SLR Advice #3198362
12/18/23 11:45 AM
12/18/23 11:45 AM
WI
mopar873 Offline OP
mopar873  Offline OP
WI
Hi Guys, I'm looking for some starting line ratio advice on a build likely hitting the track in spring. It's a Brand X, but I'm on this site almost daily and I know there are several serious racers here and I value the input greatly. Scoop on the car:
2600lbs/4 link
31" tire/1.76 first gear glide/5.14 gear
775-800hp/3.625 stroke
This car will be footbrake only, no transbrake in the future. The intent is to break into the high 8's NA. If my math is right, I'm coming up with a 9.05 ratio SLR as it sits now. Might be a little light, but with this high rpm combo it will be very dependent on a great converter to get it there. If I'm way off, please share.
Thanks!
Re: SLR Advice [Re: mopar873] #3198371
12/18/23 12:22 PM
12/18/23 12:22 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I would run it as it is and try to be able to data log at least driveshaft speed vs RPM and go from there.
Re: SLR Advice [Re: mopar873] #3198372
12/18/23 12:24 PM
12/18/23 12:24 PM
gregsdart Offline
gregsdart  Offline
You won't be too steep on SLR, unless you over rev it ( too much rear gear) on an 1/8 mile track, IMHO. If you race a delaybox class, you can launch at a lower rpm if need be. I have had good consistancy with 11.17 slr, much more than recomended by most, by launching at 3900 on a converter that flashes to 6200, running 8.60 1/4 mile with 550 cubes.
Re: SLR Advice [Re: gregsdart] #3198376
12/18/23 12:56 PM
12/18/23 12:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We run SLR's in the 12's with the red car on a 29.5x10.5 tire(not W)with no issues running 7's. Dont get caught up in "ideal" numbers every combo is different. Might have to work on the car a bit to make it work but if you have an ET goal you are gonna have to work to get there anyway.
I also run 8's with a 3600lb 64 Plymouth NA and my SLR is 10.4 and still on the 29.5x10.5 tire. Its not rocket sceince.
Re: SLR Advice [Re: Al_Alguire] #3198381
12/18/23 01:08 PM
12/18/23 01:08 PM
WI
mopar873 Offline OP
mopar873  Offline OP
WI
Thanks for the replies Guys. I think we just need to go out and thrash it to see what it likes and go from there. The rear gear was picked to match up where we thought we'd be at RPM/trap speed-wise. If we do need more, powerglide gears aren't hard to find.
Re: SLR Advice [Re: mopar873] #3198427
12/18/23 05:08 PM
12/18/23 05:08 PM
gregsdart Offline
gregsdart  Offline
I suspect it will like more ratio in the glide, as that short stroke can use it.
Re: SLR Advice [Re: gregsdart] #3198429
12/18/23 05:20 PM
12/18/23 05:20 PM
WI
mopar873 Offline OP
mopar873  Offline OP
WI
I am guessing the same.
Re: SLR Advice [Re: mopar873] #3198481
12/18/23 10:15 PM
12/18/23 10:15 PM
I would look into using the 1:80 low gear set and then find out what RPM your motor wants to be shifted at with that ratio up twocents up twocents
Re: SLR Advice [Re: Cab_Burge] #3198548
12/19/23 10:55 AM
12/19/23 10:55 AM
WI
mopar873 Offline OP
mopar873  Offline OP
WI
Yeah, that's the direction I'm going. The higher numerical ratios above 1.80 appear to be limited to what kind of power they can take. This engine will have a shift point between 8750-9k.
