Looking for recommendations on rocker arms. #3194329
11/29/23 10:52 PM
11/29/23 10:52 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
So I’m needing rocker arm assembles and probably shafts as the heads I’m ordering for a big block won’t come with them. Looking around, looks like there are over twenty brands and styles for sale on big block engines. Std, roller, adjustable, steel, ductile iron an aluminum material, just to name the basics. I’m looking at one engine to be just a fun street 440 not sure what to get. Would stamped steel rockers work, or should I upgraded? Any brand or company offering nice ones out there? Also, engine power is going to be resto with maybe 100-150hp over stock.
Re: Looking for recommendations on rocker arms. [Re: migsBIG] #3194330
11/29/23 11:03 PM
11/29/23 11:03 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
Stamped steel work for a stocker with less than .509 hydraulic cams. If you gotta buy shafts, hold downs, and hardware, these are a great deal by Mancini Racing. Made by Harland Sharp.
Here's the link. Item #: MRE57001-15-714K
Re: Looking for recommendations on rocker arms. [Re: migsBIG] #3194354
11/30/23 03:38 AM
11/30/23 03:38 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
440 Source has started selling the old ductile iron rockers. Price seems to be very reasonable.
America First!
Re: Looking for recommendations on rocker arms. [Re: migsBIG] #3194388
11/30/23 09:59 AM
11/30/23 09:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Hyd or soild ?
The valvetrain is the last place to cheap out , it will cost thousands more to fix the carnage below a dropped valve than the few dollars you save buying cheap chinese junk.
Re: Looking for recommendations on rocker arms. [Re: JohnRR] #3194501
11/30/23 02:14 PM
11/30/23 02:14 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Hyd or soild ?
Still working out the specs. Like to have a a little chop to it but have to decide i I'm running a brake booster or manual brakes for my vacuum needs. Not a fan of some Chinese stuff either, but not looking to save too much and compromise the drivetrain.
Re: Looking for recommendations on rocker arms. [Re: jcastle1] #3194525
11/30/23 04:20 PM
11/30/23 04:20 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
If running a hyd f t.. I am running a Comp Cams XE295H cam with 519/.524 lift with stock stamp rockers in one of my 440's and drive it everywhere during nice weather with over 55,000+ on the engine so far.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Looking for recommendations on rocker arms. [Re: 6PKRTSE] #3194992
12/02/23 08:30 PM
12/02/23 08:30 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
A - Comp XE295HL has .564 Lift
The XE275HL has .525 Lift - I have been running that cam in my 383 Stroker for about six summers now with E Street Heads and Sealed Power Stamped Steel Rockers and shafts (Made in the USA)
Does anyone make a decent stamped steel rocker anymore ? They where scarce four or five years ago already , and the Elgins that I had in my hands where complete junk
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Looking for recommendations on rocker arms. [Re: migsBIG] #3195009
12/02/23 09:49 PM
12/02/23 09:49 PM
Sit down and figure out the entire package before you start buying any parts, buy the best parts you can and have fun without worry after that up twocents work scope up
Re: Looking for recommendations on rocker arms. [Re: bee1971] #3195022
12/02/23 11:08 PM
12/02/23 11:08 PM
Central NC
gch Offline
gch  Offline
Central NC
I think 440 Source just came out with new stamped steel rockers with new shafts. Can't speak to the quality but at least someone is making them.
https://store.440source.com/Rocker-Arm-Shaft-Assemblies-Factory-Style-COMPLETE/productinfo/105-1024/
Re: Looking for recommendations on rocker arms. [Re: Cab_Burge] #3195186
12/03/23 06:22 PM
12/03/23 06:22 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Going to the machine shop this week to talk on parts for the build.
