Page 3 of 3 1 2 3
Re: 2009 Engine masters [Re: CokeBottleKid] #320111
08/02/09 09:02 PM
08/02/09 09:02 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Dial indicators are used extensively on snap-gages, throughout
the machining industry for tolerances down to at least .0001" It's
much quicker and highly accurate. I've used them for years.
The real nice ones yes, but a standard indicator (like the one pictured) is only good down to .0005. The crappiest mics out there are good to .0001. I'm not seeing the logic, I guess it's just faster with a DI...
A Mic that measure to 1/10th of a thou is useless in the wrong hands, a stretch gauge or snap gauge takes the user's "feel" out of the equation. They are a very accurate measuring device that can be used quickly and consistantly. A Mic with spherical anvils could be used, but the stretch gauge would be just as accurate and much faster.
Unless you are in a temperature controlled environment, measuring to 0.0001" is futile, the size will change just holding the mic in your hand too long.
AL...
Alan Jones
Re: 2009 Engine masters [Re: W5DART66] #320112
08/02/09 09:12 PM
08/02/09 09:12 PM
Manassas, VA USA
Scamp451 Offline
Scamp451  Offline
Manassas, VA USA
Nice! Keep us posted on the runner progress as well.
Thanks to Todd at Marsh Performance for pulling strings and getting it up to you so quickly, great guy to deal with.
Re: 2009 Engine masters [Re: LA360] #320113
08/02/09 09:20 PM
08/02/09 09:20 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
I have to give Thanks to Dennis at AFD cylinder heads we had to patch heads back together after 2008 EM. seat and guide work on sundays LOL fun stuff. got the on the flow bench tonight at AFD. Not bad but could be better just to fast over ST. I think wse are just going to stay on the safe side but... the set up in this head with more ST work would make Killer power on a all out engine.
Re: 2009 Engine masters [Re: W5DART66] #320114
08/02/09 10:10 PM
08/02/09 10:10 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
What are the cubic inch rules this year?
Re: 2009 Engine masters [Re: HotRodDave] #320115
08/02/09 10:59 PM
08/02/09 10:59 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
FLOW PRO Report
________________________________________________________________________________
Test No. Test Name Customer Max CFM
Avg CFM
36 bhinbc 337.6
227.5
Lift CCFM MANOMETER RANGE DEPRESSION ACFM
CFM DIF PERCENT OF ACTUAL DEPR
0.0500 52.3 0.24 I1 28.00 52.3
27.25
0.1000 81.8 0.47 I1 28.00 81.8
25.46
0.1500 120.1 0.89 I1 28.00 120.1
27.21
0.2000 152.9 1.35 I1 28.00 152.9
24.44
0.2500 183.7 1.87 I1 28.00 183.7
26.25
0.3000 204.4 2.27 I1 28.00 204.4
27.61
0.3500 230.2 2.82 I1 28.00 230.2
26.83
0.4000 258.2 3.49 I1 28.00 258.2
27.95
0.4500 281.9 4.11 I1 28.00 281.9
25.72
0.5000 305.2 4.76 I1 28.00 305.2
27.75
0.5500 321.1 5.24 I1 28.00 321.1
26.66
0.6000 331.7 5.57 I1 28.00 331.7
25.73
0.6500 337.6 5.75 I1 28.00 337.6
25.25
0.7000 324.4 5.34 I1 28.00 324.4
26.28
Here are the flow #s for intake port. The CI rules are open this year.
Re: 2009 Engine masters [Re: W5DART66] #320116
08/03/09 11:59 AM
08/03/09 11:59 AM
SoCal
Brian Hafliger Offline
SoCal
Have you tried flowing the head with the intake, and carb?
Brian Hafliger
Re: 2009 Engine masters [Re: Brian Hafliger] #320117
08/04/09 06:55 AM
08/04/09 06:55 AM
The Great White North
RAMM Offline
RAMM  Offline
Not to Hijack your post Brett, but I figured I'd introduce myself here before the EMC in October. Our team (SKMFX Engine) has been accepted and myself being a Mopar fan have chosen to enter a 471 low deck stroker. All I really want at this point is to not embarass ourselves! I truly cannot wait for October and the chance to meet you and the other competitors. I am sure it will be a humbling experience to say the least. J.Rob
Re: 2009 Engine masters [Re: Brian Hafliger] #320118
08/04/09 11:05 PM
08/04/09 11:05 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
No I did not have time to do that yet would like to have that data but I would like to be on the dyno in 2 weeks(good luck with that LOL) and I still need parts..... and need to finish the other head and match up the intake. I will give it a shot(flow intake/carb on the head) What did you think of the flow #s ? This is now a 2.08" intake valve so if it did not back up over .650" would be darn nice head. I think it would make big power on all out Drag engine.
Re: 2009 Engine masters [Re: RAMM] #320119
08/04/09 11:09 PM
08/04/09 11:09 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
You will have a good time!"Nervous Excitement" How far you on the engine build?
Re: 2009 Engine masters [Re: W5DART66] #320120
09/05/09 09:21 PM
09/05/09 09:21 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Pay no attention to me.......
#7
Re: 2009 Engine masters [Re: S/ST 3040] #320121
09/05/09 09:25 PM
09/05/09 09:25 PM
S/ST 3040 Offline
S/ST 3040  Offline
#7.......again
Re: 2009 Engine masters [Re: W5DART66] #320122
09/06/09 12:50 PM
09/06/09 12:50 PM
SoCal
SoCal
I would have tried a 2.125 valve. Did this on a project I'm working on right now, and it actually works quite well! Flow #'s look alright, but .400 and .500 are low compared to larger intake valve that I've tried.
How fast is the port where you are accessing (.100 below max lift at the valve measured)?
Brian Hafliger
Page 3 of 3 1 2 3
