440 suggested carb #3200070
12/26/23 12:37 PM
12/26/23 12:37 PM
MILFORD, MICHIGAN
MILFORD MOPARS Offline OP
MILFORD, MICHIGAN
have a 440 mild cam with a little porting
auto trans . not a numbers car.. i like Holeys
what carb would you all recommend?
i was thinking 750 vacuum secondary
thanks for any input
Re: 440 suggested carb [Re: MILFORD MOPARS] #3200073
12/26/23 12:44 PM
12/26/23 12:44 PM
Star Idaho
67vertman Online rolleyes
67vertman  Online Rolleyes
Star Idaho
Oh boy, here comes the catfight You know it is winter Moparts season?
I like the I like the Holley 3310 750cfm
My Monster are real!
Living within your means makes life pretty easy.
Re: 440 suggested carb [Re: MILFORD MOPARS] #3200077
12/26/23 01:31 PM
12/26/23 01:31 PM
Kirkland, Washington
Pacnorthcuda Offline
Yes, a Holley 750 VS works very well with an auto transmission car. And you can tune the secondary springs to bring ‘em in faster if you want.
Re: 440 suggested carb [Re: MILFORD MOPARS] #3200124
12/26/23 05:20 PM
12/26/23 05:20 PM
Which trany is in it?
If it is an automatic the 3310 will work fine, if it is a stick car I would run a 700,750 or 800 CFM double pumper twocents up
Re: 440 suggested carb [Re: MILFORD MOPARS] #3200127
12/26/23 05:48 PM
12/26/23 05:48 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
Quick Fuel Brawler BR-67258 770 VC. Completely adjustable air bleeds ect. Adjustable vacuum secondary, electric choke. I have one and it works great.
America First!
Re: 440 suggested carb [Re: MILFORD MOPARS] #3200150
12/26/23 08:13 PM
12/26/23 08:13 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Why doesn't anyone ask the OP's level of willingness and ability to 'tune' their new carb BEFORE making a recommendation? A carb that is 'easy' to tune (and needs to be tuned) may not be for them. And most guys are probably wanting a 'bolt on and go' type of deal.
The 3310 is a good universal carb. I have installed quite a few over the years. BUT! They are WAY rich on the cruise. 4 to 6 steps on the mains on most and then, the PVCRs need drilled larger to get the WOT back where it needs to be. And the secondary will need a quicker spring on most every engine I have ever put one on. There are a couple of other things that usually need attention, too. So again, if the OP is comfortable with 'tuning', then the 3310 may be a good choice. But let's be clear; it is putting far too much fuel into the engine at light loads.
And for a street car, the Double Pumpers are even richer. Holley lists them a 'track carb' after all. And for good reason.
If the OP wants a Holley platform carb, I would suggest calling Holley with the details and getting a recommendation from them. They have a lot of carbs with different tunes for different applications. Starting with a carb that is closer to the real needs of the combo is always better than starting father away.
Personally, I would suggest avoiding the AFB/AVS CarterBrocks simply because their 'tunes' are ancient. And if the OP does want to tinker with the idle and off idle tuning, they are a royal PITA. The basic platform is a good one. It's just a shame that after all these years and with all the different companies making a version of them that no one has updated the transitions or made them easier to adjust. But it is what it is.
My go-to carbs the last few years have been the Street Demons. They have the very best off idle transitions going today. Plenty of youtube videos on them. BUT! They are a street carb and are for stock and nearly stock engines. The rougher the idle, the less they make sense.
If the idle is rough, it may be difficult for the OP to get an out-of-the-box carb to get the job done without needing to be tuned or being excessively rich.
twocents
Master, again and still
Re: 440 suggested carb [Re: MILFORD MOPARS] #3200157
12/26/23 08:51 PM
12/26/23 08:51 PM
AndyF Offline
AndyF  Offline
Engine like that doesn't need more than 600 cfm but a 750 vac secondary won't hurt anything. The 750 will probably never fully open since that engine will only use 500 to 500 cfm of air at WOT.
Re: 440 suggested carb [Re: DaveRS23] #3200174
12/26/23 10:42 PM
12/26/23 10:42 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
twocents
I agree. The level the OP wants to keep the tune is significant to the recomendation.
But we need more info, IMHO.
What are the cam specs?
What intake manifold do you have?
Cast Iron exhaust or headers?
What is the rear end gear ratio and rear tire size?
Re: 440 suggested carb [Re: MILFORD MOPARS] #3200534
12/28/23 06:49 PM
12/28/23 06:49 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Holley's are the most tunable. I consider all to need tweaking to get right. I have found most are just cores needing to be gone through. Passages not drilled all the way, throttle blades miss-aligned, bleeds all wrong, jetting off. They all need work. Edelbrocks work well on mostly stock engines.
Re: 440 suggested carb [Re: AndyF] #3200624
12/29/23 10:52 AM
12/29/23 10:52 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Really, 500 cfm? Wonder why the six pack worked so well on the 440, 1350 cfm. They also worked on the 340 engine.
Re: 440 suggested carb [Re: GODSCOUNTRY340] #3200651
12/29/23 12:17 PM
12/29/23 12:17 PM
AndyF Offline
AndyF  Offline
Six pack doesn't flow 1350 cfm, that is a 2bbl rating number not a 4bbl rating number. Engine output of 400 hp requires 569 cfm with a BSFC of 0.500. If the engine is more efficient than 0.500 then it requires even less air to make 400 hp.
Re: 440 suggested carb [Re: AndyF] #3200698
12/29/23 02:24 PM
12/29/23 02:24 PM
moparx Offline
moparx  Offline
i am unlike all here, in that i love Thermo-Quads !
however, it took me YEARS to figure them out, and be able to tune them to my needs.
the result is good/reasonable gas mileage with the added oomph of the monster secondaries tunable with the air door.
before my retirement, jets and metering rods were kind of hard to find, so i whipped up programs for them on a CNC we had at work, then made a bunch of each.
in the interim, i pick up T-quads cheap at swaps, or sometimes i get them for free from friends.
the only real problem i run into almost always, is the jet wells on the bottom of the float bowl come loose and leak.
the fix for that is the gasoline resistant version of JB weld.
no problems otherwise.
beer
Re: 440 suggested carb [Re: AndyF] #3200712
12/29/23 03:01 PM
12/29/23 03:01 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I had thought that many of us had run this test over the years. laugh2 We frequently threw larger carbs on our Mopars. And with varying degrees of success due to a number of factors besides just the size of the carb.
But I firmly believe that most 440s would be quicker at the drag strip with carbs larger than 600cfm. Now, for street only we can talk about the smaller being better until you throw in the spreadbores like the Thermoquad. But overall, don't most here feel that any credible 440 with a tuned 750 would outrun one with a 500 or 600cfm carb?
Aren't there any youtube videos doing this kind of shootout? Or has everyone thought that this was settled (rightly or wrongly) in the 1970s?
Engine Masters episode 44 tested a mild 383 shivvy with a 600 and with a 750 carb. But I am not a subscriber. Can anyone link that test?
Here's Uncle Tony's take on this: www.youtube.com/watch?v=HdF7IAWFT8w
And he does make some good points on this subject.
Re: 440 suggested carb [Re: DaveRS23] #3200732
12/29/23 04:46 PM
12/29/23 04:46 PM
Every B/RB motor, regardless of cubic inches, that I've added cfm on the intake side of the motors made more power at the drag strip and on the engine dyno up work
Swap 600 CFM carb to a 750, then an 850 and finally a intake and carb change to a 1050 CFM Dominator on a stock bore and stroke 440 bracket motor, jetted for best ET and MPH up
Same thing on more than one engine dyno tests, started testing with a 600 CFM carb and ended up with a tunnel ram intake with two 1060 CFM Dominators shock up boogie
Stupid Mopar wedge motors whistling grin
Re: 440 suggested carb [Re: Cab_Burge] #3200743
12/29/23 05:48 PM
12/29/23 05:48 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Yup
Re: 440 suggested carb [Re: Cab_Burge] #3200756
12/29/23 06:48 PM
12/29/23 06:48 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Re: 440 suggested carb [Re: MILFORD MOPARS] #3200761
12/29/23 06:59 PM
12/29/23 06:59 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Simple plug and play Holley 770 Street Avenger
Re: 440 suggested carb [Re: A12] #3200779
12/29/23 08:56 PM
12/29/23 08:56 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
You can't change the air bleeds easily. Check out the Brawler carb I posted BR-67258.
America First!
Re: 440 suggested carb [Re: carnut68] #3200795
12/29/23 10:18 PM
12/29/23 10:18 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Never found changing the air bleeds "easily" an issue? Had the Street Avenger's as mentioned plug and play on both of my 383 '68 RR and 440 4-speed '69 GTX and no need for an easy air bleed change. All of the easy adjustments on the Holley SA were more fun to play with but not really necessary just did them as mention to play around with. Both the 383 and 440 SA's were plug and play and spot on out of the box. Just saying if the OP wants to drive the car without making adjustments.
Re: 440 suggested carb [Re: DaveRS23] #3200797
12/29/23 10:19 PM
12/29/23 10:19 PM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
Basically there is no perfectly tuned carburator out-of-the-box. Yes, there is a slight chance it may work well upon install but not likely..
Today many new carburators are tuned on the lean side for emissions..
However one carburator has been mentioned more than others and that is a Holley.
IMHO...
A Holley carburator is EZ to tune if U understand its basics, and its multiple internal parts are readily available..
Just my $0.02.. wink
