battery time - recommendations please #3201150
12/31/23 02:15 PM
12/31/23 02:15 PM
moparx Offline OP
moparx  Offline OP
i need to buy a new battery for my charger. i know this topic has been covered many times, but is there anything new out there ?
it has a group 27 in there now, with an 850cca rating.
engine is 446cuin with 11.5 compression, 18 degree initial timing, and using a mini starter.
i would like to keep the battery up front, and as previous battery's have pitted up the front rail below the battery box, i have decided to lower the battery by repairing the rail and incorporating a battery box there, instead of having a separate [stock style] box above it.
any suggestions on a smaller, lighter battery that would work for my needs ?
running a 78 amp alternator [square back] with the electronic [70 up] style voltage regulator, and an amp gauge bypass from the alternator output stud to the battery stud on the starter relay, complete with fuseable link, with a volt gauge monitoring the charging system.
no extra electrical devices, such as ignition boxes or fuel pump, using a perfect condition factory 54 year old wiring harness.
however, i may convert to LED bulbs in all positions except headlights.
i also know battery's are expensive and you get what you pay for.
however, i don't want to have to buy one every two or three years.
i am also aware a new charger may be required, depending on what is selected.
thanks in advance for any advice you can give me. bow
beer
Re: battery time - recommendations please [Re: moparx] #3201211
12/31/23 06:15 PM
12/31/23 06:15 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Heard Everstart Maxx from Walmart is the same as Duralast Gold. That may be what I go for next time.
Re: battery time - recommendations please [Re: MI_Custumz] #3201226
12/31/23 07:57 PM
12/31/23 07:57 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Buddy of mine has a Braille battery - quite small, seems good at a few years old, it spins his MP crate 360 just fine.
IIRC, several guys here run Oddysey batteries inside their gutted OEM cases.
Re: battery time - recommendations please [Re: MI_Custumz] #3201238
12/31/23 09:07 PM
12/31/23 09:07 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
For what it's worth. twocents A Johnson Controls engineer once posted that all of the different brand batteries they manufacture use the exact same components. The only difference is the number of plates. The more plates the better the battery. He said buy the heaviest one. When asked which one that would be he said John Deere.
Re: battery time - recommendations please [Re: moparx] #3201330
01/01/24 04:42 AM
01/01/24 04:42 AM
i like to use a RV marine battery for my street toys, same thing on my race cars. Group 27 or group 24, Eveready brands from Costco or Walmart the last ten years scope up
I tried two different XS along with their charger,, JUNK tsk puke down twocents
Re: battery time - recommendations please [Re: GomangoCuda] #3201338
01/01/24 08:07 AM
01/01/24 08:07 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That is interesting because Johnson(now Clarios) only makes a couple of part numbers for Deere and only on the west side of the Mississippi.
68 Barracuda Formula S 340
Re: battery time - recommendations please [Re: moparx] #3201343
01/01/24 08:58 AM
01/01/24 08:58 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
OEM batteries seem to last the longest and are the most expensive. Since most brands come from the same manufacturer, I buy "gold" rated batteries locally. This makes it easier to claim any prorating and exchange because everyone sells defective product. And it goes bad on Sunday afternoon regardless of age. I need to change batteries typically every 6 years on DD. I remove batteries on toys and mowers for winter then put them on tenders. twocents
Re: battery time - recommendations please [Re: redraptor] #3201355
01/01/24 10:08 AM
01/01/24 10:08 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I've had a good luck with Wal Mart as anything. My daily Magnum which is used very little and sits sometimes for months in the summer. Going on 8 years. Same with my Cummins that is only used for towing the racecar April to October, 3 years and going well. To be honest if you don't let them go dead most are pretty good. That is the key. I have a slew of old batteries in about everything except my racecar. Various brands over 6 years old that all do alot of setting as well.
Doug
Re: battery time - recommendations please [Re: moparx] #3201371
01/01/24 11:00 AM
01/01/24 11:00 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Today's group 34s are nearly the same dimensions as the old group 24s. They are smaller than your group 27. You can look up the dimensions to see it the 34 would be small enough for you. It is a relatively common battery so it shouldn't be difficult to find.
There has been some good information already posted. The cca is the important number to watch. You have an 850 which is a fairly powerful car battery and there are group 34s with that same capacity. But, with capacity comes weight in most cases. So, the most powerful batteries will also be the heaviest until you get into some expensive, specialty batteries.
With batteries like these typically running north of $150 now, we buy them from the late model wrecking yards or better yet, the self serve yards. Most batteries are $30 to $40 there. And you can usually find them that are less than a year old. I have salvage yard batteries in all my cars, truck, tractors, and my Cuda. We get excellent life out of them. Great bang for the buck. The one in the Cuda has been in there for 4 years now.
Master, again and still
Re: battery time - recommendations please [Re: moparx] #3201392
01/01/24 12:36 PM
01/01/24 12:36 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I've been using (3 seasons) Snyder motorsports batteries with out any issues, and recently installed a Dynabatt in a customer car but no real use as of yet. Compact size (7" L X 3" W X 7" H) at 13 lbs... right around $200. I use a standard batter charger (set on a low amperage) to do between round maintenance.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: battery time - recommendations please [Re: W.I.N. Racing] #3201411
01/01/24 01:21 PM
01/01/24 01:21 PM
central il.
second 70 Offline
second 70  Offline
central il.
Walmart Last one I changed out on my Hemi was 11 years old and still started the car fine but I wanted to be safe.
https://www.walmart.com/ip/EverStar...27-12-Volt-810-CCA/28275658?from=/search
Re: battery time - recommendations please [Re: DaveRS23] #3201419
01/01/24 01:53 PM
01/01/24 01:53 PM
Houston, Texas
sean1970 Offline
sean1970  Offline
Houston, Texas
Great idea I never thought about that! Thanks brother!
Re: battery time - recommendations please [Re: Bad340fish] #3201476
01/01/24 06:23 PM
01/01/24 06:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
And those Deere ones have the plates Epoxied to the bottom, or at least always used to.
Re: battery time - recommendations please [Re: Bad340fish] #3201546
01/02/24 01:34 AM
01/02/24 01:34 AM
GomangoCuda Offline
GomangoCuda  Offline
I'll see if I can find that. I don't remember if he was referring to a specific group type. Also not real recent so who knows what models may have been discontinued since then. I just threw it out there as possibly useful information.
Re: battery time - recommendations please [Re: GomangoCuda] #3201591
01/02/24 11:20 AM
01/02/24 11:20 AM
PA
moparacer Online content
moparacer  Online Content
PA
Have always used Odyssey 12 volt batteries and had great luck with them. Couldn't get the PC1200 back during covid and bought a XS power D1200.
3 years on it with no problems.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: battery time - recommendations please [Re: moparx] #3201633
01/02/24 01:14 PM
01/02/24 01:14 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I used Mopar Performance batteries for years as my dad was a mechanic. Once he retired, I bought a yellow top optima battery. It's been issue free for close to 10 years now. My other car I had to replace the battery in 2 years ago and I went with an Interstate AGM battery as it was a little bit cheaper option. So far it's been issue free as well.
Re: battery time - recommendations please [Re: DusterKid] #3201749
01/02/24 05:21 PM
01/02/24 05:21 PM
moparx Offline OP
moparx  Offline OP
the battery i have now is a group 27, 850cca, and the date is 4/2011
if i charge it before i take the car out, it works ok, but parking it overnight with the negative cable disconnected, it discharges to anywhere between 11.9 and 12.1 volts.
good tips on going to a group 34 battery and checking out a junkyard. thanks ! up bow
my one buddy has a nephew that works at a scrap yard, and they get batteries in all the time.
i'll have him keep his eye out for one..........
beer
Re: battery time - recommendations please [Re: moparx] #3201775
01/02/24 07:13 PM
01/02/24 07:13 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I have had great success with red top Optimas'. not cheap but typically I get 10 years or more from.
One point about the Optimas' is they are sensitive to brand of external chargers, if it gets run down.
I use an Optima charger and have had no issues, bringing the Optimas' back up to full voltage....
Just my $0.02.. wink
Re: battery time - recommendations please [Re: Bad340fish] #3201854
01/02/24 10:52 PM
01/02/24 10:52 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I’m an Optima person. Our 12 year old blue top and the 9 year red top in my daily driven 96 Jeep are our 2 oldest ones. Not bad for the extreme heat of the desert SW. race car red top is 3 years old. Will buy a pair of the new yellow top H7s for the 17 Ram when needed.
Re: battery time - recommendations please [Re: J_BODY] #3201887
01/03/24 10:25 AM
01/03/24 10:25 AM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
I have read that Optima has changed hands (maybe more than once) and that their quality has slipped significantly.
www.diymobileaudio.com/threads/optima-batteries-decrease-in-quality.457537/
https://bobistheoilguy.com/forums/threads/optima-batteries-who-makes-them.190550/
This guy likes his Optima, but the comments are less positive:
www.youtube.com/watch?v=7EjkzZd1_5M
What are Mopart member's experiences with the Optima's the last few years?
