727 id #3200745
12/29/23 06:09 PM
12/29/23 06:09 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
Hi all, so I'm looking to Id a 727 the numbers are in the photo .. the tailshaft has the snap ring acces on the side.. ty for any help
Re: 727 id [Re: Dakota_Don] #3200755
12/29/23 06:46 PM
12/29/23 06:46 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
By the reinforcements cast in across the top of the case and the style of print of the "pk" number that has to have been one of the last 727s made.
Re: 727 id [Re: volaredon] #3200764
12/29/23 07:22 PM
12/29/23 07:22 PM
Alton, IL
Alton, IL
I tried to use the ID search. It said 61.. but I know that's not right..
Re: 727 id [Re: Dakota_Don] #3200766
12/29/23 07:40 PM
12/29/23 07:40 PM
N
NITROUSN Offline
NITROUSN  Offline
N
It is off a magnum engine so it has to be a 92 or newer. I would guess 92 to 96 and most likely out of a van with the tailshaft snap ring cover on the side.
Re: 727 id [Re: NITROUSN] #3200770
12/29/23 07:58 PM
12/29/23 07:58 PM
N
NITROUSN Offline
NITROUSN  Offline
N
PK52119176 is the number. 3-Speed Automatic, 36RH
Re: 727 id [Re: NITROUSN] #3200809
12/30/23 12:02 AM
12/30/23 12:02 AM
Alton, IL
Alton, IL
What I found out 78 to 89... 3/4 ton and 1 ton vans and trucks
Screenshot_20231229_174807_eBay.jpgScreenshot_20231229_174043_eBay.jpgScreenshot_20231229_174715_eBay.jpg
Re: 727 id [Re: Dakota_Don] #3200812
12/30/23 12:25 AM
12/30/23 12:25 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The pic's are a bit confusing as they don't show the 727 front servo bulge an the pan confused, might be a 904 shruggy But i doubt they'd put one in the application you mentioned shruggy beer
Re: 727 id [Re: Dakota_Don] #3200817
12/30/23 12:43 AM
12/30/23 12:43 AM
AndyF Offline
AndyF  Offline
I didn't know the application but I could tell that it was very late model and most likely a truck or van. Looks like it is big and heavy.
Re: 727 id [Re: Dakota_Don] #3200875
12/30/23 11:39 AM
12/30/23 11:39 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Wrong. Its a 92 or newer from a magnum. The U shape hole is for the crank sensor which started in 1992.
Re: 727 id [Re: NITROUSN] #3200900
12/30/23 12:43 PM
12/30/23 12:43 PM
AndyF Offline
AndyF  Offline
Good catch, I didn't notice that sensor notch.
Re: 727 id [Re: Dakota_Don] #3200903
12/30/23 12:57 PM
12/30/23 12:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
PK52119176 is a 36RH from a '94-'95 Ram 1500 or 2500 2-WD or van with 5.2L engine.
Re: 727 id [Re: John_Kunkel] #3201013
12/30/23 10:03 PM
12/30/23 10:03 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
So Why the pic's of two different transmissions whistling? 1st pic bolted to a motor is a 727 and appears to be correctly identified. The 3rd & 4th pics look like a 904 confused shruggy
Re: 727 id [Re: TJP] #3201027
12/30/23 10:51 PM
12/30/23 10:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
My guess is the right hand does not know what the left hand is doing.
Re: 727 id [Re: NITROUSN] #3201134
12/31/23 01:31 PM
12/31/23 01:31 PM
moparx Offline
moparx  Offline
i switched hands one time, and the outcome wasn't what i expected......... biggrin
beer
Re: 727 id [Re: moparx] #3201258
12/31/23 10:19 PM
12/31/23 10:19 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
When I did that it felt like a stranger and the outcome exceeded normal expectations. 🙄 whistling beer 🤣
Re: 727 id [Re: TJP] #3201685
01/02/24 02:44 PM
01/02/24 02:44 PM
moparx Offline
moparx  Offline
beer
and off to the races ! laugh2 boogie punkrocka
beer
Re: 727 id [Re: moparx] #3201857
01/02/24 10:57 PM
01/02/24 10:57 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
