Page 2 of 3 1 2 3
Re: What is the best helmet? [Re: Hemi_Joel] #3200417
12/28/23 09:27 AM
12/28/23 09:27 AM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
I prefer a Bell. But any brand helmet that is Snell approved.
Re: What is the best helmet? [Re: Hemi_Joel] #3200418
12/28/23 09:31 AM
12/28/23 09:31 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Originally Posted by Hemi_Joel
Originally Posted by JERICOGTX
Did you forget you just bought a new helmet 2 years ago???
How could I forget?
A tech official on Death Week informed me that it is a motorcycle helmet and not fire resistant. Plus the spots where the Nexgen fitting go have thick, non removable hard foam, so I can't mount them. So I need a new one.
What size helmet does that big melon of yours take? You can try on my HJC if your head will fit.
69 GTX 68 Road Runner
Re: What is the best helmet? [Re: JERICOGTX] #3200425
12/28/23 10:32 AM
12/28/23 10:32 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I dug through the rulebook just for some clarification, and motorcycle helmets (like the RF1400 I have) are ok provided they are Snell M2015/2020 rated, with a couple exceptions. If you go 9.99 or quicker in an open bodied car with a power adder (or open bodied electric) it needs to be an SA rated helmet, not M. Pro mod, top alcohol dragster, top alcohol funny car, top fuel and funny car also all require SA rated helmets instead of M. Everything else, the M designation is ok per the rulebook.
That being said I don't know enough about the differences in helmet ratings to know which would be better if your head contacts a rollbar in an accident, as an example.
Re: What is the best helmet? [Re: Blusmbl] #3200496
12/28/23 01:57 PM
12/28/23 01:57 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
The tech said I could use it at my et, but didn't elaborate. (I was driving a 14 second car) The concerning thing to me is that he said it is not fire resistant like a helmet rated for race cars. Facial reconstruction in the burn ward is more costly than a fire resistant helmet.
Re: What is the best helmet? [Re: Blusmbl] #3200497
12/28/23 01:58 PM
12/28/23 01:58 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have a carbon fiber helmet from Speedway, I am sure it is made by the same people that make G-force because that is what it looks like. It is nice and light weight and fits my big melon well. Has all the appropriate ratings.
68 Barracuda Formula S 340
Re: What is the best helmet? [Re: Bad340fish] #3200536
12/28/23 07:02 PM
12/28/23 07:02 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
M rated helmets are rated and tested for your head hitting an object or hard surface. SA is tested and rated for having something hit you in the head. Fire rating is also included in SA as well as eye port size.
The SA standard was designed for competitive auto racing while the M standard was for motorcycling and other motorsports. The K standard was released to accommodate helmets used in karting. There are three major differences between them:
The SA standard requires flammability test while the M and K standards do not.
The SA and K standards allow for a narrower visual field than the M standard (Some SA and K certified helmets may not be street legal).
The SA and K standards include a rollbar multi-impact test while the M standard does not.
Re: What is the best helmet? [Re: CMcAllister] #3200702
12/29/23 02:35 PM
12/29/23 02:35 PM
moparx Offline
moparx  Offline
thanks for the rating clarification CM.
i learned something new that [hopefully] will protect my old noggin as good as possible, even though i'm in a super slow class. [roughly 11.90-12.50]
beer
Re: What is the best helmet? [Re: moparx] #3200711
12/29/23 03:01 PM
12/29/23 03:01 PM
Minnesota
Minnesota
Yes, that rating clarification is very useful! Thank you.
Re: What is the best helmet? [Re: Hemi_Joel] #3200734
12/29/23 05:03 PM
12/29/23 05:03 PM
When it comes to body protection clothes and devices I buy the best I can get up
I do hate that the helmet industry has gotten NHRA to limit the use of helmets, seat belts and other driver safety gear base on how old they are instead of what condition they are in rant twocents
Re: What is the best helmet? [Re: Cab_Burge] #3200767
12/29/23 07:47 PM
12/29/23 07:47 PM
Minnesota
Minnesota
How does a vented helmet prevent fire from entering the vents?
Re: What is the best helmet? [Re: Hemi_Joel] #3200782
12/29/23 09:14 PM
12/29/23 09:14 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
It doesn’t.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: What is the best helmet? [Re: Hemi_Joel] #3200842
12/30/23 04:41 AM
12/30/23 04:41 AM
confused
Thee SFI spec helmets with the neck socks required are probably fire resistance work scope twocents
Re: What is the best helmet? [Re: Hemi_Joel] #3200857
12/30/23 08:39 AM
12/30/23 08:39 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That is a scary thought.
One method might be the use of a low melt temp air supply hose to self disconnect to assist with vehicle exit and also terminate any path for hot pressurized air being forced inside the helmet.
Additionally, a crash sensor electrical cutoff switch on the helmet air supply fan might be another precaution.
Re: What is the best helmet? [Re: jcc] #3200932
12/30/23 02:57 PM
12/30/23 02:57 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
This got me to thinking about a new helmet, and Speedway is having a sale of sorts.
The inner liners - often Nomex, or what's called a Nomex blend - are fire-retardant, but yeah, helmet vents supply oxygen...
So, hard to quantify, but that's what head socks are supposed to do.
But those have their limits too, as anyone who knows who Niki Lauda was can tell.
Anyway, I see Speedway's selling Zamp helmets - never heard of them, but the company has a Meridian, ID address...a couple miles from my new place.
Supposedly a Euro-centric helmet maker, owned by Bell.
Re: What is the best helmet? [Re: topside] #3200984
12/30/23 06:43 PM
12/30/23 06:43 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
A few decades back at a Miami Beach hotel Niki sat down for breakfast at the adjacent table.
It was rather sobering.
I have incredible respect the man/driver.
My concern with supplied air helmets is not so much fire, as it is breathing superheated air into the lungs, which a head sock cannot prevent.
Re: What is the best helmet? [Re: jcc] #3200985
12/30/23 06:46 PM
12/30/23 06:46 PM
Minnesota
Minnesota
Some say they have liners of nomex and some have liners of EPS. What is EPS? The EPS that I know of is expanded polystyrene foam. But that couldn't be a liner, the liner is cloth right?
I was looking at the impact 1320 on their website. You can pay extra to get your helmet with NextGen mounts on it. But I couldn't figure out if you don't buy them next-gen mounts, if the threaded inserts are already in there. I suppose I'll have to call them.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: What is the best helmet? [Re: Hemi_Joel] #3200986
12/30/23 06:49 PM
12/30/23 06:49 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
By all means call them, but I believe most upper end helmets have the area reinforced and the screw inserts already installed, which makes a lot of sense rather than run the risk of the buyer yanking out the liner/padding and drilling holes.
The EPS is basically Styrofoam, covered by fabric (nomex?). The padding is best if it does not rebound, causing more brain injury, and helmets in hard hits are one time use.
Re: What is the best helmet? [Re: jcc] #3201020
12/30/23 10:18 PM
12/30/23 10:18 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
If you wreck a car at an NHRA race, two things happen immediately. They pull the cert sticker off the chassis and they pull the Snell sticker out of the helmet.
Re: What is the best helmet? [Re: CMcAllister] #3201033
12/30/23 11:33 PM
12/30/23 11:33 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Does the driver first get to take his helmet off? work biggrin
I did not know that.
edit: In further reflection taking off the chassis cert I can understand, but delabeling my helmet starts to be an issue, unless that is agreed to in some small print somewhere in advance. Not being able to prove a helmet was Snell approved post crash post Snell tag removal. seems to be problematic for me,
Re: What is the best helmet? [Re: jcc] #3201034
12/30/23 11:45 PM
12/30/23 11:45 PM
Minnesota
Minnesota
Looks like all SA 2015 and SA2020 helmets are required to have the M6 threaded holes pre-installed for the Hans device.
I think I'm going to go with the Impact 1320. I've heard only good about it, and I like that it is made in the USA. Thanks for all the help and suggestions.
Page 2 of 3 1 2 3
