QA1 front suspension 64 Dart #3187872
10/31/23 02:58 PM
10/31/23 02:58 PM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
Anyone use a this QA1 front suspension on an early A body?
https://gerstsuspensions.com/products/gts-front-suspension-qa1/
Have a 64 Dart GT slant 6 car I’m going to put a 440 in. Was originally thinking a Mustang II suspension but this is as bolt in deal and will have the right track width. Plus they claim you can use block hugger long tube headers. A little pricey but I think it’s a better setup than the mustang II. Already have a Dana 60 for the rear.
Re: QA1 front suspension 64 Dart [Re: Dabee] #3187940
10/31/23 10:06 PM
10/31/23 10:06 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Do you plan on cutting out the factory shock towers? Leaving them in is going to make it really tough to run an off-the-shelf set of headers. Most folks with big block early A's have to get pretty creative to run a set of headers. I know with mine, I had to take the exhaust up quickly to clear the shock towers.
Re: QA1 front suspension 64 Dart [Re: mopowers] #3187958
10/31/23 11:12 PM
10/31/23 11:12 PM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
Yes that is the plan
