Re: External Oil Pump One Way Valve Mounting
[Re: B1MAXX]
#3193713
11/27/23 06:34 PM
11/27/23 06:34 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
Actually those (Moroso maybe) inline AN filters where design for that application ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I ended up breaking two oil pump drives on that deal before removing the pump and taking it apart ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif) One was a new Hi Po Mopar brand and the other was good use stock one, they both snap, twisted off, around the exact same place on the tips ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) I had to borrow the third one to run that race, I replace it later in that year at another division race ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: B1MAXX]
#3193738
11/27/23 07:28 PM
11/27/23 07:28 PM
Posts: 2,122 Byron, NY
W.I.N. Racing
Byron, NY
too bawlzy for me. Them engines can barley oil themselves in a perfect world, when you start to get past 6900-7000. Im with B1MAX... these motors (B/RB/Hemi) have been raced for over 50 years with little to no modification to the external oiling set up but for some reason this one is special????? I think there is an issue that a check valve will not help. But thats my 40 yrs experience talking so I may be wrong ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) As a point of consideration...every fitting.connection will cause a disturbance in flow (reduced flow) and most if not all of us that have had check valves in any type of system have never seen them fail....as an example I had a check in the oil cooler line on my Bruno, it (the Bruno) got hot enough to melt the DOT spec vent hose laying on the case, why ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) because a piece of debris got in the check and wouldn't let it open (the pressure side) want to bet whats going to happen on the suction side???
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: B1MAXX]
#3193746
11/27/23 07:45 PM
11/27/23 07:45 PM
Posts: 8,351 fredericksburg,va
cudaman1969
fredericksburg,va
Heck the factory will bypass the filter on the pressure side before hurting anything. The reason I’m not using a filter on my 340, pump feeds straight up to galleys not through all those 90* bends and through a filter that restricts flow. If your pump stops working (0 pressure) let’s see you kill the engine before it blows. By the time it drops it’s already over and gone. Filters are for street cars.
[Re: cudaman1969]
#3193752
11/27/23 08:17 PM
11/27/23 08:17 PM
Posts: 22,732 Bitopia
jcc
Bitopia
Seems the least harm here can come from a check valve on the pressure side, not the vacuum side. Oil CANNOT leave the immersed suction side unless somehow air to replace the leaking oil can somehow gain entry, and a pressure side check would "check" both air and oil, regardless of loops, fittings, etc. How/where you can place a check valve on the pressure side for a BBM is above my pay grade.
[Re: mopar dave]
#3193786
11/27/23 10:01 PM
11/27/23 10:01 PM
Posts: 554 Kentucky
clovis
Kentucky
Short line mock up. While I am concerned about the check valve restriction, I have to keep reminding myself that on my “race” motor that I spin 7500 it uses a 3/8 internal pickup and the bearings always look good on it when i take it down. Even with the restrictions on a 12AN line it seems it has to be getting more oil than the internal 3/8 pickup. I was first concerned about the 120 degree fitting at the oil pump being a restriction but it does hold 80lbs at idle.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: clovis]
#3193790
11/27/23 10:42 PM
11/27/23 10:42 PM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I like to think I'm familiar with every Milodon Mopar oil pump of the last 50 years but I've never seen one like that.
2011 Drag Pak Challenger
[Re: Cab_Burge]
#3193827
11/28/23 07:59 AM
11/28/23 07:59 AM
Posts: 554 Kentucky
clovis
Kentucky
It is what you get when order a 21815 (the photo is old to new design)-it just has a Meiling pump cover on it. I called Milodon and they had no reservations with me using the stock style cover on it. It is the same with the their pump cover with the OEM style pump, I think they are designed to be used with OEM parts.
[Re: HardcoreB]
#3193849
11/28/23 10:52 AM
11/28/23 10:52 AM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I like to think I'm familiar with every Milodon Mopar oil pump of the last 50 years but I've never seen one like that. Guess you haven't looked in a Milodon catalog in the past ten years ... these aren't new !! FWIW, now that I see the pump open I recall drain back issues being related to the design of Milodon's rotor design. If you were using a standard HV pump with a Milodon block plate for external pickup you would have no issues with drain back.
[Re: Stanton]
#3193851
11/28/23 10:57 AM
11/28/23 10:57 AM
cudaman1969
fredericksburg,va
I like to think I'm familiar with every Milodon Mopar oil pump of the last 50 years but I've never seen one like that. Guess you haven't looked in a Milodon catalog in the past ten years ... these aren't new !! FWIW, now that I see the pump open I recall drain back issues being related to the design of Milodon's rotor design. If you were using a standard HV pump with a Milodon block plate for external pickup you would have no issues with drain back. Interesting on what you say there, I have one of each type vanes and debating which would be better.
[Re: rickseeman]
#3194117
11/29/23 10:47 AM
11/29/23 10:47 AM
jcc
Bitopia
Now if we could only get Peterson to incorporate a pre-screen, we would be all set.
[Re: jcc]
#3194165
11/29/23 01:32 PM
11/29/23 01:32 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Here's what I've run on my hemi for many years w/ no issues at all. Milodon pump w/ a stock cast iron pump cover. 7200+ rpm.
[Re: an8sec70cuda]
#3194216
11/29/23 05:25 PM
11/29/23 05:25 PM
Cab_Burge
Here's what I've run on my hemi for many years w/ no issues at all. Milodon pump w/ a stock cast iron pump cover. 7200+ rpm. Who popped a wheelie and bashed his oil pan on the return to earth ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) I'm glad it didn't tear it open ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
