School me 9n a 1970 truck 8 3/4 rear
#3187972
11/01/23 07:03 AM
11/01/23 07:03 AM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Rear 8s compleat has left hand studs on driver side A castle nut on axel and the azeo 8s on the outside of the brake drum It's not locked up. Has a sure grip center section he sa8d ht thought it had a 3.73 gear Was in a 1970 dodge truck (can tell by the pads) that had a flat bed on it
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: School me 9n a 1970 truck 8 3/4 rear
[Re: 6PakBee]
#3188022
11/01/23 11:45 AM
11/01/23 11:45 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Well it seams. The rear was changed at some point and not orignal to the 70 truck The rear is out of a truck thou Is the drum splined onto the axel? At some point. Can I pull the axel. Install green bearing Install new normal type axels along with normal brakes
[Re: toplescuda]
#3188025
11/01/23 12:02 PM
11/01/23 12:02 PM
Posts: 10,708 North Dakota
6PakBee
North Dakota
Well it seams. The rear was changed at some point and not orignal to the 70 truck The rear is out of a truck thou Is the drum splined onto the axel? No, it's a tapered fit with a key. At some point. Can I pull the axel. Yes. after you pull the drum with a drum puller. Install green bearing Have no clue. Install new normal type axels along with normal brakes Yes.
[Re: toplescuda]
#3188040
11/01/23 01:07 PM
11/01/23 01:07 PM
Posts: 25,767 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Not without some modifications; they changed the bolt pattern at the end of the housing in '65...you can install the later brakes with custom axles and Green bearings but you'll have to re-drill the bolt pattern.
