Kickdown return spring #3200266
12/27/23 02:12 PM
12/27/23 02:12 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
A while back I bought dual throttle return springs (chrome) for my big block but I forgot about needing a kickdown return spring. Can someone tell me what the correct spring length should be (unstretched) for use on a kickdown return and where I can get one in chrome if possible?
Re: Kickdown return spring [Re: 6PAX] #3200385
12/27/23 10:30 PM
12/27/23 10:30 PM
Pasadena, Texas
fal3 Offline
fal3  Offline
Pasadena, Texas
Can't help you with the length, but I went to local parts store and bought a box of chrome springs of various lengths and diameters. Just went through them until found one that worked.
Re: Kickdown return spring [Re: 6PAX] #3200680
12/29/23 01:23 PM
12/29/23 01:23 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
See pics of the kick down return spring from my 71 RR 383. I hope this is what you are looking for.
Ron
Re: Kickdown return spring [Re: Ronnman] #3200713
12/29/23 03:03 PM
12/29/23 03:03 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Thanks for the pics Ron. 71 style must be different than earlier versions as what I need should be considerably longer and smaller in diameter. I believe it should span the distance from the throttle pin to the throttle bracket where the ball pivot mounts.
Re: Kickdown return spring [Re: 6PAX] #3200717
12/29/23 03:24 PM
12/29/23 03:24 PM
NJ
EV2RTSE Online content
EV2RTSE  Online Content
NJ
Yup it looks like they changed at some point in 1970. Megaparts has the original non chrome style-
https://www.megapartsusa.com/products.php?cat=687
Re: Kickdown return spring [Re: 6PAX] #3200718
12/29/23 03:25 PM
12/29/23 03:25 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
For reference the pic below shows how the spring is installed. For what year vehicle/engine are you inquiring?
Ron
Re: Kickdown return spring [Re: 6PAX] #3200741
12/29/23 05:41 PM
12/29/23 05:41 PM
IMGTX Offline
IMGTX  Offline
That spring is a Fairly light spring. If you go with a chrome one be sure it will work.
Maybe John Kunkel can come in on if the tension is really that important.
Re: Kickdown return spring [Re: IMGTX] #3200834
12/30/23 01:55 AM
12/30/23 01:55 AM
NJ
NJ
Here's the measurement on the early spring, the one end is broken off but should still get you in the ballpark.
Re: Kickdown return spring [Re: EV2RTSE] #3200848
12/30/23 07:44 AM
12/30/23 07:44 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I believe that's the spring I need. Thanks for the pic and thanks to everyone for your replies.
Re: Kickdown return spring [Re: 6PAX] #3200919
12/30/23 01:55 PM
12/30/23 01:55 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
a little silver chrome paint and nobody would ever know
