The type of armrest base in the pictures below were typical for a whole lot of early 60's Mopars.. They are the "long" style, measure about 15" long, and have twin holes where the screws mount them to the door panel.
- My '65 Satellite uses the two rear-most mounting holes. I use a total of two screws to mount the armrest..
Which Mopars used the two front mounting holes? ..or am I supposed to use all four mounting holes?
The reason I ask is the plastic around my rear armrest holes cracked, so I got replacements.
My old armrest(s) seem fine for a Mopar that uses the front mounting holes.
Thanks , - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
