Re: Thoughts on what to change to run mid 11's?
[Re: AndyF]
#3198066
12/16/23 10:04 PM
12/16/23 10:04 PM
Posts: 4,715 Wichita
GY3
Wichita
6 bolt crank is all you need but before you decide double check availability on flex plates. You'll want a high quality flex plate for that engine and sometimes 8 bolt ones are easier to find in the SFI grade. Head studs can be a nice upgrade but sometimes they'll interfere with the header flange. With the power you'll be making you need to upgrade a lot of the little parts. You'll need Cometic head gaskets for example, and the best bearings. The one piece rear main from Fast Fish is usually a good investment but you might want to talk to the engine builder before you buy too many parts. Some engine guys only want to use certain parts. Yep, we did the 8 bolt Molnar crank. Competition Products had good pricing on the crank and rods, but that was quite a while ago. You might check them out, though.
[Re: GY3]
#3198072
12/17/23 12:03 AM
12/17/23 12:03 AM
Posts: 31,106 Oregon
AndyF
I usually use Molnar for cranks and rods unless it is a killer race engine and then we would step up to Callies. But for this engine I'd buy from Molnar if they had them in stock. MI vendor so freight is less too. The dealer discount is significant from Molnar so if you want a Molnar crank see if you can find a local dealer. Could save you about $300 on the crank.
[Re: Thelma133]
#3198106
12/17/23 11:44 AM
12/17/23 11:44 AM
Posts: 3,529 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
That is a nice looking car!! I get the temper, I call it mission creep. I know a guy that makes custom stainless headers if you ever wanted to spend the money. It sure wasn’t cheap, but It’s the best part of my engine. But I have plenty of room in my cuda. He has made headers for lots of original mopar cars that I thought weren’t possible. His headers are a work of art. Maybe a getting a little off topic but Jon Kasse says it is very important to use stainless headers or headers that are well coated inside the pipes. Why? He says rust from the pipes get sucked back into the engine. He said sometimes as far back as the carburetor.
[Re: 340Cuda]
#3198216
12/17/23 07:02 PM
12/17/23 07:02 PM
Posts: 8,191 Plymouth, MI
Blusmbl
Plymouth, MI
Thanks Thelma, appreciate it! Andy- right now I have to buy a flexplate too (the one on the car isn't SFI) so I can buy either, looks like both the 6 and 8 bolt ones are available from B&M at Summit right now. Don't think I'll ever exceed 1000 hp with this combo no matter how much it gets sprayed so the 6 bolt should be ok, same with Molnar vs. stepping up to a real Callies USA forged crank. Center counterweight would be nice if I ever swapped the top end to make real power, but I can't find any of the import forgings in CCW. I worked at Roush 2 decades ago and used to be able to get parts at wholesale cost, got cranks and cams for a few guys on the board, the discount back then was significant. I should've stockpiled parts back then instead of starting fresh. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Competition Products doesn't look like they sell Molnar anymore. Mancinis and Ray Barton both do and they're cheaper than what Molnar would sell them for, thanks! Bill - that's definitely true. On the Harleys I've owned you can hear and see anything near the exhaust get sucked in and blown back out when they start.
[Re: dvw]
#3198310
12/18/23 06:48 AM
12/18/23 06:48 AM
Posts: 10,049 MN
JERICOGTX
MN
Try Campbell Enterprises for Molnar stuff. Doug I've bought all of my Molnar stuff from Campbell. Marshall has been great to deal with. Waiting on a crankshaft for my Dad's 383 now from them.
69 GTX
68 Road Runner
[Re: 340Cuda]
#3198496
12/18/23 11:25 PM
12/18/23 11:25 PM
Posts: 288 NW Illinois
MoonshineMattK
NW Illinois
That is a nice looking car!! I get the temper, I call it mission creep. I know a guy that makes custom stainless headers if you ever wanted to spend the money. It sure wasn’t cheap, but It’s the best part of my engine. But I have plenty of room in my cuda. He has made headers for lots of original mopar cars that I thought weren’t possible. His headers are a work of art. Maybe a getting a little off topic but Jon Kasse says it is very important to use stainless headers or headers that are well coated inside the pipes. Why? He says rust from the pipes get sucked back into the engine. He said sometimes as far back as the carburetor. https://www.enginelabs.com/news/amazing-video-jon-kaase-tests-airflow-dynamics-with-his-finger/Probably because of all the pulsing going on. There's been rusty exhaust on most of the cars forever and ever. Suppose the greater the investment in the engine the more a person would want to protect the investment.
[Re: 340Cuda]
#3198512
12/19/23 04:48 AM
12/19/23 04:48 AM
Posts: 43,355 Bend,OR USA
Cab_Burge
That is a nice looking car!! I get the temper, I call it mission creep. I know a guy that makes custom stainless headers if you ever wanted to spend the money. It sure wasn’t cheap, but It’s the best part of my engine. But I have plenty of room in my cuda. He has made headers for lots of original mopar cars that I thought weren’t possible. His headers are a work of art. Maybe a getting a little off topic but Jon Kasse says it is very important to use stainless headers or headers that are well coated inside the pipes. Why? He says rust from the pipes get sucked back into the engine. He said sometimes as far back as the carburetor. Me thinks that be baloney sauce, sucked back into the engine up to the carb when running ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: Cab_Burge]
#3198532
12/19/23 09:51 AM
12/19/23 09:51 AM
Posts: 2,013 Apollo, PA.
B1MAXX
Apollo, PA.
That is a nice looking car!! I get the temper, I call it mission creep. I know a guy that makes custom stainless headers if you ever wanted to spend the money. It sure wasn’t cheap, but It’s the best part of my engine. But I have plenty of room in my cuda. He has made headers for lots of original mopar cars that I thought weren’t possible. His headers are a work of art. Maybe a getting a little off topic but Jon Kasse says it is very important to use stainless headers or headers that are well coated inside the pipes. Why? He says rust from the pipes get sucked back into the engine. He said sometimes as far back as the carburetor. Me thinks that be baloney sauce, sucked back into the engine up to the carb when running X2
[Re: B1MAXX]
#3198544
12/19/23 10:41 AM
12/19/23 10:41 AM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
If it were me and you have to run the smaller headers you need to up the compression and reduce the overlap, build more torque sooner and lower the RPM peak...Kinda similar to if you have FAST Racing type exhaust restrictions....
As small as 1 7/8" x 3 1/2 with a 3" system sounds, I'm sure some of the FAST guys limited to Manifolds and 2 1/2-ish(lol) would kill for the ET gains they might make having the exhaust system you're working with.
Also the 40-50HP difference/advantage with open headers on a Dyno is likely to be considerably reduced in an actual car with full exhaust pushing against rolling and wind resistance.
To me a big C body is going to ET better on FAT mid range torque, it's going to make it's best moves through the middle and on the shift recovery and it's simply not going to top end charge like a lighter car with a lot less frontal area.
You want a big grunt motor not so much a 'horspower' motor.
I got a ported MW Indy Dual plane if you want to borrow it to try it out. I'd run it over a single plane on something like your 68
Unless it's in a really light car like an A body, to me a BB Mopar is less like a Hemi or a Small block Mopar and more like a Buick/Olds/Pontiac type motor, and the ET's respond to a similar kind of race tuning.
Also if you look at your exhaust sytem I would put the 3 1/2" collector on it and bring it straight back and run your "street" system coming out of the collector extention on a 45 degree cut out branch on each side. Forcing your exhaust through that 'double dog leg ' just to get to the cut out is killing some torque and power.
[Re: Cab_Burge]
#3198628
12/19/23 02:05 PM
12/19/23 02:05 PM
340Cuda
Tulsa, Oklahoma
That is a nice looking car!! I get the temper, I call it mission creep. I know a guy that makes custom stainless headers if you ever wanted to spend the money. It sure wasn’t cheap, but It’s the best part of my engine. But I have plenty of room in my cuda. He has made headers for lots of original mopar cars that I thought weren’t possible. His headers are a work of art. Maybe a getting a little off topic but Jon Kasse says it is very important to use stainless headers or headers that are well coated inside the pipes. Why? He says rust from the pipes get sucked back into the engine. He said sometimes as far back as the carburetor. Me thinks that be baloney sauce, sucked back into the engine up to the carb when running I think this is where I heard him talk about this, Hidden Horsepower episode. https://www.youtube.com/watch?v=TfAt5XTQDrII have always thought Kaase was a smart no BS type of guy and I choose to believe him. Bill Edit: https://www.youtube.com/watch?v=moUZPvAmvr4&t=7sThis is the correct video, discussion starts about 31:08
[Re: Streetwize]
#3198776
12/19/23 11:12 PM
12/19/23 11:12 PM
Blusmbl
Plymouth, MI
Thanks guys, Campbell looks to have the best advertised prices for Molnar stuff so once I'm back in town I'll definitely order from them. I also called Callies, they weren't sure if a 4.375" crank would fit with the internal pickup, but did confirm a 4.25" fits with no issues. I looked under the car again and I only see one potential routing for an external oil line next to the block, because of where the steering box mount is a taller oil pump or one with a sandwiched plate like the Milodon setups won't fit. I could maybe route a -12 line up to the inlet on the block with a 90* fitting but it's going to be very tight. If it were me and you have to run the smaller headers you need to up the compression and reduce the overlap, build more torque sooner and lower the RPM peak...Kinda similar to if you have FAST Racing type exhaust restrictions....
Also if you look at your exhaust sytem I would put the 3 1/2" collector on it and bring it straight back and run your "street" system coming out of the collector extention on a 45 degree cut out branch on each side. Forcing your exhaust through that 'double dog leg ' just to get to the cut out is killing some torque and power. This makes a lot of sense, thanks. I definitely want to put as much compression in it as possible. I'm sure I could get by with 12.5:1 on the street with some timing pulled out of it but that will also make it lazy and also run warmer than it would otherwise. Definitely think I'm going to need a tighter converter. The converter in the car now flashes to ~4500 on motor and maybe 5000 with a 180 shot. Even if this new motor only makes 700, I think that's a solid 100 more than it currently makes on nitrous and should have a similar torque curve too. Agree totally on the location of the dumps, make the open end have flow priority and then let it make a 45* turn to join the rest of the exhaust. Appreciate the offer on the intake, honestly I'm probably a year out from getting the motor in the car. Originally thought I'd assemble it myself with help from friends who offered, but am getting gunshy now adding up the receipts of what has been bought already and what it still needs. Might start contacting some builders.
[Re: 340Cuda]
#3199371
12/22/23 11:19 AM
12/22/23 11:19 AM
GY3
Wichita
That is a nice looking car!! I get the temper, I call it mission creep. I know a guy that makes custom stainless headers if you ever wanted to spend the money. It sure wasn’t cheap, but It’s the best part of my engine. But I have plenty of room in my cuda. He has made headers for lots of original mopar cars that I thought weren’t possible. His headers are a work of art. Maybe a getting a little off topic but Jon Kasse says it is very important to use stainless headers or headers that are well coated inside the pipes. Why? He says rust from the pipes get sucked back into the engine. He said sometimes as far back as the carburetor. I recall seeing that. He said it occurs at startup and to rev the engine as soon as possible when starting. Reversion tends to suck the debris back up into the plenum. They were finding rust up there and couldn't figure it out. Dude has done more testing than 99% of the people out there.
[Re: smalltyredart]
#3215810
02/24/24 12:29 PM
02/24/24 12:29 PM
Blusmbl
Plymouth, MI
Figured I'd pop in for a quick update on this one. Haven't done anything with the car all winter, but parts are piling up, along with the events and to do list. Was already signed up for Sick Summer and just got registered for Drag Week as well. Have almost everything on order or here now for the motor now besides pushrods. I talked to a few different people, some shops had lead times of > 8 months. In the end it made sense to go with a friend, Jim Pranis originally built the engine and trans that is in the car now and he is excited to help me build the new motor as well. AndyF and Dwayne helped out with parts as well! Going full speed ahead on a 540, Molnar crank/rods, ATI balancer, Diamond 11:1 pistons ordered through another local friend, 0.060" quench so it's got a wider tuning window for nitrous (or if I ever swap it to procharger or turbo), total overkill BAM DLC lifters, cometics, Andy's billet timing cover/button setup and a rollmaster timing chain, modest Comp custom solid roller, Indy 440-2 intake, Moroso 7 qt pan and 1/2" pickup, Melling HV pump, HS e series rockers. I also have King coated rod bearings, and a set of Clevite 3/4 groove main bearings- I also have a set of King XP series main bearings ordered and I was going to use whichever set had better overall clearances. They were supposed to ship last week, but are now indicating May. Going to run it initially with the 1 7/8" headers, plate kit and 850 Holley, but expect to eventually swap it to either a Dominator or a Dominator-sized FI unit. Tom Bailey wanted drag and drive cars in his Sick the Mag display at Autorama next week so I'm in for that. Afterward I'm going to get the rear seatcovers redone and a rollbar put in it before Sick Summer. I also want to install the tailpipes and cutouts before then so it's a little quieter for the street drives. Then between Sick Summer and Drag Week I'll try to get the new motor in if it's assembled, dynoed and ready to go. Hoping it goes mid-low 11's on motor with the 540 and then can spray it to low 10's for Street Machine Eliminator. No shortage of work and my wallet is definitely on fire! ![panic panic](/ubbthreads/images/graemlins/custom/panic.gif)
![Name: autorama.jpg
ID: 502791 autorama.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/502791/filename/autorama.jpg)
[Re: Blusmbl]
#3216000
02/25/24 09:56 AM
02/25/24 09:56 AM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
Cool beans buddy, sounds like you're setting yourself up for the future really well.
Rich H.
Esse Quam Videri
