Re: B/RB hydraulic roller lifters which ones are good now [Re: AndyF] #3194351
11/30/23 02:40 AM
11/30/23 02:40 AM
Cab_Burge Offline OP
Thanks for that Andy up bow
Re: B/RB hydraulic roller lifters which ones are good now [Re: MarkZ] #3194456
11/30/23 12:28 PM
11/30/23 12:28 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted by MarkZ
I'm following this as well. I'm running Comp retrofit lifters in my big block and while I could stand the noise at first, now it's just grating. To the point I'd be willing to drop $1k on new lifters to shut it up if that is an option.
A friend had this problem in his 440 Dart. He asked what I was using and ended up buy a set of Howards hydraulic rollers. Replaced the Comp's and everything was fine. Comp's are hot garbage!
'63 Dodge 330
11.19 @ 121 mph
Re: B/RB hydraulic roller lifters which ones are good now [Re: Car Nut] #3194457
11/30/23 12:29 PM
11/30/23 12:29 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted by Car Nut
Originally Posted by GY3
Close to 9,000 miles on my Howards with hundreds of dragstrip passes.
No issues at all and quiet as can be.
Can you post the item number of the Howards?
It's been 8 years and I don't recall the number nor do I have it written down. Sorry, I'm usually good about remembering numbers but not this time. LOL
'63 Dodge 330
11.19 @ 121 mph
Re: B/RB hydraulic roller lifters which ones are good now [Re: GY3] #3194520
11/30/23 03:57 PM
11/30/23 03:57 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
We have had issues with all of the different brands. Luckily, we have enough inventory of most that if we get a bad lifter. We swap it from another set and then when we accumulate an entire set of 16 bad lifters. I then return that full defective set.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: B/RB hydraulic roller lifters which ones are good now [Re: 6PKRTSE] #3194568
11/30/23 08:56 PM
11/30/23 08:56 PM
Do mind sharing how you're identifying the bad ones? help luck
Re: B/RB hydraulic roller lifters which ones are good now [Re: Cab_Burge] #3194584
11/30/23 09:50 PM
11/30/23 09:50 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
We have a test fixture that we made while the lifters are submerged in oil we pump them over and over. If they pass that. Then we dyno test every engine. Some pass the text fixture test even and then fail on dyno. Quality on everything today is getting unbearable.
