Re: 914hp Pump Gas Hemi
[Re: Dragula]
#3196481
12/10/23 02:09 PM
12/10/23 02:09 PM
Posts: 1,629 pa
572charger
pa
the heads pictured are stage v big valve heads , mine made 880 hp with a smaller cam and 11.75 to 1 comp my 3900 lb car ran 9.60 at 142 mph
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: Dragula]
#3196576
12/10/23 09:30 PM
12/10/23 09:30 PM
Posts: 6,136 Melbourne , Australia
LA360
FYI ...The one in the article is only 541 cubes...Wonder why the sheet metal intake then. I would suspect it was an owner request. No real reason to run one otherwise
Alan Jones
[Re: LA360]
#3196618
12/11/23 08:43 AM
12/11/23 08:43 AM
Posts: 12,384 Taxes & Virus's R-US, NY
Dragula
Did you see the intake bolt pattern? That is not standard...Ports are too big for standard location bolts.
[Re: Dragula]
#3196722
12/11/23 03:27 PM
12/11/23 03:27 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
Wouldn't be the first time a car mag got stuff wrong but the caption under the picture of the heads The heads are CNC-machined Stage V aluminum castings from Ray Barton Racing Engines. maybe Barton relocates the intake bolts?
[Re: Al_Alguire]
#3196782
12/11/23 06:17 PM
12/11/23 06:17 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
My 528 is also pump gas street engine as well that makes good power and even more on the spray.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Skeptic]
#3196783
12/11/23 06:17 PM
12/11/23 06:17 PM
Posts: 2,636 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
You could order Stage V heads with the 5 bolt intake setup. That is for making the ports larger and not running out of intake gasket. Since he was buying a sheet metal intake anyway it just makes things easier. Sometimes they make the intake or heads for O-rings. I like that.
2011 Drag Pak Challenger
[Re: Al_Alguire]
#3196786
12/11/23 06:18 PM
12/11/23 06:18 PM
rickseeman
Stuttgart, Arkansas
Aint rocket science nor that difficult. This 536" Hemi made 936 on ump gas that was in my truck. It was sold CHEAP too. It appears to me that engine has been hopped up.
[Re: Dragula]
#3196893
12/12/23 09:20 AM
12/12/23 09:20 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
If it had Milleniums on it, I'd expect it to make well north of 1k hp. Mine makes decent power (somewhere over 800 hp) and is a lot milder than that one. Mine still has the standard intake bolt pattern, nothing special CNC ported MP aluminum heads, a cast single 4500 intake, and a pretty mild solid roller. 9.54 at 140.4 mph at 3800 lbs. on motor only and pump gas.
[Re: an8sec70cuda]
#3200725
12/29/23 03:57 PM
12/29/23 03:57 PM
Dragula
Al, those are SS heads....As they are known now. They still retain one 1/4 bolt per port, but the second one has been deleted as per the allowed rules I guess. Can't image what it cost to build one of those custom monsters. I went to the Stage V website and they state the Millenium heads can be 16-bolt, 6-bolt or 10 bolt......Only other heads offered that way are Indy 426-H1-HiPo heads or Big valve stock replacement heads as they are known, but those do not flow enough to hit those numbers. http://www.stagev.com/pages/m2000head.html
[Re: Dragula]
#3200844
12/30/23 06:40 AM
12/30/23 06:40 AM
Posts: 6,389 nielsville, minn.
quickd100
nielsville, minn.
Al, those are SS heads....As they are known now. They still retain one 1/4 bolt per port, but the second one has been deleted as per the allowed rules I guess. Can't image what it cost to build one of those custom monsters. I went to the Stage V website and they state the Millenium heads can be 16-bolt, 6-bolt or 10 bolt......Only other heads offered that way are Indy 426-H1-HiPo heads or Big valve stock replacement heads as they are known, but those do not flow enough to hit those numbers. http://www.stagev.com/pages/m2000head.html . I had my 426 Hi-Po heads flowed right out of the box. Intake 443 corrected@.700 Exhaust 255 corrected@.700 Intake port is 265cc's I asked my friend with the flow bench why he didn't go to .800 and he said The bench was maxed out. They easily flow enough air to get there.
