Page 3 of 5 1 2 3 4 5
Re: Intake porting? [Re: AndyF] #3194916
12/02/23 03:06 PM
12/02/23 03:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Originally Posted by AndyF
Yeah, sheet metal intakes are often R&D projects, especially for something like a BB Mopar engine. There might be some "proven" sheet metal designs for popular SBC and BBC heads but I really doubt a person could order up a sheet metal intake for a BB Mopar and have it be better than a Wilson ported cast intake right out of the box. Maybe by the time you buy three sheet metal intakes the third version will be singing on the dyno, but I bet the first one is a door stop. About the only way to win the sheet metal intake derby is to partner up with a NHRA super stock guy and buy his year old stuff. Typically their year old stuff is better than anything else on the market.
I would disagree with this statement. Buy the intake from the right person and it WILL pickup power. The difference between a full ported cast intake done by someone who knows what they are doing and a sheet metal intake done by a qualified person who knows what they are doing will pickup power period......Been down this road a number of times.
The one thing I have seen MANY times with ported cast intakes is folks doing them who have no clue what they are doing, or what they are trying to accomplish.
Re: Intake porting? [Re: Al_Alguire] #3195344
12/04/23 05:30 PM
12/04/23 05:30 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The coolest porting / fabricating work is what they do in FAST.
Take the upper plenum of a dual plane and block it off completely from the plenum, then completely Gut the floor out of the lower plenum and build a new larger floor from underneath...then join all 8 port runners and you build a Stealth big volume single plane manifold, the big runners also now have a huge open plenum and it all looks stock.
Coat the bottom of the "inverted single plane" with high temp themal barrier ceramic coating to keep the oil heat away from it. All it takes is ingenuity and cubic dollars!
WIZE
In Car:
Re: Intake porting? [Re: Streetwize] #3195356
12/04/23 06:48 PM
12/04/23 06:48 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Sounds cool, have any pics?
Re: Intake porting? [Re: LSP] #3195361
12/04/23 07:45 PM
12/04/23 07:45 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I did mine a little different than what Wise describes, I think the floor was too high. Dyno testing proved that the plenum was too small. Still, it picked up over 35 horse compared to the Vanke Mod.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Intake porting? [Re: Hemi_Joel] #3195364
12/04/23 07:58 PM
12/04/23 07:58 PM
AndyF Offline
AndyF  Offline
Pretty wild. So that ended up as a big volume single plane intake but it still looks like a dual plane from the outside? I had not seen that before but it makes sense.
Re: Intake porting? [Re: AndyF] #3195371
12/04/23 08:14 PM
12/04/23 08:14 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Yes, that's the gist of it. It was a really fun project, but it was purely experimental- there was no way to know if it would work until it was done and tested. Thankfully it worked out. I used 2 intakes that had already had some butchery so I got them fairly reasonable on ebay.
Re: Intake porting? [Re: Streetwize] #3195437
12/05/23 10:35 AM
12/05/23 10:35 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
This gives me some ideas. I already cut the bottom out of an intake, but my issue is I have a cast iron intake, what you are talking about is a lot easier to do with an aluminum intake.
Re: Intake porting? [Re: JohnRR] #3195492
12/05/23 02:47 PM
12/05/23 02:47 PM
moparx Offline
moparx  Offline
i wonder how something like that would work on a CH4B intake.
beer
Re: Intake porting? [Re: moparx] #3195493
12/05/23 03:02 PM
12/05/23 03:02 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
From the Facebook Factory Appearing site
WIZE
In Car:
Re: Intake porting? [Re: Streetwize] #3195500
12/05/23 03:25 PM
12/05/23 03:25 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I saw this on there...the poster also said it was currently used as a door stop.
As for Super Stock...the multi carb guys are using sheet metal, single carb are still starting with cast intakes from what I've seen. Usually Victors.
Re: Intake porting? [Re: sixpakdodge] #3195509
12/05/23 04:10 PM
12/05/23 04:10 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Oh Yeah I read that too, but I think the concept is sneaky and if it's executed correctly it could work....or possibly does work and we don't even know it.
but LSP asked about pictures....so. If nothing else I hope the pics of the 'doorstop' help people understand the stealthy concept.
There's maybe only a few combos that would benefit from it...like a stroked 71-72 340 TQ or something else with a tall deck and a deep valley...maybe a stroked 455 olds or Pontiac.
You could Conceivably model a known "good" single plane and copy its cross sectional areas (as best as you can) but you'll still lose something in the obviously poor approach angles to the heads.
It would be interesting to make a very thin mold of just the very top outside of a factory intake..... just to see what is conceivable to fit underneath it. work
to stick with a dual plane you would have to get the 4 common paired plenums as large as possible because they feed the individual runners and with a bit of taper toward the carb they can act like 2 larger "main" plenums, the biggest restriction are the inevitable acute angles mainly to the inboard 3-4-5-6 cylinders.
WIZE
In Car:
Re: Intake porting? [Re: sixpakdodge] #3195520
12/05/23 04:53 PM
12/05/23 04:53 PM
AndyF Offline
AndyF  Offline
That is what I've seen too. The sheet metal stuff doesn't seem to work very well for single carb. Works great for dual carbs. I think it is because the curved runners are too hard to make in sheet metal.
Re: Intake porting? [Re: AndyF] #3195629
12/06/23 10:28 AM
12/06/23 10:28 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
It wasn't that long ago that I came across pics of a single-plane sheetmetal intake for the first time and didn't realize anyone even made them
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Intake porting? [Re: Streetwize] #3195631
12/06/23 10:34 AM
12/06/23 10:34 AM
U.S.S.A.
U.S.S.A.
I missed that one , I'll have to go back to find it.
Re: Intake porting? [Re: JohnRR] #3195633
12/06/23 10:47 AM
12/06/23 10:47 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
The pics were posted in the comments on the low deck intake post over the weekend.
Re: Intake porting? [Re: sixpakdodge] #3195655
12/06/23 12:33 PM
12/06/23 12:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Single 4 "box ram" style intake work VERY well. They dont make any cast ones for a Mopar but a sheetmetal version works very well. We have a few in the NA ranks and you will find them in comp as well.
Re: Intake porting? [Re: sixpakdodge] #3195844
12/07/23 10:34 AM
12/07/23 10:34 AM
U.S.S.A.
U.S.S.A.
Thanks , that explains why I couldn't find them
Re: Intake porting? [Re: JohnRR] #3195867
12/07/23 11:40 AM
12/07/23 11:40 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Rhett posted a thread last year on FABO about the whole build process involved with his SB FAST intake.
Time flies….. it was a few years ago……..
https://www.forabodiesonly.com/mopa...lass-and-needed-a-winter-project.480041/
Re: Intake porting? [Re: Hemi_Joel] #3196624
12/11/23 09:51 AM
12/11/23 09:51 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice work! Thanks for sharing.
Re: Intake porting? [Re: HardcoreB] #3196628
12/11/23 10:00 AM
12/11/23 10:00 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I wonder if the people who set up F.A.S.T. had any idea the extent to which people would go to build these things... and if it's even in the spirit of the original rules wink
