Re: Sure Grip rebuild
[Re: Jim_Lusk]
#3201700
01/02/24 03:20 PM
01/02/24 03:20 PM
Posts: 43,193 Bend,OR USA
Cab_Burge
Which type and year posi unit? The Dana 8 3/4 clutch type posi are rebuildable, the cup and cone type are not that I know of
[Re: Jim_Lusk]
#3201723
01/02/24 04:14 PM
01/02/24 04:14 PM
Posts: 75,019 U.S.S.A.
JohnRR
U.S.S.A.
My son's Dart already has a sure grip, but yesterday we discovered that it may not be working properly. We were working on the hydraulic clutch and wanted to make sure the clutch was disengaging. With the trans in first and clutch out he could spin one side and the other side was spinning opposite indicating that the SG may be worn out. Dr Diff has a clutch pack for $117. Is that likely all we'll need? How difficult is the rebuild? Is it a clutch or cone , the DR. diff kit is for a clutch, assuming you know how to set up and 8 3/4 chuck it's not hard , follow the service manual and note what the backlash is before taking the diff unit out to rebuild. I believe the case bolts are left hand thread .
[Re: Cab_Burge]
#3201727
01/02/24 04:20 PM
01/02/24 04:20 PM
Posts: 25,815 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Which type and year posi unit? The Dana 8 3/4 clutch type posi are rebuildable, the cup and cone type are not that I know of They're not "rebuildable" but they're repairable. Worn cones can be machined and Doc Diff offers a shim kit.
[Re: Jim_Lusk]
#3201921
01/03/24 12:55 PM
01/03/24 12:55 PM
John_Kunkel
Rio Linda, CA
To my knowledge it's the unit I pulled from a '68 Coronet wagon. Most sources show the introduction of the cone-type Sure-Grip as being in '69 but is was actually introduced on January 9, 1968. Only a visual inspection will show what it is.
[Re: Cuda340]
#3201975
01/03/24 04:30 PM
01/03/24 04:30 PM
JohnRR
U.S.S.A.
Also a 68 power-loc will have the one piece side gears, the earlier units had two piece side gears and you would have to use the axles to align the splines before tightening the unit back together after a clutch rebuild. Learned something new , I've only seen 2 piece side gears in the few I have owned , now I have something to look for .
[Re: JohnRR]
#3201979
01/03/24 04:38 PM
01/03/24 04:38 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
Also a 68 power-loc will have the one piece side gears, the earlier units had two piece side gears and you would have to use the axles to align the splines before tightening the unit back together after a clutch rebuild. Learned something new , I've only seen 2 piece side gears in the few I have owned , now I have something to look for . It was a mid 68 thing from my understanding prior to them phasing in the non-rebuildable units.
[Re: Cuda340]
#3201990
01/03/24 05:56 PM
01/03/24 05:56 PM
Cab_Burge
Also a 68 power-loc will have the one piece side gears, the earlier units had two piece side gears and you would have to use the axles to align the splines before tightening the unit back together after a clutch rebuild. All the Dana brand 8 3/4 posi had two piece side gears, the later Eatons did not have clutches or the same type spider gears like the Dana 8 3/4 posi units had If you can see springs inside the posi it is an Eaton type, not a clutch type Dana brand
[Re: Cab_Burge]
#3202214
01/04/24 02:08 PM
01/04/24 02:08 PM
JohnRR
U.S.S.A.
Also a 68 power-loc will have the one piece side gears, the earlier units had two piece side gears and you would have to use the axles to align the splines before tightening the unit back together after a clutch rebuild. All the Dana brand 8 3/4 posi had two piece side gears, the later Eatons did not have clutches or the same type spider gears like the Dana 8 3/4 posi units had If you can see springs inside the posi it is an Eaton type, not a clutch type Dana brand Cab the cone type used by Chrysler was made by Borg Warner .
[Re: JohnRR]
#3202256
01/04/24 06:49 PM
01/04/24 06:49 PM
Posts: 5,829 ohio
ruderunner
ohio
Isn't Eaton currently making them? I know BW sold off alot of their designs.
Angry white pureblood male
[Re: ruderunner]
#3202381
01/05/24 10:00 AM
01/05/24 10:00 AM
JohnRR
U.S.S.A.
Isn't Eaton currently making them? I know BW sold off alot of their designs. Eaton, Auburn , BW , no matter who makes it they all have one thing in common ... GARBAGE design ...
