Page 2 of 3 1 2 3
Re: External Oil Pump One Way Valve Mounting [Re: B1MAXX] #3193713
11/27/23 06:34 PM
11/27/23 06:34 PM
Cab_Burge Online work
Cab_Burge  Online Work
Actually those (Moroso maybe) inline AN filters where design for that application up
I ended up breaking two oil pump drives on that deal before removing the pump and taking it apart realcrazy One was a new Hi Po Mopar brand and the other was good use stock one, they both snap, twisted off, around the exact same place on the tips whiney
I had to borrow the third one to run that race, I replace it later in that year at another division race up
Re: External Oil Pump One Way Valve Mounting [Re: Cab_Burge] #3193723
11/27/23 06:54 PM
11/27/23 06:54 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
too bawlzy for me. Them engines can barley oil themselves in a perfect world, when you start to get past 6900-7000.
Re: External Oil Pump One Way Valve Mounting [Re: B1MAXX] #3193738
11/27/23 07:28 PM
11/27/23 07:28 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Im with B1MAX... these motors (B/RB/Hemi) have been raced for over 50 years with little to no modification to the external oiling set up but for some reason this one is special????? I think there is an issue that a check valve will not help. But thats my 40 yrs experience talking so I may be wrong twocents
As a point of consideration...every fitting.connection will cause a disturbance in flow (reduced flow) and most if not all of us that have had check valves in any type of system have never seen them fail....as an example I had a check in the oil cooler line on my Bruno, it (the Bruno) got hot enough to melt the DOT spec vent hose laying on the case, why shruggy because a piece of debris got in the check and wouldn't let it open (the pressure side) want to bet whats going to happen on the suction side???
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: External Oil Pump One Way Valve Mounting [Re: B1MAXX] #3193746
11/27/23 07:45 PM
11/27/23 07:45 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Heck the factory will bypass the filter on the pressure side before hurting anything.
The reason I’m not using a filter on my 340, pump feeds straight up to galleys not through all those 90* bends and through a filter that restricts flow. If your pump stops working (0 pressure) let’s see you kill the engine before it blows. By the time it drops it’s already over and gone. Filters are for street cars.
Re: External Oil Pump One Way Valve Mounting [Re: cudaman1969] #3193752
11/27/23 08:17 PM
11/27/23 08:17 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Seems the least harm here can come from a check valve on the pressure side, not the vacuum side. Oil CANNOT leave the immersed suction side unless somehow air to replace the leaking oil can somehow gain entry, and a pressure side check would "check" both air and oil, regardless of loops, fittings, etc.
How/where you can place a check valve on the pressure side for a BBM is above my pay grade.
Re: External Oil Pump One Way Valve Mounting [Re: B1MAXX] #3193754
11/27/23 08:21 PM
11/27/23 08:21 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
The closer the oil is to the pump ,the quicker it will prime. I had this problem using a Milodon aluminum pump with internal pick up. The pump needed a bigger O ring on the snout/drive end of the pump. It will suck air if that orific is not sealed.
Re: External Oil Pump One Way Valve Mounting [Re: mopar dave] #3193786
11/27/23 10:01 PM
11/27/23 10:01 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Short line mock up.
While I am concerned about the check valve restriction, I have to keep reminding myself that on my “race” motor that I spin 7500 it uses a 3/8 internal pickup and the bearings always look good on it when i take it down. Even with the restrictions on a 12AN line it seems it has to be getting more oil than the internal 3/8 pickup. I was first concerned about the 120 degree fitting at the oil pump being a restriction but it does hold 80lbs at idle.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: External Oil Pump One Way Valve Mounting [Re: clovis] #3193790
11/27/23 10:42 PM
11/27/23 10:42 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I like to think I'm familiar with every Milodon Mopar oil pump of the last 50 years but I've never seen one like that.
2011 Drag Pak Challenger
Re: External Oil Pump One Way Valve Mounting [Re: rickseeman] #3193822
11/28/23 05:05 AM
11/28/23 05:05 AM
work Me too, maybe confused
Re: External Oil Pump One Way Valve Mounting [Re: Cab_Burge] #3193827
11/28/23 07:59 AM
11/28/23 07:59 AM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
It is what you get when order a 21815 (the photo is old to new design)-it just has a Meiling pump cover on it. I called Milodon and they had no reservations with me using the stock style cover on it. It is the same with the their pump cover with the OEM style pump, I think they are designed to be used with OEM parts.
'75 Plymouth Duster
Re: External Oil Pump One Way Valve Mounting [Re: clovis] #3193832
11/28/23 09:06 AM
11/28/23 09:06 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
As has been mentioned, the one-way valve might be restrictive!!!
Re: External Oil Pump One Way Valve Mounting [Re: HardcoreB] #3193849
11/28/23 10:52 AM
11/28/23 10:52 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Guess you haven't looked in a Milodon catalog in the past ten years ... these aren't new !!
FWIW, now that I see the pump open I recall drain back issues being related to the design of Milodon's rotor design. If you were using a standard HV pump with a Milodon block plate for external pickup you would have no issues with drain back.
Re: External Oil Pump One Way Valve Mounting [Re: Stanton] #3193851
11/28/23 10:57 AM
11/28/23 10:57 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted by Stanton
Quote
Interesting on what you say there, I have one of each type vanes and debating which would be better.
Re: External Oil Pump One Way Valve Mounting [Re: cudaman1969] #3193882
11/28/23 12:54 PM
11/28/23 12:54 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The rotor/vane issue goes so far back most are too old to remember it. But the issue is real.
Re: External Oil Pump One Way Valve Mounting [Re: Stanton] #3194093
11/29/23 07:55 AM
11/29/23 07:55 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Use one of the Peterson primer remote filter mounts. Spin it with a cordless till you have pressure and go. I would check both fitting hose joints on the suction side. If you're loosing prime you have an air leak period.
Re: External Oil Pump One Way Valve Mounting [Re: fbs63] #3194113
11/29/23 10:25 AM
11/29/23 10:25 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I don't like external filters but those things are so sexy.
Re: External Oil Pump One Way Valve Mounting [Re: rickseeman] #3194117
11/29/23 10:47 AM
11/29/23 10:47 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Now if we could only get Peterson to incorporate a pre-screen, we would be all set.
Re: External Oil Pump One Way Valve Mounting [Re: jcc] #3194165
11/29/23 01:32 PM
11/29/23 01:32 PM
an8sec70cuda Offline
Here's what I've run on my hemi for many years w/ no issues at all. Milodon pump w/ a stock cast iron pump cover. 7200+ rpm.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: External Oil Pump One Way Valve Mounting [Re: B1MAXX] #3194213
11/29/23 05:11 PM
11/29/23 05:11 PM
Canada
RobR Offline
RobR  Offline
Canada
I've always used a 180 degree fitting on the top and never ever had a no prime issue.Now before I started using a 180 on the top nothing but problems.The 180 has to go over the top of the oil pump and against the block for it to work.
Re: External Oil Pump One Way Valve Mounting [Re: an8sec70cuda] #3194216
11/29/23 05:25 PM
11/29/23 05:25 PM
Who popped a wheelie and bashed his oil pan on the return to earth whistling
I'm glad it didn't tear it open bow up
Page 2 of 3 1 2 3
