ac delco torque adapter #3190629
11/13/23 02:44 PM
11/13/23 02:44 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
Any one used a AC delco digital torque adapter. Thanks
Re: ac delco torque adapter [Re: dragon] #3190825
11/14/23 01:17 PM
11/14/23 01:17 PM
WI
mopar873 Offline
mopar873  Offline
WI
I was in a position to use one when I was helping a friend with an LS build. I didn't get a warm and fuzzy using it at all. It felt and looked light. In fact, I told him I didn't trust it and ran home to get my own mechanical torque wrench. The digital was reading about 5-7 lbs light across the board. Maybe it got dropped or knocked around to take it out of calibration. Or, maybe it was just off that much. I wonder if the fact there are two separate "drives" in operation that there is a falsely high reading because of the added friction.
Re: ac delco torque adapter [Re: dragon] #3191494
11/16/23 09:59 PM
11/16/23 09:59 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
https://www.youtube.com/watch?v=LwuXGgSdhew
Don't know if this helps you at all. Have no personal experience with any of these brands.
My torque wrenches are all old analogue dial face with the exception of one 15 or so year old Snap On digital.
Guy who works for me has new MAC digital torque wrenches with the angle feature. They work well.
Re: ac delco torque adapter [Re: dragon] #3191555
11/17/23 09:25 AM
11/17/23 09:25 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
https://www.amazon.com/ACDelco-ARM6...;hvtargid=pla-4583932713325041&psc=1
looks similar to the Harbor Freight digital unit but in a different outer case colored bright CCP red.
I used the now gone 20% off coupon and bought the Harbor Freight digital intending to return it if was way off.
I had 3 torque wrenches that the instrument shop at Oak Ridge National Labs instrument shop crew had tested for me during their once per year “Family Day.”
The HF digital unit tested +/- 1 ft-lb at 100
I was surprised, but testing 1 is not like testing 20 randomly purchased units.
Remember you can test one torque wrench against another using star shaped sockets.
If you have an accurate weigh scale,
You can also test torque wrenches
by clamping the square drive in a vise
and hanging known weights from a known length handle
when the handle is as near perfectly horizontal when under strain.
Use the cosine of angle correction if the handle angle is not horizontal.
If everything is not moving and still, there cannot be torsional friction at any joint. Friction requires movement.
Do not get too excited about exact torque because torquing a fastener is so inexact anyway. Bolt stretch is way better.
You can test pressure gauges with a high vertical pipe and distilled water.
You can test temperature with the freezing and boiling temperature of distilled water but correct boiling temp for your altitude.
The accuracy of those “gravity wave” detectors is unreal.
