Rocker shaft hold down #3192067
11/19/23 06:24 PM
11/19/23 06:24 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
I lost an end one for a 516 head so before I look for one are the ones on the 62-63 max wedge head the same?
Re: Rocker shaft hold down [Re: cudaman1969] #3192159
11/20/23 10:38 AM
11/20/23 10:38 AM
Mopar quit using that type of rocker shaft hold owns on B and RB motors in 1963, none of the later head 6 bolt rocker arms heads like all the 516 head came with them on the motors is what I'm remembering twocents
I've only had 1 or 2 sets of the 1964 stage Three M.W. head casting that came with the 6 bolt valve covers and the later rocker shaft hold downs so I may be wrong on ALL the real early stage three castings having the built in rocker shaft stands work shruggy
Re: Rocker shaft hold down [Re: Cab_Burge] #3192170
11/20/23 11:11 AM
11/20/23 11:11 AM
fredericksburg,va
fredericksburg,va
Well my 63 max had stands like the one pictured, reason I asked if they were the same as 516 head
Re: Rocker shaft hold down [Re: cudaman1969] #3192203
11/20/23 02:12 PM
11/20/23 02:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The parts book does show a difference in the MW bracket, don't know why. shruggy
Re: Rocker shaft hold down [Re: John_Kunkel] #3192212
11/20/23 03:04 PM
11/20/23 03:04 PM
The ductile iron adjustable rocker arms are wider so the hold downs need to be narrower, Mopar added small bosses, ears, on both sides at the top for the stamp steel rocker stands, they can be used by removing, them wrench no big deal scope up
Re: Rocker shaft hold down [Re: Cab_Burge] #3192227
11/20/23 04:07 PM
11/20/23 04:07 PM
fredericksburg,va
fredericksburg,va
I’ll be using the iron rockers, I can see what you’re saying about that edge part. If I could run across a set of 67 heads (915) with small exhaust I won’t need to do the 516 heads. I want to keep the closed chamber.
Re: Rocker shaft hold down [Re: cudaman1969] #3192233
11/20/23 04:30 PM
11/20/23 04:30 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
You know that newer 516 heads also have the cast in rocker holders and have the closed chamber? If you are ok with 516 why not just go with a newer 516?
Re: Rocker shaft hold down [Re: markz528] #3192250
11/20/23 06:06 PM
11/20/23 06:06 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
My 64 300 had those hold downs, the engine was stamped with a T then over stamped with a V. I think those head casting numbers, 4 bolt valve cover, rocker stands, ended in 3200?
I couldn't get the aluminum stands off the steel shafts so my solution was to get a set of NOS 906 heads from Len Dawson, this was in the late 80's when you could still get them.
Re: Rocker shaft hold down [Re: markz528] #3192251
11/20/23 06:06 PM
11/20/23 06:06 PM
fredericksburg,va
fredericksburg,va
Yes could do that, I looked at a 64 413 that had those ($500 no intake) but I went with the 413 industrial block with no heads because of the block. It’s just that I have the 63 set on hand.
Re: Rocker shaft hold down [Re: cudaman1969] #3192263
11/20/23 07:15 PM
11/20/23 07:15 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
The Max Wedge rocker stand does not have the little extension at the top inner edge. Some people grind the edge off and pass them off as original.
Re: Rocker shaft hold down [Re: cudaman1969] #3192312
11/20/23 10:29 PM
11/20/23 10:29 PM
Morrow, OH
Morrow, OH
I was in your backyard on Friday. I could of brought you a set of newer 516's.
Re: Rocker shaft hold down [Re: Sniper] #3192339
11/21/23 12:17 AM
11/21/23 12:17 AM
I've remove the stands, it wasn't easy though wrench I think I used a plastic hammer head and drove them off so I could grind some of the rocker main body narrower and to add shims as needed to help position the rocker pad on the center of the valve stems better.
Blueprinting is so much fun realcrazy grin work The endless pursuit of power . realcrazywhistling work up
Re: Rocker shaft hold down [Re: markz528] #3192402
11/21/23 12:47 PM
11/21/23 12:47 PM
fredericksburg,va
fredericksburg,va
[quote=cudaman1969][quote=Cab_Burge
Dang!
Re: Rocker shaft hold down [Re: cudaman1969] #3194083
11/29/23 05:27 AM
11/29/23 05:27 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Re: Rocker shaft hold down [Re: 451Mopar] #3194214
11/29/23 05:17 PM
11/29/23 05:17 PM
I bought several sets of the Mopar brand steel W2 race hold downs years ago, there still in one of the parts cabinet waiting for me to use them realcrazy shruggy
