Automatic Fire Suppression?
#3195359
12/04/23 07:30 PM
12/04/23 07:30 PM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
After seeing this video, I am thinking about an automatic fire suppression system. I was already planning to add a manually activated system. What are the pros and cons of automatic? Is there much risk of unintended activation? Thanks, Joel https://youtu.be/DUS5tYBLycc?feature=shared
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Automatic Fire Suppression?
[Re: Hemi_Joel]
#3195366
12/04/23 08:00 PM
12/04/23 08:00 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I don't have an automatic, but I do have a manual pull system in one of my cars just in case.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Hemi_Joel]
#3195370
12/04/23 08:13 PM
12/04/23 08:13 PM
Posts: 54 VA Beach, VA
Runnoft
VA Beach, VA
I've had (2) 10lb systems in my car for going on 5 years now. One circuit is heat sensing auto discharge I use for the drivers area and the other is manual activation for the engine bay. I can't think of any negatives for the system, other than being kind of pricey, and the auto side can be manually activated too if I need it. It's made by Spa Technique and uses a liquid filled glass bulb to hold the valve shut very similar to a fire sprinkler system you would find in a public building. The activation temp on the auto discharge is 175 degrees.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116. Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
[Re: Hemi_Joel]
#3195372
12/04/23 08:23 PM
12/04/23 08:23 PM
Posts: 22,696 Bitopia
jcc
Bitopia
That was sobering. A few things I didn't hear addressed or I missed: 1. A tree should not be near any race track 2, Did the car have a rated real fuel safety cell? 3. Was the cell caged at all? 4. Most automatic fire suppression systems are only active for around 15? sec, he mentioned fuel kept reigniting, and granted 15 sec of less burn time is still a big plus. 5. Did fuel pump have an automatic crash cut off switch? 6. Contrasting colors of suits and belts should be a requirement. 7. My preference is for a dual suppression system, automatic in fuel cell area, and another manual for driver and engine 8. I respect the driver for candid sharing and voiced concern to help prevent others from ever having the same fate.
Edit, also ought to make few reconsider the track cars that are street driven with fuel lines running out the rear of an exposed tank to a nearby high-capacity electric fuel pump that is mounted a few inches from the bumper. It won't take much to heat up your day up when a texting driver shoves the rear of your car into the car ahead of you while you are sitting at a red light with now jammed doors wearing a tee shirt and flip flops while out for a weekend cruise with your wife.
[Re: jcc]
#3195518
12/05/23 04:39 PM
12/05/23 04:39 PM
Posts: 9,835 MI, usa
dvw
MI, usa
Mine s a 10lb manual. Drivers compartment and engine compartment. The electrical shut off is cable connected to lever on the cage. With one arm movement I can swipe the electrical and the fire bottle. Nothing by the cell. But it is firewalled in the trunk. Doug
