor multiplied by being near the coast. 12 miles takes that idea off the table. I have a car with black coated headers, which were promoted as being higher temp solutions then the normal silver, in practice they didn't convince me.
Re: Rust on tti coated headers [Re: jcc] #3203107
01/07/24 09:23 PM
01/07/24 09:23 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Yeah tie rod sleeves have plenty of surface rust but then they weren't ceramic coated. I should've painted the sleeves before installing them.
It was a real pain turning my car upside down for these pics!
Re: Rust on tti coated headers [Re: larrymopar360] #3203112
01/07/24 09:49 PM
01/07/24 09:49 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Not as much as it was turning my monitor over. grin
Re: Rust on tti coated headers [Re: larrymopar360] #3203121
01/07/24 11:03 PM
01/07/24 11:03 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
is it possible you got the black "Rust prevention" coating vs. ceramic or other coating? I ask because most of the MFR's will coat their bare headers with crap paint to keep them from rusting. As soon as they see heat the coating is gone. I've often wondered why they don't use a hi temp paint. I would gladly pay 20 or 30.00 more so I didn't have to strip the crap off.
Your comment and pictures make me strongly suspect you got the ""Rust prevention" coating. If not, I'd be calling TTI twocents beer
Re: Rust on tti coated headers [Re: TJP] #3203131
01/07/24 11:44 PM
01/07/24 11:44 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Sooner or later, mild steel headers are going to rust. Quality of the coating only determines how long. Pull them off and send them to be redone is the only thing you can do.
Re: Rust on tti coated headers [Re: CMcAllister] #3203147
01/08/24 07:01 AM
01/08/24 07:01 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Embrace the rust
if it is made “less flakey”
and almost like paint?
That is the idea of COR-TEN steel such as grades ASTM 242 and ASTM 588
https://en.wikipedia.org/wiki/Weathering_steel
sample quote
Disadvantages
Using weathering steel in construction presents several challenges.
Ensuring that weld-points weather at the same rate as the other materials may require special welding techniques or material.
Weathering steel is not rust-proof in itself: if water is allowed to accumulate on the surface of the steel, it will experience a higher corrosion rate, so provision for drainage must be made.
Weathering steel is sensitive to humid subtropical climates, and in such environments it is possible that the protective patina may not stabilize but instead continue to corrode.
For example, the former Omni Coliseum, built in 1972 in Atlanta, never stopped rusting, and eventually large holes appeared in the structure. This was a major factor in the decision to demolish it just 25 years after construction.
The same thing can happen in environments laden with sea salt. Hawaii's Aloha Stadium, built in 1975, is one example of this.[26] Weathering steel's normal surface weathering can also lead to rust stains on nearby surfaces.
end quote
Note the bit about the arc welding rusting faster than the base steel.
I see more and more electrical power line towers made of cor-ten steel than 20 years ago.
I am more a fan of the South African invention: so called 3Cr12 steel,
much less expensive than original 8Ni-18Cr stainless steel
https://www.atlassteel.com/products/3cr12
Re: Rust on tti coated headers [Re: 360view] #3203155
01/08/24 09:04 AM
01/08/24 09:04 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted by 360view
Embrace the rust
sample quote
Disadvantages
end quote
I have a long time associate with Florida Power and Light share with me a few years back they are replacing all their Core-Ten steel HV transmission line towers with galvanized towers. That is literally thousands of miles of towers in Florida due to corrosion failures.
Mostly due to bird droppings it seems. This conversion is easily seen along Highway 27 in Broward County where 4 HV lines run parallel and for the last couple of years the towers have been transitioned out.
BTW, I do like your new TB's up
Re: Rust on tti coated headers [Re: TJP] #3203457
01/09/24 06:07 PM
01/09/24 06:07 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
No I definitely paid for ceramic coating and they even admitted a failure by their sub-contractor and offered to re-coat.
Re: Rust on tti coated headers [Re: jcc] #3203459
01/09/24 06:09 PM
01/09/24 06:09 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
laugh
Page 3 of 3 1 2 3
