as much as you may not want to hear this, the frame rails look like there may be rust issues, although how bad remains to be seen.
the only way to repair the dents and crushed areas is to cut them out and weld new material in there.
if the rails are too far gone, rail replacement will be required.
as to the floor area, a [REALLY] BFH and a piece of wood could possibly be used to get the floor into it's approximate position, depending on what your wanting the outcome to look like.
if the floor is rusty at it's edges, you may be in for a floor pan replacement.
