Re: Now: 66 Hemi Satellite survivor
[Re: tboomer]
#3221136
03/17/24 07:23 PM
03/17/24 07:23 PM
Posts: 27,623 So Cal
autoxcuda
So Cal
That looks good! Did you re-use the factory bolts? Reused the bolts that were there. Seemed factory but looked like three different brands/stamps I used Justice Brothers Engine Degreaser. Seemed to work better than brake clean or concentrated simple green. It was best when surface dry between applications/follow-ups. I used an air nozzle to dry. Then scrub. Then spray with hand spray bottle with water set to stream. The agitated greas-grime and degreaser would shoot off surface when the shot of water stream hit it. Then slide and dip off to a pan underneath. Used dishwasher brush, small stiff bristle shop brush, engine cleaner bottle brushes.
[Re: autoxcuda]
#3222393
03/23/24 05:15 PM
03/23/24 05:15 PM
autoxcuda
So Cal
Thinking about buying a group 27 repro battery.
What is the difference between early 65-68? red top and later 69-72? battery.
I have a late one with green tops I’m debating gutting and putting a small mini battery inside
They sell red tops separate ?
This is what I have. It’s got a 29…. Part number
[Re: autoxcuda]
#3222415
03/23/24 07:23 PM
03/23/24 07:23 PM
Posts: 22,071 Enjoy life today, It has an ex...
gtx6970
My gut feeling is cap color has something to do with cold cranking amps maybe. or manufacturer year,,,,or both I went with red caps
Enjoy life today, It has an expiration date
[Re: gtx6970]
#3255424
09/02/24 06:46 PM
09/02/24 06:46 PM
autoxcuda
So Cal
Steve, You decide on tires ?? Rims powdercoated like factory grey, then painted black from front. My tires are on car. I'm just detailing hub caps more. And I've gotta change the intake gasket.
[Re: autoxcuda]
#3255432
09/02/24 07:25 PM
09/02/24 07:25 PM
autoxcuda
So Cal
Dyno Tune by famed Nubu’s Auto Lab -Hollywood, CA (right in heart of Hollywood btw)
February 7, 1970
Done by Nubu himself.
$72 is seems like quite a bit back then. Plug, dual points, recurve vacuum advance, rejet, floats, wheel dyno run.
[Re: autoxcuda]
#3255433
09/02/24 07:35 PM
09/02/24 07:35 PM
gtx6970
Dyno Tune by famed Nubu’s Auto Lab Hollywood, CA (right in heart of Hollywood btw)
February 7, 1970
$72 is seems like quite a bit back then. Plug, dual points, recurve vacuum advance, rejet, floats, wheel dyno run. $4.50 for hemi plug wires ???
[Re: autoxcuda]
#3255434
09/02/24 07:36 PM
09/02/24 07:36 PM
gtx6970
Steve, You decide on tires ?? Rims powdercoated like factory grey, then painted black from front. My tires are on car. I'm just detailing hub caps more. And I've gotta change the intake gasket. Cool, You better have it for viewing in April next year ,,,,,or else !!!!! LoL !!!
[Re: gtx6970]
#3255438
09/02/24 07:52 PM
09/02/24 07:52 PM
autoxcuda
So Cal
February 7, 1970
$72 is seems like quite a bit back then. Plug, dual points, recurve vacuum advance, rejet, floats, wheel dyno run. $4.50 for hemi plug wires ??? $4.50 Labor. Parts are $13. They did quite a bit. at 17,000 miles in October of same year, just 6,000 miles later (23K mi) Nubu's did another tune and adjusted the valves. $79. But in July with 20K mi the dealer did a trans service and brake adjustment & inspection and lube.
[Re: autoxcuda]
#3255445
09/02/24 08:15 PM
09/02/24 08:15 PM
autoxcuda
So Cal
This picture stamped developed June 1974
Look at the black body putty coming out from door sill plate!
The passenger door panel still has errant assembly line upholstery glue shot on the door panel and upper door frame. Nice build quality!
[Re: gtx6970]
#3255489
09/02/24 11:17 PM
09/02/24 11:17 PM
autoxcuda
So Cal
February 7, 1970
$72 is seems like quite a bit back then. Plug, dual points, recurve vacuum advance, rejet, floats, wheel dyno run. $4.50 for hemi plug wires ??? It just dawned on me. That is just the wires and maybe spark plug ends. The boots and standoffs I just took off the car, are the originals with orange engine paint from factory on them. New wires are nice Lectric Limited date coded ones with boots that stay snapped on the tubes now. Back in the day when people would make plug wires. Vehicle log says solid core wires only replaced Apr 11, 1997 to replace previous solid cores from Feb 7, 1970 from invoice shown above. Those solid core wires sure don't like modern timing lights BTW !!
[Re: A12]
#3255586
09/03/24 01:51 PM
09/03/24 01:51 PM
gtx6970
Steve, You decide on tires ?? Rims powdercoated like factory grey, then painted black from front. My tires are on car. I'm just detailing hub caps more. And I've gotta change the intake gasket. Wow that is some off-set on that wheel and tire Deep Dish
