Re: Poly 318 bore thickness
[Re: earlymopar]
#3196617
12/11/23 08:41 AM
12/11/23 08:41 AM
Posts: 6,250 nowhere
Sniper
nowhere
A common swap is to use 360 pistons (4" bore versus the 4.04" bore of the 340) and turn the mains on the 360 crankshaft to fit the 318 block. Not sure what the purpose of this common swap is? Seems like an expensive way to make a 360.
[Re: earlymopar]
#3196730
12/11/23 03:44 PM
12/11/23 03:44 PM
Posts: 4,674 Wichita
GY3
Wichita
By design, Poly heads offer an obvious performance potential over L/A heads. In fact the current generation Hemi engines are closer to the Poly valve configuration than to an earlier Hemi. I have yet to see a Poly head that will outflow even the W-2's let alone a W-8! A friend has the cast iron W-2's on his stroker 340 and makes an easy 600+ horsepower. Show me the Poly head that does that! One of the guys that wrote an article for Chrysler Power pimps 500 horsepower Polys. When you drill down you find out it takes lots of custom machine work, special parts and your final price is going to be about $15k!
[Re: GY3]
#3196741
12/11/23 04:04 PM
12/11/23 04:04 PM
Posts: 1,335 Oregon
earlymopar
You're comparing apples to oranges as expected. I'm talking factory-stock heads as a benchmark. The prices you mentioned are purely based on the builder, their build plan and their parts sources. Building a poly is all about making something perform what was never meant as a performance engine. I have the same amount of $ in my Poly block and heads as most would have in their LA block and heads. No "drilling down" needed.
[Re: earlymopar]
#3196744
12/11/23 04:21 PM
12/11/23 04:21 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Generally yes by quite a bit but as usual, confirmation by ultra-sonic measurement is best before committing to a plan for boring. Thicker than my early 360?
[Re: topside]
#3196924
12/12/23 11:16 AM
12/12/23 11:16 AM
Posts: 10,717 North Dakota
6PakBee
North Dakota
Poly motors are something like the Y-block Ford or the 348 Chevy, not the best nor the most powerful but really cool! If I live long enough one of my goals is to build a stroker poly with 2-4's.
[Re: Neil]
#3196945
12/12/23 12:03 PM
12/12/23 12:03 PM
Sniper
nowhere
Better to have bore thickness for ring seal than boring something out the outer edges of usability. Simply boring one out to a 340 is not going to make it significantly more powerful all by itself I don't think.
Years ago some guy built a 402 out of Poly 318 and it did ok for what it was. I think he made it a 4" bore and used 360 pistons? That article was once easy to locate, but it escapes me at the moment. People have posted it on here numerous times over the years, myself included. Did more than bore it out to get a 402 out of it. Stroked it too. My math shows a 4" stroke with 4" bore to get a 402. According to this guy, 450 hp out of a set of ported poly heads is doable. If course he'd building a 390 stroker version. https://poly318.com/poly-318-cylinder-head-porting/Stock poly heads flow 187 intake, 146 exhaust at .50" lift. No way this head will support lots of HP, stock. I don't care what you chamber is, you still need air and fuel in to make HP out. Here's a 402 build with lots of head work. 405 hp, 442 tq. A stock magnum 360 with a cam and intake change will almost beat that, 380hp/410 tq. A 360 based 402 with Edlebrocks will beat it. Port those Edelbrock to similar levels and it will destroy it. https://www.motortrend.com/how-to/mopp-0110-how-to-give-a-318-poly-engine-more-power/ Is it cool to have an off beat engine powering your ride, you bet. I am build a 230 based flathead with hot rod goodies because it's not a belly button engine. But I have realistic expectations of it's output, 150 hp if I am lucky, lol. Is it cost effective, not even close. Sometimes it's about other things than max output. If I was worried about that I'd swap a Hellcrate in.
