Re: Pull a 318 with the hood on
[Re: stumpy]
#3191470
11/16/23 09:14 PM
11/16/23 09:14 PM
Posts: 5,031 Star Idaho
67vertman
Star Idaho
If you pull the hood be sure to outline the hinge mountings with a marker so you can just put it back where it was. I drill a hole in each hinge the hood and use a pin to relocate it when reinstalling the hood.
My Monster are real!
Living within your means makes life pretty easy.
[Re: 67vertman]
#3191615
11/17/23 02:38 PM
11/17/23 02:38 PM
Posts: 19,878 north of coder
moparx
If you pull the hood be sure to outline the hinge mountings with a marker so you can just put it back where it was. I drill a hole in each hinge the hood and use a pin to relocate it when reinstalling the hood. i have done both of these over the years on all kinds of vehicles, as well as using a scribe to outline the hinge position if one doesn't care about the paint, or will be touching up the paint in that area when the engine transplant is done. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
