This is what I get for being a nice guy #3198644
12/19/23 03:07 PM
12/19/23 03:07 PM
Central TEXAS!!!!
sr4440 Offline OP
sr4440  Offline OP
Central TEXAS!!!!
About 45 days ago, a customer comes in with a fresh rebuilt 426 Hemi that’s been sitting for 2 years. After hooking up to the dyno, pre oil, fuel, and water. We get ready to start it, on its 1st rotation there is a loud snap. So off come the valve covers and we find a broken adjuster. The geometry is awful, maybe worse than awful. The adjusters are out about 8 or 9 threads, pushrods are aimed at the shafts, everything is in a bind. The customer bought the engine in Minnesota and now doesn’t trust the builder, so he’s not going to send it back.
Ok, even though I don’t work on other people’s engines, I tell him I will help him out and fix it. After fixing the geometry, getting longer pushrods, degreeing in the cam. I go to put everything together, and one of the brand “new” comp cams hydraulic roller lifters is missing the spring inside the lifter!!! So I go to order one set, and they are backordered until the end of Jan (maybe). I can’t even find a used lifter to take the spring out. Now this engine is going to sit in the shop.
This is what I get for being a nice guy, it bites me in my behind every time.
Rant over/
Joe
Without Data, you’re just another guy with an opinion.
Re: This is what I get for being a nice guy [Re: sr4440] #3198649
12/19/23 03:12 PM
12/19/23 03:12 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Order a pair of some lifters you can actually get……. Might need a couple pushrods too…… not a big additional expense in the long run.
Re: This is what I get for being a nice guy [Re: fast68plymouth] #3198657
12/19/23 03:35 PM
12/19/23 03:35 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
There's an old saying: "no good deed goes unpunished".
I've lived that many times.
BUT - there's a personal satisfaction in solving problems, making someone else's situation better, and/or earning respect.
You'll likely attain all 3 - and hopefully be paid for your efforts.
Trust me, it could be a lot worse...
Re: This is what I get for being a nice guy [Re: topside] #3198660
12/19/23 03:55 PM
12/19/23 03:55 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'm guessing a spring out of just about any hydraulic lifter would work -- I think all they do is hold the cup up when there's no oil in the lifter. Once oil pressure is applied the job of the spring is done.
Re: This is what I get for being a nice guy [Re: Stanton] #3198697
12/19/23 06:39 PM
12/19/23 06:39 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Been there done that. Funny too, I'll get a feeling in the pit of my stomach and when I do it usually means I m in for a lot more work than anticipated. I should say no and I don't.
Re: This is what I get for being a nice guy [Re: quickd100] #3198700
12/19/23 06:55 PM
12/19/23 06:55 PM
NY
B1duster Offline
B1duster  Offline
NY
What # Comp lifters ?
I just found some on ebay
Re: This is what I get for being a nice guy [Re: sr4440] #3198716
12/19/23 08:22 PM
12/19/23 08:22 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I stopped by my local speed shop yesterday to chat up the owner. Nice guy, but he's into phords. Anyway, they do a lot of rebuilds. He was telling me that whenever a customer wants a time estimate, he tells them he can't tell them a thing until he checks on availability of EVERYTHING. Usually, it is 90+ days. Something is always on back order. Even common, popular stuff. And it sometimes affects the combo; they have to change to pieces other than they first spec'd due to turn around times.
He bought some big heavy shelves to hold the blocks and stuff. He puts paint daubs on everything in an attempt to keep everything where it belongs. I'll bet he has 40 or 50 engines apart and waiting for parts. He would have the customers hang onto them until their time gets close, but he usually needs to tear them down so he knows what they need. And then he hates to have the customer come and get it until it's time and parts come. Keeping track of it all, particularly the ordered parts is a full time job all by itself.
What a headache!
Master, again and still
Re: This is what I get for being a nice guy [Re: sr4440] #3198718
12/19/23 08:26 PM
12/19/23 08:26 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Bag it and stuff it into the corner. There are worse things that could happen than having to store a motor for a month.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: This is what I get for being a nice guy [Re: A39Coronet] #3198719
12/19/23 08:30 PM
12/19/23 08:30 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
After finding that mess you going to pull the pan? I can see more pain on the horizon.......
Re: This is what I get for being a nice guy [Re: B1duster] #3198725
12/19/23 08:54 PM
12/19/23 08:54 PM
Central TEXAS!!!!
sr4440 Offline OP
sr4440  Offline OP
Central TEXAS!!!!
They are 8921-2, the ones on eBay don't look anything like them, the oil hole is in the band and the ones on ebay it's in the body.
Thanks for looking
Joe
Re: This is what I get for being a nice guy [Re: slantzilla] #3198730
12/19/23 09:01 PM
12/19/23 09:01 PM
Central TEXAS!!!!
sr4440 Offline OP
sr4440  Offline OP
Central TEXAS!!!!
I know I should, and I probably will, because I didn't mention 2 different size valve tip heights, 3 broken adjusters from being over torqued. Or the cam being installed "dot to dot" and being 6 degrees off.
Re: This is what I get for being a nice guy [Re: sr4440] #3198754
12/19/23 10:21 PM
12/19/23 10:21 PM
AndyF Offline
AndyF  Offline
The engine is most likely a pile of junk. Tell the owner that and ask him if he wants to proceed or not. Odds are that he'll be into it several thousand before it works right. Tell him to give you some money up front since you will most likely need to buy a steady stream of parts until it is done.
Re: This is what I get for being a nice guy [Re: AndyF] #3198758
12/19/23 10:30 PM
12/19/23 10:30 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm a firm believer in Karma, both good and bad. A good deed done will come back as a blessing.
Re: This is what I get for being a nice guy [Re: AndyF] #3198759
12/19/23 10:31 PM
12/19/23 10:31 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Agreed. If the top end has been a victim of bush league assembly, the bottom end probably is also.
Re: This is what I get for being a nice guy [Re: AndyF] #3198866
12/20/23 01:00 PM
12/20/23 01:00 PM
WI
mopar873 Offline
mopar873  Offline
WI
^^ Spot on!
I gave my Dad a hand with a matching number '66 hemi rebuild that was going into a triple digit $ restoration about 15 years ago. There were about a dozen F-ups in that engine that he uncovered when we offered to double check everything for the owner before it was installed. A new set of pistons, cam, lifters, valley bolts,1 MP replacement head, balance job, and two rebuilt carbs later....it was finally right. All found in an engine previously deemed "ready to fire" , assembled by a local rebuilder here in central WI. That would've been a disaster.
Re: This is what I get for being a nice guy [Re: mopar873] #3198869
12/20/23 01:20 PM
12/20/23 01:20 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I'd like to know who built it in Minnesota?
69 GTX 68 Road Runner
Re: This is what I get for being a nice guy [Re: AndyF] #3198895
12/20/23 03:16 PM
12/20/23 03:16 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
x8 up
Re: This is what I get for being a nice guy [Re: sr4440] #3198952
12/20/23 07:12 PM
12/20/23 07:12 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Thanks for looking
How likely are they to be the 'big-brother' of the SB 8920 lifter? (my stipulation here being that the internals, including the retaining snap ring would be the same size)
Can't specifically help you today as those 8920 lifters are in my w2 stroker motor, but perhaps finding a single 8920 set might work?
Re: This is what I get for being a nice guy [Re: Diplomat360] #3199071
12/21/23 10:10 AM
12/21/23 10:10 AM
Central TEXAS!!!!
sr4440 Offline OP
sr4440  Offline OP
Central TEXAS!!!!
Thanks for looking
Thank you for the suggestion, looked on summit and found
"Not Available At This Time
This product cannot be ordered at this time. Future availability is unknown. We apologize for the inconvenience"
Re: This is what I get for being a nice guy [Re: sr4440] #3199103
12/21/23 12:58 PM
12/21/23 12:58 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Just one more reason to not use comp's. And the smallest to boot.
