Re: 503 Ford on dyno today
[Re: AndyF]
#3198565
12/19/23 11:57 AM
12/19/23 11:57 AM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Andy
If that is a 4150 sniper, it's running out of air. They are rated @830, but anytime I get near 780-790 SCFM I start to pull a good size vacuum. Plus, the AFR heads really flow, I have seen VE as high as 110 on a race engine and 104 105 on a street engine.
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#3198580
12/19/23 12:32 PM
12/19/23 12:32 PM
Posts: 31,046 Oregon
AndyF
Andy
Joe Yes, it could be running out of air or fuel. The data log shows the Sniper is over 90% duty cycle so the injectors are basically running full time. We're going to increase the fuel pressure today to see if that helps. I looked at the manifold vacuum on the data logs and it was still around 99 kpa at the end of the pull so it wasn't losing much power there. The AFR heads are pretty good. We've built other BBF engines with these same heads that make a lot more power. But those engines had more compression and much larger cams. This cam is only 240/248 since it is going into a truck.
[Re: Streetwize]
#3198582
12/19/23 12:36 PM
12/19/23 12:36 PM
AndyF
Never mind the big block, (JK!) what's the story on that Cleveland next to it? We do have some Clevelands in the shop at the moment but that isn't one of them. That is another BBF with Kaase SR71 heads. It is a 521 inch drag race engine. Flat top pistons make 13.5 compression with the SR71 heads. The SR71 heads have raised ports, relocated valves and big SCJ ports. That engine should make 900 hp once we get it sorted out.
[Re: Streetwize]
#3198596
12/19/23 12:56 PM
12/19/23 12:56 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Would need to be lean/over 100% duty cycle for that to be the reason. 99kpa isn't showing the throttle body being a restriction.
[Re: AndyF]
#3198604
12/19/23 01:08 PM
12/19/23 01:08 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
My first suspicion with a big block, HR, and high RR is always lifter issues.
Similar cube combo, 505 BBM, mid-10’s CR, ez-295’s, Indy 2-D, HS 1.6 rockers, HR………. 640/640.o
[Re: fast68plymouth]
#3198617
12/19/23 01:31 PM
12/19/23 01:31 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Are the Bore and stroke the same or did you do the logical thing and go with a larger bore on the Ford???
#3198674
12/19/23 04:34 PM
12/19/23 04:34 PM
AndyF
Similar cube combo, 505 BBM, mid-10’s CR, ez-295’s, Indy 2-D, HS 1.6 rockers, HR………. 640/640.o Yeah I agree. I suspect the lifters are just starting to complain at 5800 rpm. It hits earlier in a BBF due to the 1.73 rocker ratio. We made a few pulls today for the customer and it ran better today than yesterday. Probably due to rings seating after a few heat cycles. Peaks were up to 660 torque and 650 hp so it will be a stout truck motor. Going in a F250 4 wheel drive dually pickup. The Sniper duty cycle peaks at 88% so it isn't running out of fuel. It is pulling about 800 cfm according to the turbine so it is close to running out of air. The manifold vacuum at WOT bounces around between 0 and 1.5 inches so there is some restriction but not a ton.
[Re: AndyF]
#3198753
12/19/23 10:19 PM
12/19/23 10:19 PM
INTMD8
Lake Villa Il
Not saying you guys aren't right, but I don't understand the how and why. Yes more rocker ratio puts more load on the lifter but to me it's not load on the lifter but a loss of control. I can't eyball the OD of the spring/retainers but looks huge (heavy)/steel to me.
[Re: AndyF]
#3198798
12/20/23 06:03 AM
12/20/23 06:03 AM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
Never mind the big block, (JK!) what's the story on that Cleveland next to it? We do have some Clevelands in the shop at the moment but that isn't one of them. That is another BBF with Kaase SR71 heads. It is a 521 inch drag race engine. Flat top pistons make 13.5 compression with the SR71 heads. The SR71 heads have raised ports, relocated valves and big SCJ ports. That engine should make 900 hp once we get it sorted out. I have a 460 with a set of SR-71 heads. Its a relatively mild build for durability because its going in my jet boat. Those head castings are really nice and "Fast as cast" . With my setup, based on the RPM I'm pulling the jet pump to I figure I'm a little north of 650 HP @ 5500 RPM. With those heads and the large 2.375 intake and small 1.71 exhaust, the cam is split about 16 degrees more duration on the exhaust. AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: AndyF]
#3198938
12/20/23 06:21 PM
12/20/23 06:21 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Just a thought from a novice in the peanut gallery. What would happen if you drop a 1050 dominater on it and solid roller lifters? If it still flattens out, could it be a valve spring issue? Sad to say, it COULD possibly be a combination of issues, not just one?
[Re: gregsdart]
#3198948
12/20/23 07:06 PM
12/20/23 07:06 PM
Al_Alguire
Las Vegas
Been down that road with a Sniper on a Pontiac. Might consider throwing a good carb on and see what happens.
[Re: AndyF]
#3199109
12/21/23 01:37 PM
12/21/23 01:37 PM
gregsdart
Engine is gone already. Customer watched it run, liked it, paid the bill and took it home. Glad he was happy. But those of us on hear would want to ring out that extra hp, its just how we are built, right?
[Re: gregsdart]
#3199110
12/21/23 01:42 PM
12/21/23 01:42 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
Engine is gone already. Customer watched it run, liked it, paid the bill and took it home. Glad he was happy. But those of us on hear would want to ring out that extra hp, its just how we are built, right? Naw, not us
