Re: Coffee
[Re: cudaman1969]
#3190156
11/10/23 10:05 PM
11/10/23 10:05 PM
Guitar Jones
Yeah, to weak the second time around, I like my coffee like I like my woman, hot, black and strong.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: Coffee
[Re: cudaman1969]
#3190206
11/11/23 08:47 AM
11/11/23 08:47 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I have to have a oversize coffee first thing in the morning. I put 6 tablespoons of “light roast” coffee in a Mellita “pour over” single cup coffee maker and manually pour sixteen ounces of 190 degree water so that all the grounds get a get even wetting. I add three teaspoons of maple syrup to this and begin sipping while I immediately pour another 4 ounces of hot water on the already wet used coffee grounds to make a slightly more bitter small second cup. I like coffee, even though I did not start until age 38 but I also consider it a powerful mixture of drugs because it contains: caffeine Phenylindanes (part of the dark color of coffee comes this chemical) https://www.frontiersin.org/articles/10.3389/fnins.2018.00735/fullIf someone gives you a hard time about drinking twice watered coffee you can answer: “I paid good money for those fresh coffee grounds and I want to get most of the Phenyllindane out of it even if becomes bitter” and it was recently discovered coffee contains trigonelline https://medicalxpress.com/news/2023-09-trigonelline-derived-coffee-cognitive-function.htmlOne of the oldest medicinal herbs, first written about more than 3000 years ago, is the seed of the legume plant “Fenugreek” ( literally “Greek Hay”) which also contains trigonelline. From 11 am to 1 pm I might have a one ounce shot glass of coffee if I begin to feel “blah” as the morning coffee wears off, but no coffee past 2 pm.
Re: Coffee
[Re: cudaman1969]
#3190262
11/11/23 03:14 PM
11/11/23 03:14 PM
Posts: 15,867 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
How many run water through their machine twice? Seems the grounds still have enough left to make good coffee. A waste to use once btw I like mine black on the cool side! I have a Keurig so I use K cups. I've reused them a couple of times when I only make the smallest cup. On Gunsmoke Chester uses the same grounds for several pots! He just boils it up and adds Chicory
Facts are stubborn things.
Re: Coffee
[Re: larrymopar360]
#3190271
11/11/23 04:31 PM
11/11/23 04:31 PM
Posts: 21,507 N.E. OHIO, USA
A12
N.E. OHIO, USA
How many run water through their machine twice? Seems the grounds still have enough left to make good coffee. A waste to use once btw I like mine black on the cool side! I have a Keurig so I use K cups. I've reused them a couple of times when I only make the smallest cup. On Gunsmoke Chester uses the same grounds for several pots! He just boils it up and adds Chicory WWII for sure until there was not tint to it
Re: Coffee
[Re: A12]
#3190279
11/11/23 05:03 PM
11/11/23 05:03 PM
Posts: 8,162 USA
360view
USA
During the Civil War the beans from “Kentucky Coffee Trees” were tried as coffee bean substitutes. I had a friend in Hillsborough NC who had a Kentucky Coffee tree in his yard. He collected his “pods” off his lawn one fall and brought them into a Chapel Hill coffee shop where I helped break the fairly tough pods open and the shop owner/roaster roasted them dark brown and finely ground them. Yuck.... We talked about soaking the grounds in Methyl Chloride to isolate, weigh, and calculate the the caffeine percent, but that never got done 11. It is thought that hunting tribes put large quantities of the seeds into rivers in order to stupefy fish and make them easy to catch. from https://mileshearn.com/2019/09/11/25-kentucky-coffee-tree-facts/In Broward County FL at a farmer’s market I bought small sample bags of Robusta coffee locally grown in a field right up against the Everglades. Taste wasn’t horrible but not good. Hurricane Wilma ruined the young trees. Nestle has a new hybrid coffee tree that resists the Central America coffee rust disease, and can tolerate a range of altitudes and temperatures.
Re: Coffee
[Re: Guitar Jones]
#3190299
11/11/23 06:11 PM
11/11/23 06:11 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Yeah, to weak the second time around, I like my coffee like I like my woman, hot, black and strong. I thought you had said "a hole and a heartbeat" was all they needed to be.
Re: Coffee
[Re: 360view]
#3191538
11/17/23 07:19 AM
11/17/23 07:19 AM
Posts: 8,162 USA
360view
USA
hot off the presses - sample quote Coffee is one of the most consumed beverages and contains polyphenols, such as caffeic acid and chlorogenic acid (CGA), and antioxidants like trigonelline, melanoidins, and the oil cafestol. One study revealed that coffee consumption (at least one cup per day) was associated with a 10% lower COVID-19 risk among the United Kingdom (UK) Biobank participants. { more than 500,000 people} end quote https://www.news-medical.net/news/2...offers-new-dietary-defense-strategy.aspxMy fuzzy memory is that in one of the John Wayne movies a character says: Strong enough Coffee will cure anything...
Re: Coffee
[Re: 360view]
#3192571
11/22/23 09:32 AM
11/22/23 09:32 AM
Posts: 8,162 USA
360view
USA
Crazy Texas used coffee grounds idea: sample quote Caffeic acid belongs to a family of compounds called polyphenols, which are plant-based compounds known for their antioxidant, or free radical-scavenging properties. Caffeic acid is unique because it can penetrate the blood-brain barrier and is thus able to exert its effects upon the cells inside the brain, Narayan said. The process the team uses to extract CACQDs from used coffee grounds is considered "green chemistry," which means it is environmentally friendly. In their lab, the team "cooks" samples of coffee grounds at 200 degrees for four hours to reorient the caffeic acid's carbon structure and form CACQDs. The sheer abundance of coffee grounds is what makes the process both economical and sustainable, Narayan said. end quote more here https://www.news-medical.net/news/2...may-be-found-in-used-coffee-grounds.aspx
