8.25 rear end question #3198859
12/20/23 12:42 PM
12/20/23 12:42 PM
Central NC
gch Online content OP
gch  Online Content OP
Central NC
I have an 8.25 rear in my 72 Newport that I want to change gears in. It appears I have a 2.45 ratio. Is it possible to run a lower gear in this case? I have several gears and a later trak loc but I think the case needs to be of a 2.76 or lower ? Hoping you guys can set me straight.
I can always dran an 8.75 or 9.25 out of arts cars I have but man this would be a lot easier.
Re: 8.25 rear end question [Re: gch] #3198868
12/20/23 01:16 PM
12/20/23 01:16 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Yes, any steep gear than 2.45 in the 8 1/4 will need a carrier change, opportunity for a Suregrip installation.
Re: 8.25 rear end question [Re: Sniper] #3198951
12/20/23 07:12 PM
12/20/23 07:12 PM
Central NC
Central NC
So a different housing is needed? This housing is not usable for anything 2.76 or lower?
Re: 8.25 rear end question [Re: gch] #3198977
12/20/23 08:34 PM
12/20/23 08:34 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Just the carrier needs change, the housing is the same.
Re: 8.25 rear end question [Re: Sniper] #3199458
12/22/23 05:00 PM
12/22/23 05:00 PM
West Virginia
B1Frank Offline
B1Frank  Offline
West Virginia
if you need one i have a 3.55 gear .....i will check......send me a PM
