Shortening 8 3/4" without a jig (use channel iron & clamps)
#3198789
12/20/23 12:56 AM
12/20/23 12:56 AM
Posts: 4,929 Tri-Cities, Washington
VITC_GTX
So, your opinions on shortening a 8 3/4" without a store bought jig. I've seen many videos where guys are using 3" channel and large c-clamps to clamp the housing together and to hold it "straight" when welding it back together. Short video as an example https://www.youtube.com/watch?v=Jql_IVp_RF0 Backyard butchery or darn close enough consider factory tolerances and 50 years of hard use???
Re: Shortening 8 3/4" without a jig (use channel iron & clamps)
[Re: VITC_GTX]
#3198800
12/20/23 06:44 AM
12/20/23 06:44 AM
Posts: 4,780 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I've see people use a large tubing cutter to cut the housing. Makes straight consistent cuts. Then beveling of the ends and clamping it secure and straight just like in the video you posted. I had a shop narrow my 8.75- had them do everything.- new ends and a drain plug welded into the housing. New tubing ends and new green bearing installed. The shop used Moser to cut and respline the axles. It was not cheap. Total came to $700.
Keep old mopars alive.
[Re: B1Frank]
#3198888
12/20/23 02:42 PM
12/20/23 02:42 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Chrysler never made a straight rear housing , And the outside of the housing is less straight than the inside.
[Re: IMGTX]
#3199288
12/21/23 11:23 PM
12/21/23 11:23 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
Made my own. Only used it once. Looking for excuses to use it again. LOL!
[Re: markz528]
#3199342
12/22/23 09:59 AM
12/22/23 09:59 AM
Posts: 4,687 Wichita
GY3
Wichita
I love doing as much as I can on my car. I built the engine, transmission and suspension.
When it came to the Dana 60, I wanted it done right. I took it to a local race shop that had all the tools (that I didn't) and years of experience (that I didn't) and they charged me a nominal fee to narrow it, weld on the ends and put in a different gearset.
All in with new axles, bearings, spool and the cost to cut down a full floater, I'm in it for around $900.
We did set the pinion angle in the car and burned in the pads at my neighbors house who is really good at welding and has all the tools (that I didn't).
"Sometimes a man has got to know his limitations." - Clint Eastwood
[Re: John_Kunkel]
#3199927
12/25/23 12:23 AM
12/25/23 12:23 AM
Posts: 9,856 MI, usa
dvw
MI, usa
Johns looked like the last one I heated and shrunk back to being close before welding. Doug
[Re: dvw]
#3199964
12/25/23 01:21 PM
12/25/23 01:21 PM
John_Kunkel
Rio Linda, CA
Years ago I had a cottage industry shortening housings and shortening/re-splineing axles. IMHO the only correct way to shorten a housing is with a bar all the way through both sides of the housing.
Even with the bar installed, after the welds cooled, the bar wouldn't easily turn so I would have to heat and shrink the housing into alignment. Admittedly, I'm not the best welder but lots of experience showed me that ANY welding on a housing will result in warping it.
[Re: John_Kunkel]
#3200130
12/26/23 06:38 PM
12/26/23 06:38 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I used a 1.25" ground SS bar fore my setup
[Re: jcc]
#3200131
12/26/23 06:56 PM
12/26/23 06:56 PM
Posts: 3,087 Michigan
A727Tflite
I used a 1.25" ground SS bar fore my setup Being your unit is bolted to a fixture, does you bar come out without much flogging?
[Re: jcc]
#3200132
12/26/23 06:57 PM
12/26/23 06:57 PM
Posts: 20,187 Park Forest, IL
slantzilla
Park Forest, IL
I used to work in a shop that did a lot of rear shortening and/or straightening. They had the Mittler Brothers setup which is the spacers and bar. 8.8 Fords were the worst for being crap from the factory.
[Re: A727Tflite]
#3200207
12/27/23 10:12 AM
12/27/23 10:12 AM
jcc
Bitopia
I used a 1.25" ground SS bar fore my setup Being your unit is bolted to a fixture, does you bar come out without much flogging? That is the reason for the modified open carrier you see in the attached pic, I can remove/loosen the caps if needed to make everything more moveable if I get any excessive distortion after welding. Not sure if my pic shows this, one shaft "bookend" is bolted solid, and the other is placed/clamped as needed on a ground guide plate mounted to the robust I beam base.
[Re: IMGTX]
#3200287
12/27/23 03:40 PM
12/27/23 03:40 PM
John_Kunkel
Rio Linda, CA
Figure out which direction you need to pull it, heat a portion of that side of the tube cherry red and hit it with a water-soaked shop rag. Let cool, repeat as necessary. https://www.youtube.com/watch?v=z76i3MWi_r8
