Page 1 of 3 1 2 3
632 dyno time #3202610
01/06/24 12:07 AM
01/06/24 12:07 AM
AndyF Offline OP
AndyF  Offline OP
Got the 632 crate engine working on the dyno today. Had to spend half the day taking the wiring harness apart and putting it back together because the customer wants to run dual wide band sensors and the GM harness wasn't designed to do that.
Once we got that wrapped up we decided to do a little shake down run. This thing is a beast. And by beast I mean it is head and shoulders above anything we've ever tested in the last 20 years. We've run 1000+ hp drag engines before but this engine is in another class. First off it is quiet. When we first fired it up it sounded like a passenger car engine. Most 1000 hp engines sound like a grenade inside of a steel drum. This one is super quiet and it is very smooth. But as soon as the dyno operator started a pull we both freaked out. It instantly jumped up to 1000 hp and the dyno operator had to yank the throttle back because it revved so fast it blew right thru our set point. Usually engines take some time to make a pull but this one just instantly went to 1000 hp.
After we shut the engine down we both just sat there and laughed since it was weirdest thing we have ever seen. Anyway, here is the chart. We only had it taking data to 5500 rpm since it was supposed to be a shakedown run. I saw the gauge read 1000 hp at around the 6000 rpm mark but the operator was already pulling the throttle back there. We'll make some full runs tomorrow.
Re: 632 dyno time [Re: AndyF] #3202615
01/06/24 01:14 AM
01/06/24 01:14 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Nice. If you have ever watched Steve Morris make a pull, its over in like 3 seconds. Most of his big N/A motors make 1200-1300hp on his dyno.
Re: 632 dyno time [Re: mopar dave] #3202629
01/06/24 02:54 AM
01/06/24 02:54 AM
Most of the better engine dyno have the RPM per second rate of acceleration options, I like 300 or 600 RPM per second depending on many things in the motors, street pump gas slower, race only faster with a narrowewr RPM band for the pulls on the race motors.
One of the Studka brand engine dyno I use to use was horrible about controlling the engine RPM when you were advancing the throttle to WOT before starting the pulls, I had to learn to advance that throttle SLOWLY before starting the test.
On the DTS and Super Flows dynos that wasn't an issue confused
Re: 632 dyno time [Re: Cab_Burge] #3202658
01/06/24 09:45 AM
01/06/24 09:45 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
It really is an impressive piece. More expensive than some of the other 1000-ish hp crate motors but for that money you’re getting oem levels of engineering and development.
Re: 632 dyno time [Re: Blusmbl] #3202734
01/06/24 02:36 PM
01/06/24 02:36 PM
AndyF Offline OP
AndyF  Offline OP
It is a very, very impressive engine. The fact that it makes over 1000 hp with a hyd roller cam and beehive springs is what is so funny. And a seven qt wet sump oil pan. Not to mention the OEM timing chain, the skinny spark plug wires, the factory coil packs, etc. This engine really makes the point that what matters most is the cylinder heads.
Re: 632 dyno time [Re: AndyF] #3202810
01/06/24 05:51 PM
01/06/24 05:51 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Andy, I’m sure you mentioned it in a previous thread, but what’s the story on that manifold?
They normally get a typical single plane……no?
Re: 632 dyno time [Re: fast68plymouth] #3202818
01/06/24 07:08 PM
01/06/24 07:08 PM
AndyF Offline OP
AndyF  Offline OP
Yep, here is the way they come from Chevy. Stock water pump, cast intake with a Dominator bolt pattern. It is an EFI engine so they come with a really huge throttle body. It has super big throttle blades in it, probably flows more than 2500 cfm.
The owner wanted a front facing intake for his car. This engine is going in a tube chassis '57 Chevy and he wanted the throttle body in front so he could put a flat hood on it. It is a Hogan billet intake. Cost a small fortune.
Re: 632 dyno time [Re: AndyF] #3202834
01/06/24 08:15 PM
01/06/24 08:15 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
That’s a monster!
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 632 dyno time [Re: AndyF] #3202842
01/06/24 08:46 PM
01/06/24 08:46 PM
Who makes this motor and who did you buy it from?
I have local customer who wants me to build him a BB Chevy similar to this, I don't do that, Mopars only for me whistling realcrazy shruggy but I would be happy to turn him on to this deal.
luck
Re: 632 dyno time [Re: Cab_Burge] #3202875
01/07/24 12:50 AM
01/07/24 12:50 AM
AndyF Offline OP
AndyF  Offline OP
luck
It is a crate engine: https://www.jegs.com/i/Chevrolet+Pe...Yy5t0NdeZVHsd7-x8lawatu4oykaAgO1EALw_wcB
Re: 632 dyno time [Re: AndyF] #3202948
01/07/24 11:54 AM
01/07/24 11:54 AM
Central NC
gch Offline
gch  Offline
Central NC
Aluminum Cylinder Heads:
RS-X Design Raised Spread-Port
449cc Intake Runners
70cc Combustion Chambers
2.450 in. Intake / 1.800 in. Exhaust Titanium Valves
481 cfm of Airflow at 781 in. Valve Lift
Aluminum Valve Covers w/632 Logo in Iconic Chevy Orange
Camshaft and Valvetrain:
Billet Steel Hydraulic Roller
0.780 in. Intake / 0.782 in. Exhaust Valve Lift
.471 in. Exhaust Valve Lift
270° Intake / 287° Exhaust Duration @ .050 in.
Forged Aluminum 1.8:1 Shaft-Mounted Roller Rocker Arms
This got my attention.
Re: 632 dyno time [Re: gch] #3202952
01/07/24 12:07 PM
01/07/24 12:07 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
What is the lobe separation on the cam, if this is known ?
Re: 632 dyno time [Re: hemienvy] #3202965
01/07/24 12:41 PM
01/07/24 12:41 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
113 LSA. I like how in the Jegs reviews for the motor somebody gave it 1 star because of pump gas and 12:1 compression. With a cam that large I'm not surprised at all it can run at 12:1 on pump 93.
Re: 632 dyno time [Re: AndyF] #3202967
01/07/24 12:46 PM
01/07/24 12:46 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Bad ass engine. I haven't seen one with the forward facing intake, very nice. I like the injector placement as well. What size throttle body? Will be interesting to see if it shows any restriction/vacuum at high rpm.
Re: 632 dyno time [Re: Blusmbl] #3202975
01/07/24 01:15 PM
01/07/24 01:15 PM
AndyF Offline OP
AndyF  Offline OP
We're running 50/50 pump gas and av gas on the dyno. Not sure what the owner will run. Probably 110 race gas. It really needs a 102 unleaded but he can't find it around here. The problem is the O2 sensors foul up with lead and they cost $600 for the pair.
Re: 632 dyno time [Re: INTMD8] #3202976
01/07/24 01:16 PM
01/07/24 01:16 PM
AndyF Offline OP
AndyF  Offline OP
It is a MSD Atomic 103mm throttle body. It was the largest we could find that would fit the bolt pattern in the intake. The intake came from Hogan. Owner said it was the only one they had made but maybe they've made more of them by now. I've never seen one before. It is multipiece billet.
Re: 632 dyno time [Re: AndyF] #3202981
01/07/24 01:30 PM
01/07/24 01:30 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
Maybe one last question, what is the intake lobe centerline set at ?
OK maybe one more, what does the ignition timing curve look like ?
Re: 632 dyno time [Re: hemienvy] #3202984
01/07/24 01:35 PM
01/07/24 01:35 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Everyone realizes this is a brand new design cylinder head for a BBC right? That bog of an intake valve it should make power, be hard not to frankly. We have flogged one on the dyno with similar results but with the stock intake and throttle body. Be ZERO reason a guy could build a Predator engine to run pump swill that can make that power. These sell for $32-33K a decent value for sure.
Re: 632 dyno time [Re: Al_Alguire] #3202992
01/07/24 02:02 PM
01/07/24 02:02 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
When you have a big throttle body, it makes the throttle tip in very sensitive. Maybe even un-drivable if its a street car. I prefer, on any engine making north of 650hp, to use a progressive TB...Like a four barrel with progressive linkage. Drivability will improve. An engine will only use the amount of air it needs, no matter how big the TB is, so one that is sized a little better will give you better control. Just my 2 cents....
PS...That is the best bang for the buck engine out there right now. Thought about putting one in my Duster. Very well thought out engine, and the power it makes shows this.
Re: 632 dyno time [Re: Dragula] #3203001
01/07/24 02:57 PM
01/07/24 02:57 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
These aren't bad for throttle sensitivity. The cam the cable attaches to results in less initial blade movement vs throttle input. (of course not working that way with the dyno throttle attachment)
Page 1 of 3 1 2 3
