Re: Where exactly is the difference in balance?
[Re: volaredon]
#3189893
11/09/23 05:44 PM
11/09/23 05:44 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I do not know the answer to your questions on what internal parts if any will swap between the LA and Magnum. But while waiting for someone who might know for certain, you could look at www.magnumswap.com for information. They have a lot of good info there and I use it from time to time myself.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: volaredon]
#3189907
11/09/23 06:40 PM
11/09/23 06:40 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
The 5.9 Magnum pistons and Magnum rods are both lighter than the 360 LA piston and rod. The 1995 Ram FSM has the numbers but the correct Magnum 5.9 V8 piston weight numbers and piston drawing are in the V10 engine section of the 1995 FSM. The weight and drawing of a piston in the Magnum 5.9 V8 section of the 1995 FSM are incorrectly the old 1992 TBI 360 V8. I do not think this is corrected even in the 1998 Ram FSM, maybe not in the 2001 FSM. I think from 1995 to 1996 the rear external balance weights went from on the 46RH torque converter to a weighted timing slotted flex plate. I have the book “How to build High Performance Chrysler Engines” by Frank Adkins but it does not have the tables of different weights and lengths. The Book “How to build big inch Mopar Small Block Engines” by Jim Szilagyi might have the tables. https://www.ebay.com/itm/1159026657...msclkid=e77323b2243f10e5796446ff7acf4e7fA machine shop that routinely does engine balancing could do a custom mix job since the 360/5.9 is externally balanced.
[Re: B1MAXX]
#3190025
11/10/23 11:12 AM
11/10/23 11:12 AM
Posts: 8,251 fredericksburg,va
cudaman1969
fredericksburg,va
Here is the difference between a LA 360 and a 380 hp Magnum 360, 380 is .020 over. La is heavier
[Re: volaredon]
#3190379
11/12/23 08:47 AM
11/12/23 08:47 AM
Posts: 8,162 USA
360view
USA
Wow. Not by as much as I was led to believe. The LA pistons might just work fine I. A magnum with magnum crank, rods, balancer and weighted flex plate. 30g is only about 1 oz. Should you be multiplying 30 grams by 8 cylinders? I have not balanced gasoline engines, but I have balanced the rotors of big 100 to 600 hp electrical motors and even 30 grams of imbalance will cause the assembled motor to “walk across the floor” due to vibration as it runs just below 1800 RPM with no load. I would guess the vibration at 4000 to 5000 rpm to be very noticeable.
[Re: 360view]
#3190382
11/12/23 09:05 AM
11/12/23 09:05 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
I just had the machine work done on my 5.9 Magnum. I ask my machinist what it would cost to rebalance the motor to be internally balanced. He said it could be 600-800.00 depending on how much mallory he has to use.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
