Re: We’re you happy with your Borgeson steering box swap?
[Re: MarkZ]
#3195214
12/03/23 08:30 PM
12/03/23 08:30 PM
Posts: 6,279 nowhere
Sniper
nowhere
I really do not understand the issues people have been having. I ordered everything through Bergman Autocraft so it included all the fittings, hoses and his column adapter. Box went right in without so much on an issue. This is on an M body that nobody makes [censored] for or even takes into consideration when designing kits. Completely took the slop out of the steering. I've installed two of these kits on separate cars. Just order it all through Bergman! Yes, it seems those that went thru Bergman, who has spent the time to sort it out, have had no or minimal issues. Those who thought they could save a few dollars doing it themselves forget to account for the cost of their time and aggravation. I am generally of the second group, but in some cases it makes sense to go with the already well sorted out kit. This is one of those times.
[Re: MarkZ]
#3195217
12/03/23 08:50 PM
12/03/23 08:50 PM
Posts: 623 Zombieland
Car Nut
Zombieland
I really do not understand the issues people have been having. I ordered everything through Bergman Autocraft so it included all the fittings, hoses and his column adapter. Box went right in without so much on an issue. This is on an M body that nobody makes [censored] for or even takes into consideration when designing kits. Completely took the slop out of the steering. I've installed two of these kits on separate cars. Just order it all through Bergman! Good point I forgot to mention that I did too, he makes the install so easy.
[Re: TJP]
#3195318
12/04/23 02:52 PM
12/04/23 02:52 PM
Posts: 4,431 Michigan
MarkZ
Worthy
Worthy
I really do not understand the issues people have been having. I ordered everything through Bergman Autocraft so it included all the fittings, hoses and his column adapter. Box went right in without so much on an issue. This is on an M body that nobody makes [censored] for or even takes into consideration when designing kits. Completely took the slop out of the steering. I've installed two of these kits on separate cars. Just order it all through Bergman! Mark, I for one was not even aware of the refined Bergman kit but did make note of it. My experiences across multiple vehicle makes as stated are with the borgeson Half a-- kits that are far from the "bolt in" they make one think it is. I too have well equipped shop and have been able to address MOST of the issues as AndyF commented. The OP asked about Borgeson and like me may not have been aware of Bergman's refined kits. My experiences in a few cases required trying multiple fluid brands and Adding oil coolers to keep the fluid temp down to alleviate chattering, groaning atc at low speeds or when stopped and turning the wheels. Not sure Bergman has a fix for that based on an earlier post. Borgeson may have also come up with a solution but i wouldn't count on it No offense meant just responding to you question None taken! I think I may have come off a little strong in that post too. I should add some context. Both the boxes I have are gen 2 pieces and I know that the 1st gen boxes did have issues, especially with the case and the welded on mounting ears.
[Re: MarkZ]
#3195365
12/04/23 08:00 PM
12/04/23 08:00 PM
Car Nut
Zombieland
I really do not understand the issues people have been having. I ordered everything through Bergman Autocraft so it included all the fittings, hoses and his column adapter. Box went right in without so much on an issue. This is on an M body that nobody makes [censored] for or even takes into consideration when designing kits. Completely took the slop out of the steering. I've installed two of these kits on separate cars. Just order it all through Bergman! Mark, I for one was not even aware of the refined Bergman kit but did make note of it. My experiences across multiple vehicle makes as stated are with the borgeson Half a-- kits that are far from the "bolt in" they make one think it is. I too have well equipped shop and have been able to address MOST of the issues as AndyF commented. The OP asked about Borgeson and like me may not have been aware of Bergman's refined kits. My experiences in a few cases required trying multiple fluid brands and Adding oil coolers to keep the fluid temp down to alleviate chattering, groaning atc at low speeds or when stopped and turning the wheels. Not sure Bergman has a fix for that based on an earlier post. Borgeson may have also come up with a solution but i wouldn't count on it No offense meant just responding to you question None taken! I think I may have come off a little strong in that post too. I should add some context. Both the boxes I have are gen 2 pieces and I know that the 1st gen boxes did have issues, especially with the case and the welded on mounting ears. When did you purchase the G2 box?
[Re: Car Nut]
#3195384
12/04/23 09:55 PM
12/04/23 09:55 PM
MarkZ
Worthy
Worthy
When did you purchase the G2 box? Spring of 2015.
[Re: MarkZ]
#3195385
12/04/23 10:02 PM
12/04/23 10:02 PM
Car Nut
Zombieland
When did you purchase the G2 box? Spring of 2015. OK, thanks, that’s about when I bought mine too.
[Re: Sniper]
#3195404
12/04/23 11:40 PM
12/04/23 11:40 PM
Posts: 21,648 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
Thanks for the link. I see they refined the kit and is a minimal hassle bolt in now. With a final cost of $1500 (sipping and taxes), it's not looking it's worth the swap for the minimal return in steering improvement. Tanks again for all the info guys.
[Re: migsBIG]
#3195583
12/05/23 11:26 PM
12/05/23 11:26 PM
Posts: 15,408 Omaha Ne
TJP
Omaha Ne
