Running/built 440 & 727 value #3188388
11/03/23 12:09 AM
11/03/23 12:09 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Thinking about changing drivetrain & selling the 440 & 727. Just curious ball park what I should expect to be able to get out of my current set-up.
‘71 440 .060 over
Edelbrock Performer RPM heads 84cc
Forged Domed TRW pistons
Balanced rotating assy w/steel crank
Comp Solid flat tappet XS282S
Crane gold roller rockers
Weiand X-celerator Ported/Polished single plane intake
Aluminum water pump housing
High volume pump
727 with CRT reverse manual valbe body
3500 TCI stall converter
Fresh cam, heads, comp springs with around 250 miles
Unsure miles on bottom end
1,500 miles on the 727 set-up
1967 Barracuda Formula S 383
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: Running/built 440 & 727 value [Re: grancuda] #3188415
11/03/23 06:58 AM
11/03/23 06:58 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
6, t o 7,000 if they are able to see it run... twocents
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Running/built 440 & 727 value [Re: 6bblFLASH] #3189881
11/09/23 04:34 PM
11/09/23 04:34 PM
Minnesota
peabodyracing Offline
Minnesota
I'd agree it's a $6K setup running. $7K might take a bit more time to find a buyer.
Lead, follow or get the hell out of the way
Re: Running/built 440 & 727 value [Re: peabodyracing] #3189884
11/09/23 04:47 PM
11/09/23 04:47 PM
MN
Droop69 Offline
Droop69  Offline
MN
Original HP block? Date code on the assembly date? Casting date on the block?
Guys looking for a 71 HP block will be interested in these items.
Re: Running/built 440 & 727 value [Re: Droop69] #3189946
11/09/23 09:04 PM
11/09/23 09:04 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
where do you live at
Re: Running/built 440 & 727 value [Re: dart games] #3189967
11/09/23 11:06 PM
11/09/23 11:06 PM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
It’s not an HP block
Tulsa OK
2021 Toyota Supra
