Changing heads #319135
05/15/09 05:29 PM
05/15/09 05:29 PM
Cincinnati,Ohio
P
paulgrr63 Offline OP
P
Cincinnati,Ohio
I have a 318 2bbl and was wondering if I replace the heads with 302 casting heads do I have to change the carb to a 4bbl? I will be upgrading to a dual plane intake and 4bbl carb. Just wondering if It can be done? Can I run the 318 how it is currently and only change the heads?
Re: Changing heads [Re: paulgrr63] #319136
05/15/09 05:46 PM
05/15/09 05:46 PM
I have a SB street dominator and SB streetmaster(SM is in use)4bbl intakes & they both have 318 sized ports & I do believe the 302's have 318 sized ports so yes either a 4bbl small port intake or your current 2bbl one.
