Re: 7.75x14" blue streak repro tires choices?
[Re: autoxcuda]
#3201893
01/03/24 11:28 AM
01/03/24 11:28 AM
Posts: 3,152 tennessee,usa
mattsmopars
tennessee,usa
7 = St Louis 427 SPD = April 27, 1966 That Feb 1966 tire I posted is the original spare. March 1966 date code on carbs: Thank you for posting pictures of the car, Can you continue to post details on this car or start a thread in the member build section? I also have a 66 hemi coronet and I am interested in documenting the details. A lot of the suspension components on my 66 were black. leaf springs, lower control arms, idler arm, pitman arm. I would also like to see the wheels and details of the stampings and if you remove the tires, details inside the band of manufacture. Really any details that can be documented the better. Pete was very much about documenting hemi cars, the NHOA vin list that was published back in 1990 was a brain child of his. Today myself and a close friend with help from him and other try to continue that work. Awesome car! Matt
[Re: mattsmopars]
#3201927
01/03/24 01:12 PM
01/03/24 01:12 PM
Posts: 27,485 So Cal
autoxcuda
So Cal
7 = St Louis 427 SPD = April 27, 1966 That Feb 1966 tire I posted is the original spare. March 1966 date code on carbs: Thank you for posting pictures of the car, Can you continue to post details on this car or start a thread in the member build section? I also have a 66 hemi coronet and I am interested in documenting the details. A lot of the suspension components on my 66 were black. leaf springs, lower control arms, idler arm, pitman arm. I would also like to see the wheels and details of the stampings and if you remove the tires, details inside the band of manufacture. Really any details that can be documented the better. Pete was very much about documenting hemi cars, the NHOA vin list that was published back in 1990 was a brain child of his. Today myself and a close friend with help from him and other try to continue that work. Awesome car! Matt Thank you for the kind words. I remember going to Pete’s house once in 1988 and looking at trailer cache of parts he got from back east. I carried NOS alum 990 heads onto a self and he pointed out an extra 68 S/S A-body disk setup in the pile. Crazy stuff. I plan on making a list of date codes and complication of markings. We are just caretakers of these cars. The lower control arms are also black on this car. I thought maybe done when a bushing change took place. Now keeping a little open mind in that. Under dash detail showing factory carpet end cutouts
[Re: autoxcuda]
#3201971
01/03/24 04:05 PM
01/03/24 04:05 PM
mattsmopars
tennessee,usa
7 = St Louis 427 SPD = April 27, 1966 That Feb 1966 tire I posted is the original spare. March 1966 date code on carbs: Thank you for posting pictures of the car, Can you continue to post details on this car or start a thread in the member build section? I also have a 66 hemi coronet and I am interested in documenting the details. A lot of the suspension components on my 66 were black. leaf springs, lower control arms, idler arm, pitman arm. I would also like to see the wheels and details of the stampings and if you remove the tires, details inside the band of manufacture. Really any details that can be documented the better. Pete was very much about documenting hemi cars, the NHOA vin list that was published back in 1990 was a brain child of his. Today myself and a close friend with help from him and other try to continue that work. Awesome car! Matt Thank you for the kind words. I remember going to Pete’s house once in 1988 and looking at trailer cache of parts he got from back east. I carried NOS alum 990 heads onto a self and he pointed out an extra 68 S/S A-body disk setup in the pile. Crazy stuff. I plan on making a list of date codes and complication of markings. We are just caretakers of these cars. The lower control arms are also black on this car. I thought maybe done when a bushing change took place. Now keeping a little open mind in that. Under dash detail showing factory carpet end cutouts I have a build thread in the members project section about my 66 if you have time check it out. I also see the grommet around the dimmer switch in the carpet that a lot of folks say were not used by mopar, but my 66 had one too. Matt
[Re: topside]
#3202004
01/03/24 06:55 PM
01/03/24 06:55 PM
autoxcuda
So Cal
Heckuva car - I say you're doing the right thing there. I still have a couple NHOA decals from back in the day - guess that deal folded up. Judging by the gas pedal, looks like carb linkage is disconnected ? linkage all hooked up. I think it's the camera angle.
[Re: topside]
#3202270
01/04/24 07:33 PM
01/04/24 07:33 PM
Posts: 21,537 It's a dry heat
gtx6970
It's a dry heat
There's one on Ebay right now - "Hemi Owners decal" is how I found it. Only 2 hours left, but I don't know if you'll see this by the ending time. So, I'm bidding on it and it's yours if I win - I'm at $5.51 max bid right now. Im high bidder on it now . Thanks EDIT, Its mine now Many thanks
[Re: topside]
#3202271
01/04/24 07:34 PM
01/04/24 07:34 PM
gtx6970
It's a dry heat
BTW, there's also a '66 Hemi Belvedere owner's manual listed on Ebay @ $499/BO. There are actually 3 of them . But I have it already. And didnt pay anywhere near $500 for it 2 years ago. There is also a 67 Coronet hemi owners manual. All of them have been for sale for quite a while
[Re: autoxcuda]
#3202452
01/05/24 01:39 PM
01/05/24 01:39 PM
Posts: 19,696 north of coder
moparx
Heckuva car - I say you're doing the right thing there. I still have a couple NHOA decals from back in the day - guess that deal folded up. Judging by the gas pedal, looks like carb linkage is disconnected ? linkage all hooked up. I think it's the camera angle. the bottom of the pedal is bolted to the floor, and the top pushes on a roller wheel. i agree the linkage is hooked up, but the camera angle could make it look like it wasn't.
[Re: autoxcuda]
#3202481
01/05/24 03:11 PM
01/05/24 03:11 PM
Posts: 20,980 A collage of whims
topside
A collage of whims
Looks like a forward cover - the rearward ones are larger. Those little holes are for the cover clips.
EDIT: My 1st sentence is wrong wrong wrong - rt side is the smaller one, left side is the larger one. Sorry for the brain fart.
[Re: gtx6970]
#3202535
01/05/24 05:31 PM
01/05/24 05:31 PM
autoxcuda
So Cal
Yes, That rear one looks like there was a different cover at one time that was attached to the little holes.
But does anyone have a picture of that rear one? So I know what to look for?
In the front, I have the traditional B/E-body black painted oval-ish metal cover held by two screws. That's all that goes up there, right?
[Re: gtx6970]
#3202586
01/05/24 09:08 PM
01/05/24 09:08 PM
autoxcuda
So Cal
Only thing I have are a set of the repops. I can pull out and grab a picture if you want And I have no idea how accurate they are to al year B body cars I bought them last year and still haven't put them on. But yes, only thing in the forward end are the metal ones held with 2 screws edit, they look like these https://www.ebay.com/itm/265199708853?https://www.ebay.com/itm/404603765736? Thanks, So my front is good. Just has a very well defined line where the undercoating was masked. I keep seeing red oxide primer on the side facing surfaces on the undercarriage. Like when they put the red primer down before paint, it blow over into the wheel well, rocker pinch weld, etc. At first it looks like the red is over the grey dip. Which I would assume. But would like more proof.
